Re: Pop up Hood Spring / Paint Protection [Re: Sinitro] #1296592
09/06/12 11:37 PM
09/06/12 11:37 PM
SE Pa.
LimeliteAero Offline
SE Pa.
My fix for the mentioned issue is for the other end, on the hood.
I took a body washer about 1.25" in diameter and mounted it with a single self tapping screw. So now the spring has a solid contact surface to push on..
Just my $0.02...
thanks....but thats not going to work for me.
Re: Pop up Hood Spring / Paint Protection [Re: LimeliteAero] #1296593
09/15/12 10:44 PM
09/15/12 10:44 PM
robertop Offline
robertop  Offline
It's an Aerostar; the Windstar had no spring at all, as far as I can tell. You can only find them at junkyards.
Re: Pop up Hood Spring / Paint Protection [Re: robertop] #1296594
09/16/12 11:15 AM
09/16/12 11:15 AM
St.Clair Shores, Mich
bryansgarage Offline
I grabbed 7 of them off Ford mini vans at the pick and pull last week.
Re: Pop up Hood Spring / Paint Protection [Re: bryansgarage] #1296595
09/16/12 11:29 AM
09/16/12 11:29 AM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
I put a large vacuum cap over my spring. Blends in the with the engine bay been on there for 12 years. Dark Spring + Dark Engine bay
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Pop up Hood Spring / Paint Protection [Re: Pyper70] #1296596
02/14/13 06:00 PM
02/14/13 06:00 PM
great lakes
O
oldrods Offline
oldrods  Offline
O
great lakes
2013 jeep wrangler has a spring cover that looks just like ford one.
Re: Pop up Hood Spring / Paint Protection [Re: oldrods] #1296597
02/14/13 08:24 PM
02/14/13 08:24 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
I used some heat shrink tubing.
It's cheap, works great and hardly noticeable
Thought about the Plasti Dip but it's expensive and I only had one use for it.
