Re: Turbo Build for the duster info please
[Re: mokid]
#1299166
09/08/12 10:06 AM
09/08/12 10:06 AM
Posts: 453 Holly, MI
JackGTX440
Holly, MI
What is your current combo?
Jack Irons Jr.
'67 GTX, turbo 6.1 HEMI
[Re: JackGTX440]
#1299168
09/08/12 10:23 AM
09/08/12 10:23 AM
Posts: 763 Southington Ct.
turbobitt
Southington Ct.
X2, More info needed.
I would consider going EFI. Fuel managment is key to making good reliable power. Your goal of 1200 HP sounds conservative. Edit: I meant conservative for race gas at least... Allan G.
1970 Challenger w/572 Hemi street car and my pride and joy.
1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno.
1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
[Re: JackGTX440]
#1299169
09/08/12 11:53 AM
09/08/12 11:53 AM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
Currently it's 358 CI, heads flow 408 cfm on the intake naturally aspirated. 3.23 stroke 4.185 bore. 848 HP 565 ft/lbs. 5 stage Dry sump oiling system. 1050 4150 quickfuel carb. 7al ignition. 904 trans 7000 stall convertor. 5.33 with spool
[Re: turbobitt]
#1299170
09/08/12 11:56 AM
09/08/12 11:56 AM
JackGTX440
Holly, MI
Who told you not to turbo this engine?? That would pretty much be my dream combo for my car. I'm currently doing a turbo 6.1. May want to maybe consider a beefier piston, but I only say this because I'm not sure what those pistons look like. What rods do you have? I too would also really consider EFI. Plus with E85, I think you'll make a bazillion hp.
Those engines have some pretty kick ass parts in them. It is obviously going to require a cam, convertor and gear change.
Jack Irons Jr.
[Re: JackGTX440]
#1299171
09/08/12 12:09 PM
09/08/12 12:09 PM
DemonDust
Menomonee Falls
Ever since I mentioned this a few years ago guys have been saying don't do it. But when I was doing the project originally a ton of guys were on here saying that combo would never work as a drag car and wouldn't you know, these engines run 9.30's to 9.40's all day long with minimal to no tuning. Yes the pistons will def need to be changed. I think total height of the piston skirt to deck is only 1.32 if I remember correctly. Extremely short pistons. I'm running a 6.250 rod right now, so plenty of room to shorten the rod for more comp height and make a dish I would think. Yeah everything is billet or titanium ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: DemonDust]
#1299173
09/08/12 09:25 PM
09/08/12 09:25 PM
Posts: 6,151 Melbourne , Australia
LA360
The only thing I would imagine would be a problem is what crankshafts are available, I would imagine a 2" rod journal would have to be a minimum. Is something like that available without having one made? The blocks are plenty sturdy, piston and rods are easily changed, so I don't see what the fuss is about. The only other thing would be camshaft cores with a wide enough lobe separation. I don't know why no one else has tried an engine like this already
Alan Jones
[Re: LA360]
#1299174
09/09/12 01:52 AM
09/09/12 01:52 AM
DemonDust
Menomonee Falls
Currently the compression is at 11.8:1. If I ran the fast system wouldn't I have to do the dual quad setup? If I remember right the single 4 is good for like 600 hp. I have several cranks ranging from 3.23-3.31 with 2.100 rod journals. They were from the early days when Petty was using the old R5 stuff. Compared to the newest R5 stuff, this stuff is heavy ![](/ubbthreads/images/graemlins/laugh2.gif) My plan is to use one of the large journal cranks for the turbo build.
[Re: DemonDust]
#1299178
09/09/12 11:40 AM
09/09/12 11:40 AM
Posts: 12,339 somwhere
smokinwoody
somwhere
I emailed them a couple times a while back, they don't have any build info on their site. I never heard anything from them.
call them and ask for his dad Jack...he's the man behind the mechanical genius....
http://www.radrides.com/home.php
[Re: joshking440]
#1299181
09/09/12 09:34 PM
09/09/12 09:34 PM
DemonDust
Menomonee Falls
I wouldnt let Steve Morris build me a lawn mower engine.
He is as crooked as they come.....and I mean to the max crooked!!!!!
And as usual....he is a man of God
That's good to know, I build all my own engines, so i will only use him for information or parts.
