Page 2 of 3 1 2 3
Re: UNDERCHASSIS HEADERS FOR A A-BODY [Re: Dustin71] #1299077
09/08/12 10:52 PM
09/08/12 10:52 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
And you both had to pull the Torsion bars to install them... correct??
Nautilus Racing-
Re: UNDERCHASSIS HEADERS FOR A A-BODY [Re: Chris2581] #1299078
09/08/12 11:04 PM
09/08/12 11:04 PM
New York
Dustin71 Offline
Dustin71  Offline
New York
I did.
Re: UNDERCHASSIS HEADERS FOR A A-BODY [Re: Chris2581] #1299079
09/08/12 11:12 PM
09/08/12 11:12 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
I did not have to pull the torsion bars with the old cast crank 906 headed 440 or the new engine that is in the car now. Mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: UNDERCHASSIS HEADERS FOR A A-BODY [Re: mopar65] #1299080
09/09/12 01:00 AM
09/09/12 01:00 AM
I didn't have to pull my torsion bars either, I have talk to a lot of racers that used the Pro Parts and never heard any of them say the needed to pull the torsion bars. Mine are the originals ones that Bill Bagshaw sold as Pro Parts, not the early ones that CPPA sold or the new ones that Bob Mazolini is having TTI make and sells now
Re: UNDERCHASSIS HEADERS FOR A A-BODY [Re: Cab_Burge] #1299081
09/09/12 06:22 PM
09/09/12 06:22 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I've never pulled my T-bars either.My question was at those who use the underchassis TTI headers as the TTI website says you have to pull the T-bars to install their headers,not the Pro Parts/Mazzolini style.
Nautilus Racing-
Re: UNDERCHASSIS HEADERS FOR A A-BODY [Re: Chris2581] #1299082
09/09/12 07:31 PM
09/09/12 07:31 PM
mopar65 Offline
mopar65  Offline
Well i put my tti in the same time i put my engine in. I have never tried to install TTI headers in a car with a engine in it allready. So i can not say yes or no on pulling the T-bars. mopar65
Re: UNDERCHASSIS HEADERS FOR A A-BODY [Re: mopar65] #1299083
09/09/12 08:09 PM
09/09/12 08:09 PM
michigan woods
imfixinmopars426 Offline
michigan woods
does anyone make headers for a-body,RB w/ 440-1 heads? i looked on mancinis,for TTI's...and couldnt find any 2"sets,or am i reading wrong..any ideas???
Re: UNDERCHASSIS HEADERS FOR A A-BODY [Re: imfixinmopars426] #1299084
09/09/12 08:18 PM
09/09/12 08:18 PM
Clinton Township, Michigan
Dartin Offline
Dartin  Offline
This is the combo I have. Luckily, I have a good friend with a talent for building headers (HardcoreB). Mine have slip collectors and all of the tubes can be installed in less than a half hour.
Randy
Re: UNDERCHASSIS HEADERS FOR A A-BODY [Re: Dartin] #1299085
09/09/12 08:29 PM
09/09/12 08:29 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
Randy
do you have pics
stock front end
what size pipes and collecters
also
TTI makes step headers for R/B with 440-1s
1.39 9.85 - 137 mph
Re: UNDERCHASSIS HEADERS FOR A A-BODY [Re: imfixinmopars426] #1299086
09/09/12 09:22 PM
09/09/12 09:22 PM
I bought the Hedman race headers for my car with the 440-1 heads, they are fenderwells. Which I like a lot better than most chassis headers I race the car and I'm getting old so ease of maintenance is very important, especailly between rounds when needed
Re: UNDERCHASSIS HEADERS FOR A A-BODY [Re: mopar65] #1299087
09/09/12 09:42 PM
09/09/12 09:42 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
I put my TTI's in with the motor. BUT,,to get my starter off, the header has to be removed,,,,in order to remove the header, the torsion bar has to be removed.(along with the steering column, drag link, pitman arm, etc) SO,,going in reverse theory,,I would say YES the torsion bar would have to come out to install them with the engine in the car
If you like drag racing, support your local track.
