Re: UNDERCHASSIS HEADERS FOR A A-BODY
[Re: Dustin71]
#1299077
09/08/12 10:52 PM
09/08/12 10:52 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
And you both had to pull the Torsion bars to install them... correct??
[Re: Chris2581]
#1299078
09/08/12 11:04 PM
09/08/12 11:04 PM
Posts: 197 New York
Dustin71
New York
I did. ![](/ubbthreads/images/graemlins/2231195-dggif.gif)
[Re: Cab_Burge]
#1299081
09/09/12 06:22 PM
09/09/12 06:22 PM
Chris2581
Jacksonville, FL
I've never pulled my T-bars either.My question was at those who use the underchassis TTI headers as the TTI website says you have to pull the T-bars to install their headers,not the Pro Parts/Mazzolini style.
[Re: imfixinmopars426]
#1299084
09/09/12 08:18 PM
09/09/12 08:18 PM
Posts: 998 Clinton Township, Michigan
Dartin
does anyone make headers for a-body,RB w/ 440-1 heads? i looked on mancinis,for TTI's...and couldnt find any 2"sets,or am i reading wrong..any ideas???
This is the combo I have. Luckily, I have a good friend with a talent for building headers (HardcoreB). Mine have slip collectors and all of the tubes can be installed in less than a half hour.
Randy
[Re: mopar65]
#1299087
09/09/12 09:42 PM
09/09/12 09:42 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
Well i put my tti in the same time i put my engine in. I have never tried to install TTI headers in a car with a engine in it allready. So i can not say yes or no on pulling the T-bars. mopar65
I put my TTI's in with the motor. BUT,,to get my starter off, the header has to be removed,,,,in order to remove the header, the torsion bar has to be removed.(along with the steering column, drag link, pitman arm, etc) SO,,going in reverse theory,,I would say YES the torsion bar would have to come out to install them with the engine in the car ![](/ubbthreads/images/graemlins/laugh2.gif)
If you like drag racing, support your local track.
[Re: MIKES_DUSTER]
#1299092
09/10/12 01:29 AM
09/10/12 01:29 AM
Posts: 782 wine country
8urvette
wine country
i have a 68 b'cuda with a 440- and VICTOR HEADS I can only tell you what did not fit my car. I am running a andy f- front motor plate, but i mounted it before i took off my stock motor mounts, so i believe i am in stock location. CPPA's did not fit- i would have had to make my steering column go right through the middle of my #7 exhaust pipe. they laid all over the inner fender, touching the whole way. Proparts- did not fit, hit just about everything and then would not make it under the chassis about 1/8" to high to clear the bottom of the car. headman- fendewell headers do not fit. they sit on the shock tower on the passenger side, and i mean SIT looking to "modify" a 1/4" deep on the #2 cylinder to allow them to work. what worked on my car- the set i am building!!!! ![](/ubbthreads/images/graemlins/bump.gif)
[Re: Cab_Burge]
#1299093
09/10/12 12:16 PM
09/10/12 12:16 PM
Posts: 4,041 michigan woods
imfixinmopars426
michigan woods
I bought the Hedman race headers for my car with the 440-1 heads, they are fenderwells. Which I like a lot better than most chassis headers I race the car and I'm getting old so ease of maintenance is very important, especailly between rounds when needed
lol...im getting older too,i know what you mean..been thinking of them too.TTI's show issues w/ stock k-frame,and 440-1's raised port.mad dog headers are about 10 miles away,so i might talk to them.how big of a tire can you run on the front w/ the headmans?....thsnks to all for the help.mike ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Ari440]
#1299095
09/10/12 09:41 PM
09/10/12 09:41 PM
Dartin
Randy
do you have pics
stock front end
what size pipes and collecters
also
TTI makes step headers for R/B with 440-1s
Ari, here are a couple pics. Don't mind the crappy engine compartment. The car has stock suspension/steering. It is tight and the rear tubes on both sides go through the wheelwell.
Randy
