Re: Rev-n-nator ignition boxes.... NOW installed ,REPORT:
[Re: Kern Dog]
#1298849
10/02/12 10:51 PM
10/02/12 10:51 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
The box went in the same way the old one came out. On removal, I noticed that my old was actually was the "Wells" unit that tested the lowest power numbers of the group. I reduced the timing by 4 degrees and went for a drive. The car has always had a bunch of low end torque, so it is hard to tell if there are any gains from a dead stop. Anything over half throttle just blows off the tires. I still had some detonation. They state that the user may need to retard the timing 2-6 degrees. Thats fine, but by backing out the timing to avoid detonation, I'm also losing the 17 degrees of initial timing that the engine likes. To maximize the gains of this unit, I may either need higher octane gas or some distributor mods. Neither sound all that great to me. The engine runs strong, but it also did before. The rev limiter in the unit does work. I can say that there is nothing specifically wrong with the product, but I'm not sure yet if I like it.
[Re: Kern Dog]
#1298851
10/03/12 10:12 AM
10/03/12 10:12 AM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
my main concern about the box was DURABILITY, then a similar performance to FBO/Chromed boxes at least ( when they worked )... once that is met allong with no mods on wiring, I'm simply satisfied. If I win some over them, WELCOMED!!!
and I positivelly can notice a better response over chromed and FBO boxes.
Re: Rev-n-nator ignition boxes.... Anyone tried them?
[Re: Montclaire]
#1298855
01/30/13 04:08 PM
01/30/13 04:08 PM
Posts: 50 Mn
The R/T Garage
Mn
I don't have one yet but I will probably buy one. I really wish they offered a version without the LED readout that would just use the MSD "pills." I have to assume that since you select the rev limit on install when powered, that if your batt goes dead or is disconnected, you have to reset every time. With the pills the difference from stock appearance would be very, very small, and if the car went unpowered there would be no issue.
The Rev-n-nator will hold whatever setting that has been set. Even if you take it out and throw it on a shelf for 10 years. Thank You, R/T Garage
[Re: The R/T Garage]
#1298856
05/27/13 07:55 PM
05/27/13 07:55 PM
Posts: 6,301 colorado
a12superbee
colorado
It's been a few months since one of these threads has had any info added. Anyone have anything to say that wasn't covered in previous threads? Is the failure rate better than the orange boxes? I'd love for this to be a silver bullet product.
I can't afford this.
mark
