Page 4 of 5 1 2 3 4 5
Re: Another --How much HP?---Engine dyno--416 stroker post [Re: BPE] #1299479
09/19/12 09:11 AM
09/19/12 09:11 AM
BPE Offline
BPE  Offline
I will say 583 hp and 552 tq. But whatever the numbers are I hope it does what you want in the car.
Rod
Well if you get your extra 20 hp and 15 ft.lbs. My guess was pretty much dead on.
Rod
Re: Another --How much HP?---Engine dyno--416 stroker post [Re: BPE] #1299480
09/19/12 10:45 AM
09/19/12 10:45 AM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
If your A/F readings are anywhere close to accurate,there is quite a bit of power to be gained yet.
Looks like the valvetrain is working good at the rpm you ran it to,I'm confident you will get it sorted out!
Keith
Re: Another --How much HP?---Engine dyno--416 stroker post [Re: Dunnuck Racing] #1299481
09/19/12 05:30 PM
09/19/12 05:30 PM
The Great White North
RAMM Offline OP
RAMM  Offline OP
Picked up some fresh pump 91 and pulled it a few more times. Current new bests are 570 hp and 556 ft/lbs. I haven't found the sweet spot with timing yet --I think it wants 2 degrees more.
I have to find best timing, add the mufflers, play with lifter pre load and try a .5" spacer.
So far it's pretty stout for a 10.3 comp small block. It has almost 460 ft/lbs @ 2500 rpm but has a bit of lull in the curve, I'm hoping the mufflers help this some. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: Another --How much HP?---Engine dyno--416 stroker post [Re: RAMM] #1299482
09/19/12 06:22 PM
09/19/12 06:22 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I'm thinking the old Victor 340 might work a little better with the smallish cam/ports and CR
great motor!
WIZE
In Car:
Re: Another --How much HP?---Engine dyno--416 stroker post [Re: RAMM] #1299483
09/19/12 08:28 PM
09/19/12 08:28 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Nice Job Jesse!!!!
You need another 10 hp and 4 ft/lbs and I win.
By the way what do I win again? Matt
Re: Another --How much HP?---Engine dyno--416 stroker post [Re: MattW] #1299484
09/19/12 08:48 PM
09/19/12 08:48 PM
RAMM Offline OP
RAMM  Offline OP
I believe another 10 hp and at least 5 ft/lbs will be attainable.
I can offer you a Get out of Jail free card. J.Rob
Re: Another --How much HP?---Engine dyno--416 stroker post [Re: RAMM] #1299485
09/19/12 09:58 PM
09/19/12 09:58 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
What was the carb set up?
Re: Another --How much HP?---Engine dyno--416 stroker post [Re: emarine01] #1299486
09/20/12 08:05 PM
09/20/12 08:05 PM
RAMM Offline OP
RAMM  Offline OP
The carb set up was a Holley 830 hp.
This was the set up today. J.Rob
Re: Another --How much HP?---Engine dyno--416 stroker post [Re: RAMM] #1299487
09/20/12 08:06 PM
09/20/12 08:06 PM
RAMM Offline OP
RAMM  Offline OP
How do you think the self learning EZE -EFI did? J.Rob
Re: Another --How much HP?---Engine dyno--416 stroker post [Re: RAMM] #1299488
09/20/12 08:17 PM
09/20/12 08:17 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
I will say withing 10 hp.
Re: Another --How much HP?---Engine dyno--416 stroker post [Re: MattW] #1299489
09/20/12 08:42 PM
09/20/12 08:42 PM
RAMM Offline OP
RAMM  Offline OP
Which way? Up or down? J.Rob
Re: Another --How much HP?---Engine dyno--416 stroker post [Re: RAMM] #1299490
09/20/12 09:08 PM
09/20/12 09:08 PM
RAMM Offline OP
RAMM  Offline OP
Overall I'm impressed with the FAST EZE-EFI.
