Re: Dyno Gurus Advice Needed!!!
[Re: Dunnuck Racing]
#1297224
09/04/12 07:41 PM
09/04/12 07:41 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
Very true. The engine can run in terrible weather, but the CF will compensate for that. It will however affect the overall tune of the engine...in other words if you tune for terrible weather, and the run it in good weather it'll be very lean.
Get to know your dyno guy and others that have used him. Then make your decision.
Brian Hafliger
[Re: Brian Hafliger]
#1297225
09/04/12 08:23 PM
09/04/12 08:23 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
This is very helpful information so far. If we can all learn at least a little we will know we are getting honest numbers.Also having honest numbers on Horse-Power & Torque & weight of car is a Big + in getting the converter set up right. Its also nice to know the new engine or new engine build is making the Horse-Power you paid for it to be.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
#1297227
09/04/12 08:58 PM
09/04/12 08:58 PM
Posts: 2,091 Delray beach, Florida
Performance Only
i've dyno'd engines at several different facilities over the years that range from state of the art to the most basic bare bones types. i know of one shop that has a duct from their A/C going into the carb hat. they tell me horsepower sells engines. it does, but only when you can get the same power at the track. it's one thing to calibrate the load cell, but that's only one of several things that will determine a correction factor and final numbers. i've been in facilities that don't even have a clue as to what a phsycrometer is. a dyno is only as good as the information that's fed into it. garbage in, garbage out. over the years i've seen many a member claim great dyno numbers, only to fall way short of expectaions at the track, one of those is fairly recent. the best advice i can give is to ask the operator if the load cell is calibrated, check to make sure the baromter is accurate, take a wet bulb (phsycromter) reading, use the correct s/g reading for the ful being used, use a consistent rpm/ second while tuning, don't change in the middle of tuning. make sure the dyno repeats with no other changes being made. hopefully you'll get good, consistent numbers that the track will substantiate. i left a couple of other things out but you get the idea.
machine shop owner and engine builder
[Re: Performance Only]
#1297229
09/04/12 09:53 PM
09/04/12 09:53 PM
Posts: 6,146 Melbourne , Australia
LA360
Just out of interest, what is a Phsycrometer Dan? I have never heard of it
Alan Jones
[Re: LA360]
#1297230
09/04/12 10:05 PM
09/04/12 10:05 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
A dual bulb sling phsycrometer are used to determine the humidity, my first weather station had one instead of a cheap humidity gauge. You where instructed to wet one bulb and sling it around in the air your racing in for thirty seconds or so and take a reading on the difference between the wet and dry bulb, use the enclosed chart with it to get the humidity. Do that three times quickly to validate your results It use to be harder to keep weather records, now its push some buttons and store it
[Re: Old School]
#1297232
09/06/12 01:04 PM
09/06/12 01:04 PM
Posts: 715 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
When someone leaves my dyno, they have a CD with all the data on it, RAW, corrected and every factor that went into getting those numbers. Along with a copy of the windyn software to look at it any way they want.
As far as slinging a phsycromter around, nope I don’t do it. The SF Powermark was made this decade and all weather readings are taken by sensors, in real time. In fact, if the air was to change in the middle of a pull (unlikely) then the correction factor would change. (raw numbers wouldn’t)
Since you are going to a dyno to collect data on how your engine runs, I can’t see a reason why you shouldn’t leave with a ***load of info.
Joe
Without Data, you’re just another guy with an opinion.
[Re: sr4440]
#1297233
09/06/12 05:41 PM
09/06/12 05:41 PM
MRMOPAR622
Sweet Home Alabama
Since you are going to a dyno to collect data on how your engine runs, I can’t see a reason why you shouldn’t leave with a ***load of info. That's what I am looking for when I have one dynoed...useful info.! I know nothing about running or setting up a dyno,but wanted to get a little info. to make sure it was being done right. I have heard a lot of talk about Happy Dyno's and it never hurts to have a little knowledge of what's going on. I would hate to buy or have a engine built and they dyno the engine and it shows 800 hp and it only makes 650 hp.But after reading most post I feel my chances of getting a fairly honest dyno test results are a lots better.
