Re: Is this '69 340HP engine color Blue or Turquoise?
[Re: Tom Hand]
#130179
10/01/08 10:37 PM
10/01/08 10:37 PM
Posts: 1,339 Detroit, Michigan
fjr340gts
Detroit, Michigan
Dad bought his 69 340 Dart new, it was turquoise as was my 69 340 Cuda.
Apparently your heater hoses are backwards too!!
Does this affect the coolant flow, or wasn't this the way the factory "did it"??
[Re: fjr340gts]
#130180
10/02/08 08:26 PM
10/02/08 08:26 PM
Posts: 271 MO, USA
Tom Hand
MO, USA
Sorry, but the front one does go to the outlet (on the right as you look at the firewall). Not sure why anyone would think this way is incorrect :). Tom
[Re: RoadRunnerJD]
#130182
10/03/08 07:48 PM
10/03/08 07:48 PM
Posts: 2,537 PORT ALBERNI , BC., CANADA
superwrench
"I don't doubt your memory of a red engine either, but as I said above, I've looked at ALLOT of original 69 340's and haven't seen an orginal red one yet, only Turquoise. Maybe someone will see this post dig out thier old greasey block collections and post something that proves otherwise."
It must have been a 273 if it was red!
For what it's worth, I used to PDI new Mopars at the dealership in those years.....and ALL 340's were turquoise and had red pie tins. We always wondered why the big block magnums got the orange paint......when turquoise was the norm. Just to tell it was a Magnum I guess. 440's and 383's in 68 were all turquoise. Up until '69, the only orange engine was the Hemi.
Make any sense? Or am I suffering from age-induced memory malfunction?
[Re: superwrench]
#130183
10/09/08 10:50 PM
10/09/08 10:50 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
My 10/68 built '69 GTS has a Turquoise 340.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
[Re: IEAT4DS]
#130185
10/12/08 07:34 PM
10/12/08 07:34 PM
Posts: 1,990 , PA
sleepyhead416
, PA
[Re: sleepyhead416]
#130186
10/12/08 07:57 PM
10/12/08 07:57 PM
Posts: 3,691 MO
cdp
MO
There is a 1 owner 69-340 Dart, one family owned. Its turquise. The kid that ownes it now, stroked the original block and added batten w-2 heads.
Ironically, I have everything off the original motor. X-heads, intake, carb, exh. manifolds, oil pan, crank pistons.....all but the block.
Motor is definately turquise.
However, I could see in the transition of model year change, a red 340 could make it into a 69 model. I couldn't see an orange making it though.
[Re: Dingmaster]
#130188
10/12/08 11:14 PM
10/12/08 11:14 PM
Posts: 43,615 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
Yes, 69 motor. The 69 model year started August 1, 1968 and blocks were generally cast 2-3 months before being used.
JB Rhinehart, Realist
A-Body's RULE!
[Re: Dingmaster]
#130189
10/13/08 01:34 AM
10/13/08 01:34 AM
Posts: 17,521 Las Vegas, NV
6bblgt
Las Vegas, NV
Would this 340 be a 69 motor? The cast date looks like 6.18.68 but it's turqoise.
The VIN# on the pan rail or the assembly info from the machined pad on the front driver's side below the head would verify.