It did everything it was supposed to do (and a few other things too)
Here it is. J.Rob
Re: Another --How much HP?---Engine dyno--416 stroker post [Re: Brian Hafliger] #1299491
09/20/12 09:12 PM
09/20/12 09:12 PM
SoCal
Brian Hafliger Offline
SoCal
Lets just say that I'm sure the potential to get close to 600Hp is there...I guess it depends on the dyno to. On our dyno I would expect 555 or so. On a Superflow I'd think maybe 575...Stuska I'd expect 600!
That's a superflow right??
Brian Hafliger
Re: Another --How much HP?---Engine dyno--416 stroker post [Re: RAMM] #1299492
09/20/12 09:31 PM
09/20/12 09:31 PM
PA
W5DART66 Offline
W5DART66  Offline
PA
I would like to see the cam in advanced 2-4 more if you have not tryed that.....
Injection did way better then I thought most of the people that did TB inj. Was way down vs good carb.
What rule for carb/ intake this year? ( I am lazy could look it up)
Re: Another --How much HP?---Engine dyno--416 stroker post [Re: Brian Hafliger] #1299493
09/20/12 10:24 PM
09/20/12 10:24 PM
RAMM Offline OP
RAMM  Offline OP
I'd like to know what you will say when it makes the same @ UNOH on their VERY conservative DTS dyno's blowing through Flowcosters and 13' (yes 13 feet) of exhaust pipe!!? J.Rob
Re: Another --How much HP?---Engine dyno--416 stroker post [Re: W5DART66] #1299494
09/20/12 10:43 PM
09/20/12 10:43 PM
RAMM Offline OP
RAMM  Offline OP
The cam is already in @ 101.5 I have plenty of PV clearance but have no interest in that. If this were a stout piece within 50 points of a top 5 then YES--It ain't.
They went back to the 2010 rules---hydro cams for all STREET and single planes for injection only. Dual planes ONLY for carbs.
Like you Brett--I was expecting a severe penalty with the TBI.
I'm not all that impressed UNTIL you take into consideration the STOCK replacement EQ heads, the 10.3 compression, hydro cam, the TBI, etc....
The thing that really does get my attention is the RPM range. It takes some work to get a 417 cube engine to make almost 580 hp @ 6000-6100 rpm and hold it only to drop 8 hp all the way up to 6500 rpm.
(Heck my stock stroke build with these castings didn't do that well)
When I committed to this build the idea was to SEE how much rpm a cast iron $600/pr set of cylinder heads on a 4" stroke small block could support. In a word I am SURPRISED.
I have a fully prepped and assembled set of W2's I could drop on and I'm sure the HP would come up substantially, but I won't because I'm a (Do more with less kind of guy). J.Rob
Re: Another --How much HP?---Engine dyno--416 stroker post [Re: RAMM] #1299495
09/20/12 11:18 PM
09/20/12 11:18 PM
Delray beach, Florida
P
Performance Only Offline
P
will this combo ever see the race track? i'd really like to see the track back up the dyno numbers. that would be great.
machine shop owner and engine builder
Re: Another --How much HP?---Engine dyno--416 stroker post [Re: Performance Only] #1299496
09/20/12 11:31 PM
09/20/12 11:31 PM
RAMM Offline OP
RAMM  Offline OP
It probably will actually. Although I'm not sure when. You see, I've been doing this EMC thing since 2009 and I have sold every engine or engines using most of the same components used in the contest.
To be honest--Yes, I think it will make it to the track and I will report the results good or bad--no excuses. I think it will run a low 11. But wait!! Is that in a JR. dragster or in a full body door slammer. J.Rob
Re: Another --How much HP?---Engine dyno--416 stroker post [Re: RAMM] #1299497
09/21/12 12:23 AM
09/21/12 12:23 AM
P
P
it won't matter, honest weight and MPH will be the tell all.
Re: Another --How much HP?---Engine dyno--416 stroker post [Re: RAMM] #1299498
09/21/12 11:26 AM
09/21/12 11:26 AM
SoCal
SoCal
You know better than I do, since I never made it in '09!
I would love to know how my dyno compares to their dyno. I enjoyed participating in that flow around on Speedtalk.com...my bench was real close to Meaux's which is what I was MOST interested in.
Good luck this year, hope you give them hell!! Engine looks like it's working well. Did you get the chance to flow that TB on the EZ kit?
Brian Hafliger
