Re: 383 bigblock [Re: JohnRR] #1296618
09/04/12 01:17 PM
09/04/12 01:17 PM
LaFollette TN 37766
3
383ramd150 Offline OP
LaFollette TN 37766
Yes and it is only a weekend street/strip toy never gonna see interstate!I had the truck down to do a stroker sb but i have went into a snag and filing bankruptcy so my buddy in the pic does bigblocks and helped me out i bought and and most of the parts for 750.00!All i need is balancer,water pump,headers,tranny parts and 742 or 489 case!I have the holley 3310 but going to buy dp as bout everybody here uses dp's with no problem!My only part is block is ready but not zero decked and dont want to take block back to machine shop as i put cam bearings already in and block was painted by him awhile back!
Re: 383 bigblock [Re: 383ramd150] #1296619
09/04/12 01:21 PM
09/04/12 01:21 PM
LaFollette TN 37766
3
LaFollette TN 37766
The cam came with this deal and is new!part#21-237-4 and calls for 9.1 to 10.1 comp 2500+stall and 3.91+gear!
Re: 383 bigblock [Re: 383ramd150] #1296620
09/04/12 03:14 PM
09/04/12 03:14 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
you are going to be hard pressed to run pump premium wit hthat compression ratio and open chamber heads.
Since you are trying to save money and the engine is still just a block use the 3310 and have the block at least squared , it will cost less than a new 750DP.
Good luck with the build.
Re: 383 bigblock [Re: 383ramd150] #1296621
09/04/12 03:46 PM
09/04/12 03:46 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I like it you will be fine probably 160 to 170 cranking compression. make well north of 400 gross hp and should be fine on 93 octane even 91
Re: 383 bigblock [Re: Dodgem] #1296622
09/04/12 06:26 PM
09/04/12 06:26 PM
Royersford, PA
bschargerse Offline
bschargerse  Offline
Royersford, PA
Sorry to hijack this thread, I'm looking at doing a 383 build. Good info here.
JohnRR, did you get my PM about it? I know you're probably busier than a one-armed paper hanger.
Brian - 1971 Dodge Challenger
"The Dodge, which was practically stock, just left the Mustang like you wouldn't believe."
Re: 383 bigblock [Re: Dodgem] #1296623
09/04/12 06:44 PM
09/04/12 06:44 PM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
I have 165, 170 cranking compression and it runs fine on 93 octane.
Re: 383 bigblock [Re: ireland383] #1296624
09/04/12 06:52 PM
09/04/12 06:52 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
The DP should work fine with his 3000 stall and 3.91 gears. 1800 stall and 3.23 gears, no. A 650cfm would be fine also for a 383 motor.
Which 3310 do you have? If its a -1 or -2 I'd probably run that.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: 383 bigblock [Re: moparmarks] #1296625
09/04/12 11:31 PM
09/04/12 11:31 PM
LaFollette TN 37766
3
LaFollette TN 37766
Thats the only reason i was gonna run the dp since high stall and steep gears but i will try the 3310 but have to look to see which one it is and will let you know!But was planning on 93 octane!I can always use felpro .040 headgaskets if needed!
Re: 383 bigblock [Re: 383ramd150] #1296626
09/08/12 01:47 PM
09/08/12 01:47 PM
LaFollette TN 37766
3
LaFollette TN 37766
Ok I am going to get oil pump but need to know standard volume or hi-volume with stock truck pan,so which one?Thanks
Re: 383 bigblock [Re: 383ramd150] #1296627
09/11/12 12:56 AM
09/11/12 12:56 AM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
Go with the hi-volume. Better protection at higher rpms. More oil circulated thru the engine is a GOOD thing. Just make sure you run at LEAST a 6-quart (or more) oil pan (deep or low profile, your choice) with a windage tray. I'm not too sure about that truck oil pan's capacity, 5 quarts maybe? Kinda marginal when that 383 "ramps up" it rpms to 6K.
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: 383 bigblock [Re: HYPER8oSoNic] #1296628
09/11/12 07:30 AM
09/11/12 07:30 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
DONT use a HV pump. A standard pump is more than plenty..
I am truckless..
Re: 383 bigblock [Re: 340SHORTY] #1296629
09/11/12 11:37 AM
09/11/12 11:37 AM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
Sometimes less is more.
Re: 383 bigblock [Re: CompSyn] #1296630
09/11/12 01:08 PM
09/11/12 01:08 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Another vote for running a stock pump.
Re: 383 bigblock [Re: stumpy] #1296631
09/11/12 01:53 PM
09/11/12 01:53 PM
LaFollette TN 37766
3
LaFollette TN 37766
Ok thanks and the truck pan is 6 quart!But figured i would post some pics but I am not gonna get to run aluminum intake yet so will be using the factory 2806301 intake with light mods!Gonna get motor running first then buy either performer rpm or torker intake!
Re: 383 bigblock [Re: 383ramd150] #1296632
09/11/12 02:37 PM
09/11/12 02:37 PM
Grand Prairie,Texas
Grand Prairie,Texas
You won't like a torker. Stick with the performer dual plane intake.