Re: UNDERCHASSIS HEADERS FOR A A-BODY [Re: CHAPPER] #1299088
09/09/12 11:21 PM
09/09/12 11:21 PM
New York
Dustin71 Offline
Dustin71  Offline
New York
I never tryed it with the T-bar in the car... I just went ahead and took them off and quess what? They were in, in 10min. That's with everything out like he said. Steering link, T-bars, Engine up with side to side swing for clearance... The starter has a weired way of going in but it go's...
Re: UNDERCHASSIS HEADERS FOR A A-BODY [Re: Dustin71] #1299089
09/10/12 12:10 AM
09/10/12 12:10 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Hey Mike we have the CPPA chassis headers on my sons 400 Dart. TTI took over the CPPA headers so the TTI is the same. Plugs are no problem as long as the eng is cold when you change them. They actually fit pretty good. Ron
Re: UNDERCHASSIS HEADERS FOR A A-BODY [Re: 383man] #1299090
09/10/12 12:13 AM
09/10/12 12:13 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
This is the best pic I have of the drivers side. Ron
Re: UNDERCHASSIS HEADERS FOR A A-BODY [Re: 383man] #1299091
09/10/12 12:38 AM
09/10/12 12:38 AM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline OP
Thanks Ron!!!!
Re: UNDERCHASSIS HEADERS FOR A A-BODY [Re: MIKES_DUSTER] #1299092
09/10/12 01:29 AM
09/10/12 01:29 AM
wine country
8
8urvette Offline
8urvette  Offline
wine country
i have a 68 b'cuda with a 440- and VICTOR HEADS
I can only tell you what did not fit my car.
I am running a andy f- front motor plate, but i mounted it before i took off my stock motor mounts, so i believe i am in stock location.
CPPA's did not fit- i would have had to make my steering column go right through the middle of my #7 exhaust pipe. they laid all over the inner fender, touching the whole way.
Proparts- did not fit, hit just about everything and then would not make it under the chassis about 1/8" to high to clear the bottom of the car.
headman- fendewell headers do not fit. they sit on the shock tower on the passenger side, and i mean SIT looking to "modify" a 1/4" deep on the #2 cylinder to allow them to work.
what worked on my car- the set i am building!!!!
Re: UNDERCHASSIS HEADERS FOR A A-BODY [Re: Cab_Burge] #1299093
09/10/12 12:16 PM
09/10/12 12:16 PM
michigan woods
michigan woods
lol...im getting older too,i know what you mean..been thinking of them too.TTI's show issues w/ stock k-frame,and 440-1's raised port.mad dog headers are about 10 miles away,so i might talk to them.how big of a tire can you run on the front w/ the headmans?....thsnks to all for the help.mike
Re: UNDERCHASSIS HEADERS FOR A A-BODY [Re: imfixinmopars426] #1299094
09/10/12 03:14 PM
09/10/12 03:14 PM
I'm runnig a set of 27 inch tall Phoenix on my Duster, I do have the front ride hieght up above the stock level a tiny bit due to driving on the street. Those tires rub on my Hedmans made for the -1 heads on my 400 stroker motor with Indy SR heads raised up a tiny bit to clear the inner fender panels
Re: UNDERCHASSIS HEADERS FOR A A-BODY [Re: Ari440] #1299095
09/10/12 09:41 PM
09/10/12 09:41 PM
Dartin Offline
Dartin  Offline
Randy
do you have pics
stock front end
also
Ari, here are a couple pics. Don't mind the crappy engine compartment. The car has stock suspension/steering. It is tight and the rear tubes on both sides go through the wheelwell.
Randy
Re: UNDERCHASSIS HEADERS FOR A A-BODY [Re: Dartin] #1299096
09/10/12 09:42 PM
09/10/12 09:42 PM
Dartin Offline
Dartin  Offline
Right
Page 2 of 3 1 2 3
