Re: 383 bigblock
[Re: Dodgem]
#1296622
09/04/12 07:26 PM
09/04/12 07:26 PM
Posts: 2,507 Royersford, PA
bschargerse
Royersford, PA
Sorry to hijack this thread, I'm looking at doing a 383 build. Good info here.
JohnRR, did you get my PM about it? I know you're probably busier than a one-armed paper hanger.
Brian - 1971 Dodge Challenger "The Dodge, which was practically stock, just left the Mustang like you wouldn't believe."
Re: 383 bigblock
[Re: Dodgem]
#1296623
09/04/12 07:44 PM
09/04/12 07:44 PM
Posts: 843 Suffolk,VA
ireland383
Suffolk,VA
I like it you will be fine probably 160 to 170 cranking compression. make well north of 400 gross hp and should be fine on 93 octane even 91
I have 165, 170 cranking compression and it runs fine on 93 octane.
Re: 383 bigblock
[Re: ireland383]
#1296624
09/04/12 07:52 PM
09/04/12 07:52 PM
Posts: 12,495 Western Colorado High Desert
moparmarks
The DP should work fine with his 3000 stall and 3.91 gears. 1800 stall and 3.23 gears, no. A 650cfm would be fine also for a 383 motor. Which 3310 do you have? If its a -1 or -2 I'd probably run that.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
Re: 383 bigblock
[Re: moparmarks]
#1296625
09/05/12 12:31 AM
09/05/12 12:31 AM
Posts: 32 LaFollette TN 37766
383ramd150
LaFollette TN 37766
Thats the only reason i was gonna run the dp since high stall and steep gears but i will try the 3310 but have to look to see which one it is and will let you know!But was planning on 93 octane!I can always use felpro .040 headgaskets if needed!
Re: 383 bigblock
[Re: 340SHORTY]
#1296629
09/11/12 12:37 PM
09/11/12 12:37 PM
Posts: 1,285 Pacific NW USA
CompSyn
Pacific NW USA
DONT use a HV pump. A standard pump is more than plenty..
Sometimes less is more.
Re: 383 bigblock
[Re: stumpy]
#1296631
09/11/12 02:53 PM
09/11/12 02:53 PM
383ramd150
LaFollette TN 37766
Ok thanks and the truck pan is 6 quart!But figured i would post some pics but I am not gonna get to run aluminum intake yet so will be using the factory 2806301 intake with light mods!Gonna get motor running first then buy either performer rpm or torker intake!
