Page 2 of 11 1 2 3 4 10 11
Re: Reserection of my old W8 Bullet [Re: 408strokerdart] #1296655
09/04/12 03:42 PM
09/04/12 03:42 PM
Las Vegas
Al_Alguire Online laugh2
Las Vegas
Glad to hear you are getting closer to getting back out there. Look forward to hearing the results of all the new changes.
Re: Reserection of my old W8 Bullet [Re: Al_Alguire] #1296656
09/04/12 05:32 PM
09/04/12 05:32 PM
bronx n.y
O
one bad fish Offline
O
bronx n.y
That thing should make some good power
Re: Reserection of my old W8 Bullet [Re: 408strokerdart] #1296657
09/04/12 05:41 PM
09/04/12 05:41 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
Glad to see you back Brian Motor should be a really nice piece when your done
Re: Reserection of my old W8 Bullet [Re: 340RICK] #1296658
09/04/12 06:15 PM
09/04/12 06:15 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
Looks good.....
What rpm range are you planning for this deal???
Re: Reserection of my old W8 Bullet [Re: jim sciortino] #1296659
09/04/12 08:29 PM
09/04/12 08:29 PM
Out West
408strokerdart Offline OP
Out West
Looks good.....
8000 to 8200 max Jim. New cam will make more torque than the old one.
Re: Reserection of my old W8 Bullet [Re: 408strokerdart] #1296660
09/04/12 08:50 PM
09/04/12 08:50 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
After all of the trouble you've had, I would have put it on a Dyno! I hope it all goes well, lesser people would have thrown in the towel long ago!
Alan Jones
Re: Reserection of my old W8 Bullet [Re: 408strokerdart] #1296661
09/04/12 08:51 PM
09/04/12 08:51 PM
Caledonia, Ohio
BigDog68Dart Offline
Caledonia, Ohio
looks like you are coming along nicely, Dad is ready to break that thing in for you! you are out of practice and you know i'll take it easy on it!
Re: Reserection of my old W8 Bullet [Re: 408strokerdart] #1296662
09/04/12 09:24 PM
09/04/12 09:24 PM
Trumbull,CT.
Trumbull,CT.
Looks good.....
Are we talking peak HP at 8-8200, or cross rpm???
RPM is ET....in these smallblocks. Converter flash, gear ratio and shift recovery, get it done. With the right hardware, 8000 is not that high these days and should be easy on maintenance.
Re: Reserection of my old W8 Bullet [Re: 408strokerdart] #1296663
09/04/12 09:26 PM
09/04/12 09:26 PM
San Antonio,TX
440W8 Duster Offline
San Antonio,TX
Man I hope I don't let you down...
Looks nice
You are one of the few that haven't let me down. Superior workmanship and attention to details. Can't say enough good things about your work or ports. It won't be much longer and you will have your answers as to how well this port works on my stuff.
I just hope that I did the heads justice by making everything else "right" under them.
Brett does good work.
70 Duster W8 motor.
1.29 60ft 5.79 1/8 at 120 mph
glide with 1.80 gear
@3170 lbs.
Re: Reserection of my old W8 Bullet [Re: jim sciortino] #1296664
09/04/12 10:06 PM
09/04/12 10:06 PM
Out West
Out West
Looks good.....
I agree with all of that Jim. I will be feeling this combo out and give it what it wants. I'm loving the belt drive as I don't have anything in front of it and I can change/play with cam timing in just a few minutes. Clearances were checked within a range both directions from the installed so I know where I can safely play.
Re: Reserection of my old W8 Bullet [Re: BigDog68Dart] #1296665
09/04/12 10:09 PM
09/04/12 10:09 PM
Out West
Out West
Yes Dad....alot further than you think.
Re: Reserection of my old W8 Bullet [Re: 408strokerdart] #1296666
09/04/12 11:10 PM
09/04/12 11:10 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
hey good luck i hope it all work out for you
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Reserection of my old W8 Bullet [Re: WHITEDART] #1296667
09/11/12 10:26 PM
09/11/12 10:26 PM
Out West
Out West
A few more pictures as it went back together.....
I went with Total Seal gapless top ring/Napier second ring and low tension oil ring. Pistons were sent off to have the skirts coated with some proprietary coating that added about .0015 to the piston diameter. This was done to compensate for the .002 over the cylinders were honed to remove the grooves from the debris. I used the total seal quick seat in the cylinders and coated everything with their TS1 to seat the rings quickly. Rod bearings were all set to .0028 to .0032 per the GRP spec of .0025 to .0035
Also went with a new Charlies pan that was built to my drawing for use with the swinging pickup. It holds almost 9 quarts under the crank throw without changing my ground clearance. I did a small kick out that is slightly raised off the floor to add volume, but keep all of the available oil in the sump area. This has Charlies newest tray design (full length without a pump).
Re: Reserection of my old W8 Bullet [Re: Thumperdart] #1296668
09/11/12 10:31 PM
09/11/12 10:31 PM
Out West
Out West
Lookin good Good you caught the bearing deal. Whats the whole motor combo by chance.
Sorry I really didn't respond to this question Dom, but I will touch on the combo as I post updates of the engine re-assembly. Just my way to keep everyone tuned in.
Re: Reserection of my old W8 Bullet [Re: 408strokerdart] #1296669
09/11/12 11:12 PM
09/11/12 11:12 PM
Mobile Alabama
SB412DUSTER Offline
SB412DUSTER  Offline
Mobile Alabama
The last pic of the pan whats the little sleeve welded to the pan?
Re: Reserection of my old W8 Bullet [Re: SB412DUSTER] #1296670
09/11/12 11:15 PM
09/11/12 11:15 PM
Out West
Out West
There is one under the kick out on the other side to match. They are for my drip pan to mount to. The drip pan has pins on it and just slide forward to engauge and then dzus into place on the front of the pan.
Re: Reserection of my old W8 Bullet [Re: 408strokerdart] #1296671
09/11/12 11:17 PM
09/11/12 11:17 PM
Mobile Alabama
SB412DUSTER Offline
SB412DUSTER  Offline
Mobile Alabama
good idea
Re: Reserection of my old W8 Bullet [Re: SB412DUSTER] #1296672
09/11/12 11:28 PM
09/11/12 11:28 PM
Out West
Out West
good idea
I just hate diapers and wanted a way that I could still access the bottom easily and pass tech. Plus it isn't just a drip pan....it's a belly pan.
Re: Reserection of my old W8 Bullet [Re: 408strokerdart] #1296673
09/11/12 11:50 PM
09/11/12 11:50 PM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
Brian, You're smarter than the average mule and his head is twice the size of yours!
I really like that idea. I may have to modify it a little for the cuda. Beep
Re: Reserection of my old W8 Bullet [Re: Bigbeep] #1296674
09/11/12 11:52 PM
09/11/12 11:52 PM
Out West
Out West
I don't know about that John....been feeling like an average mule here lately. Good luck at Norwalk if you are going. Wish I was coming up this year.
