Re: My luck ran out ..... [Re: slantzilla] #1302236
09/12/12 04:07 PM
09/12/12 04:07 PM
CheddarHead till October
weedlayer Offline
weedlayer  Offline
slant--im already shopping --the Griner looks good
Direct hookup to Griner right here:
http://www.727specialist.com/index.html
picked mine up last week from Kieth
Re: My luck ran out ..... [Re: Twin Turbo Mower] #1302237
09/12/12 04:58 PM
09/12/12 04:58 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
Broke the sprag like that 2 times. One was a bolt in sprag that uses the stock parts. Those little metal tangs still fold over easy from the rollers. I now have the a&a ultimate sprag as they call it in my trans along with a griner valve body low band apply been running that for a few years now. The ultimate sprag is a more heavy duty peice. Would be interesting to see which one you had.
dont think it was the Ultimate model
Re: My luck ran out ..... [Re: weedlayer] #1302238
09/12/12 04:59 PM
09/12/12 04:59 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
yea guys---i was looking at Keiths site last night
Re: My luck ran out ..... [Re: 493_DART] #1302239
09/12/12 09:27 PM
09/12/12 09:27 PM
NC
440Jim Offline
440Jim  Offline
NC
Next pass I put a 3K chip in it to calm her down a bit, let go of the button and it launched about 2 feet and ZINNNGG !! up on the 7K chip.
Sounds like the rev limiter saved the stock front drum from coming apart.
A low band apply valve body and a 16-roller sprag (Coan Super Sprag or A&A Ultimate Sprag) will help a lot. An aluminum or steel (not stock cast) drum is a good safety device.
I like the stepped bolts of the Coan better than the A&A plain bolts with compression ferrules.
Re: My luck ran out ..... [Re: 493_DART] #1302240
09/12/12 11:29 PM
09/12/12 11:29 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
The ultimate sprag costs about 200 , A+A sells lots of parts also.
If it was just a normal bolt in sprag and your old sprag was not damaged or loose in the case then it was a total waste or time and money, as you found out.
Re: My luck ran out ..... [Re: JohnRR] #1302241
09/13/12 12:23 AM
09/13/12 12:23 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
my old sprag WAS damaged .
It wasnt the Ultimate we put back in. I dont recall it being $200.
Wasnt any waste of time and money -- I had to tear the trans down due to a faulty valve body from Tranzact that had me chasing my tail for months .
Re: My luck ran out ..... [Re: 493_DART] #1302242
09/13/12 12:06 PM
09/13/12 12:06 PM
JohnRR Offline
JohnRR  Offline
If you old Sprag was damaged then it wasn't a complete waste of time and money , but many are under the assumption that all bolt in sprags are the same and by installing one that there will be no more sprag failures , which is not the case.
Hope you get it fixed some and back out on the track , put the ultimate or super sprag in it this time .
