Re: Cross Drilled vs. Slotted Rotors
[Re: MuuMuu101]
#1299036
09/07/12 03:37 PM
09/07/12 03:37 PM
Posts: 27,486 So Cal
autoxcuda
So Cal
I was just going to say, "Doesn't drilling holes in the rotors create stress risers?" Now since the slotted rotors are actually thinner in some spots than others, wouldn't that be a primary weak point in the rotor or is the rotor thick enough and over engineered that it wouldn't matter in harsh racing conditions?
The slots are the safer way to do. Doesn't really weaken a stock setup. Still not necessary for street car.
[Re: MuuMuu101]
#1299038
09/07/12 04:18 PM
09/07/12 04:18 PM
autoxcuda
So Cal
So basically it's all for the look.
On a car farting around town that has adaquate brakes. Not neccessary. On an overloaded capacity truck that cooks the brakes, maybe slots or casted in holes would help.
On the racetrack, it could help when done properly. But not all race cars use them.
[Re: MuuMuu101]
#1299041
09/07/12 05:24 PM
09/07/12 05:24 PM
Posts: 28,078 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
One added benefit to the cast in holes is lighter weight. It doesn't remove a lot of weight but anything you do to remove rotating weight without compromising braking ability is a benefit.
[Re: feets]
#1299042
09/07/12 05:26 PM
09/07/12 05:26 PM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
I forgot about that point. ![](/ubbthreads/images/graemlins/thumbs.gif)
