Re: Keep Fouling plugs....need help
[Re: RobX4406]
#1301646
09/10/12 11:58 PM
09/10/12 11:58 PM
Posts: 1,039 ALBERTA CANADA
CUDA8U
ALBERTA CANADA
I believe at idle it is at 34*
I doubt that if it has springs in it.
If it smells like a fuel factory out the tailpipes, it's not close...
I wouldn't mess with anything else until you know where the idle/initial timing is set.
If you reach in at idle and twist the distributor clockwise and it picks up RPM, it want the timing you just twisted in.
really? any time you can turn the dist.and the rpm increases your engine wants more timing?
[Re: Challenger 1]
#1301650
09/11/12 02:32 PM
09/11/12 02:32 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
Its just smokey, fresh motor smells in no way of burning oil. The guy who built the motor opened the dist up and changed the springs and has it set at 34* total. Vac. advance is unplugged.
How do you know this when you haven't even put a timing light on it?
Why is the vacuum adv disconnected?
And imo rOBBx4406 KNOWS WHAT HE'S TALKING ABOUT, more people should listen to him.
Sometimes I wonder why people bother to offer up anything around here.
Some people don't even have an idea of why idle timing is important. It's been explained numerous times around here and the disaster in waiting that is mechanical advance. Hey, if you want your stuff to run based on bad info from a performance book written in the 70-80's, go for it!
Two words for likely what's causing the OP's issue... TRANSFER SLOTS.
If you don't get why the idle timing and the amount of transfer slot is showing, then you don't understand the relationship of the systems on the car.
And, NO, engines don't always pick up RPM when timing is advanced. It's about finding the efficiency point of the engine at idle. You'll run into limits doing this, namely starter issues. I'll bet this particular engine could run pretty good with 22 initial and 34-35 total all in by 2500.
Pick your way to skin a cat. Your way, IMO, may suck, but, it's still your way. Grab that MP manual and follow the rotten way to time it up. More, or likely, less power to you!
[Re: RobX4406]
#1301651
09/11/12 05:24 PM
09/11/12 05:24 PM
Posts: 12,495 Western Colorado High Desert
moparmarks
If you don't get why the idle timing and the amount of transfer slot is showing, then you don't understand the relationship of the systems on the car. Well said. ![](/ubbthreads/images/graemlins/thumbs.gif)
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: moparrulzzz]
#1301652
09/11/12 05:33 PM
09/11/12 05:33 PM
moparmarks
Oil or carbon fouled plugs? If carbon then is ignition problem or carb is dumping to much gas. Any exhaust smoke? If so what color. Really should take a vacuum reading then choose the power valve. Plug wires? New and not touching the exhaust anywhere?
Carbon Fouled, get blueish colored smoke when starting cold but doen not smell like oil burning, only lasts a second or two. I figured it was rich from choke being closed. Plug wires are new, everything is new!! ![](/ubbthreads/images/graemlins/laugh2.gif) Wires are not touching the headers. I fouled a set of plugs out in 14 miles of cruising 35 MPH avg, goosed it a couple times.
Blue smoke is oil. Black smoke is fuel.
I'd get a vacuum advance on there. Get the timing dailed in and making sure it is on the idle circuit. Check the fuel spray pattern. Check the stark. Blue or yellow? Take a vacuum reading. Then if still going fat I'd go into the carb. What jets are you running?
[Re: moparmarks]
#1301653
09/11/12 05:37 PM
09/11/12 05:37 PM
moparmarks
Also like John said, get some Autolite plugs.
[Re: moparmarks]
#1301654
09/11/12 06:09 PM
09/11/12 06:09 PM
Posts: 508 Cincinnati, Ohio
superbeedave
Cincinnati, Ohio
Then again, What is his vacuum at idle? Could be low enough to tell him his power valve is letting in more fuel. If he is running say 10 inches of vacuum or lower at idle and with a 6.5 power valve it may be getting too much fuel in that way! Just my ![](/ubbthreads/images/graemlins/Twocents.gif) Amongst other things such as timing and advancement not where it should be! Hey, I'm just saying!!
[Re: RobX4406]
#1301658
09/11/12 10:22 PM
09/11/12 10:22 PM
Posts: 3,344 Central TX
roe
Central TX
I'm still learning how to properly tune and dial in a carb/tuning. This thread is putting out some good info. Does anyone here feel like writing a response that explains the relationship between the carb, jets, transfer slots, initial/total timing, etc... I find that guys here do a better job at explaining this stuff than a magazine, or a random article online
1971 Plymouth Satellite 408/904 8 3/4 3.23 SG
[Re: moparrulzzz]
#1301661
09/12/12 12:56 AM
09/12/12 12:56 AM
Posts: 43,352 Bend,OR USA
Cab_Burge
Are your foul out plugs black and shiny or are they dull black?
[Re: Cab_Burge]
#1301662
09/12/12 01:09 AM
09/12/12 01:09 AM
moparmarks
"You should be able to run them in and kill the engine". If turning the idle screws all the way in does not kill the motor then the carb is not down on the idle circuit. Try this and see. I see way too many times someone trying to set the timing when the carb is not set right.
[Re: moparrulzzz]
#1301663
09/12/12 01:20 AM
09/12/12 01:20 AM
moparmarks
Rob Just came in from garage. Had neighbor behind car when 1st started it and while revving motor, he and I agree smoke is black not blue, that being said kneeling in front of the exhaust smells like fuel not raw fuel and burns eyes and throat. Ok...car at temp I put the light on it at idle 975 RPM and it goes to total advance 34*, revving motor with light on it it retards 1-2*'s I have 12-13 inches vaccum at idle jets are 68 rear 70 front. And just so ya know this is my 1st motor and had alot of people giving me crap advice and spending my money. I was told to put those springs in and I wouldn't need to run vaccuum advace and my car would run so much better. With that being said can you help point me in the right direction with this dist. Do I return it to its original state and use the vac. advance? Thnx Chuck
Don't let people hammer you. EVERONE had to start at the begining. Myself I like a vacuum advance on a mild street motor. Black smoke and as fast as your fowling plugs leads me to think you have a carb problem but you need to make sure the ignition is correct first. Process of elimination. Take the steps of elimination that Rob and I are stating. The jets are probabaly close for where you live. What is the timing at idle?
[Re: moparmarks]
#1301664
09/12/12 07:00 AM
09/12/12 07:00 AM
Posts: 1,679 Mansfield,Ohio
moparrulzzz
Mansfield,Ohio
Mark it advaces to 34 total when started.
[Re: moparrulzzz]
#1301665
09/12/12 08:21 AM
09/12/12 08:21 AM
moparmarks
Thats way too much timing. Like Rob stated earlier, initial timing should be around 20* and around 32* total advanced. Sounds like its at 34* with no advance. I'd get a better dist in there first.
