Congratulations Myron !!!!!!!!!!!!!!
#1296485
09/03/12 09:42 PM
09/03/12 09:42 PM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
Congrats to Myron Piatek on taking the Ironman at Darlington today in stock eliminator My Engine Builder Mike Thompson also won yesterday in Top Sprtsman and good friend John Taylor runnered up today in Super Rod Had to be loooong weekend Rickster
Re: Congratulations Myron !!!!!!!!!!!!!!
[Re: 340Cuda]
#1296490
09/09/12 12:17 AM
09/09/12 12:17 AM
Posts: 1,675 Mi.
G-Money1320
Mi.
Can the mods just make a "Congratulations Myron" sticky and we can just change the dates and venues!! Way to go Myron!!
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out. 11.06 open headers----so far!!
[Re: G-Money1320]
#1296491
09/09/12 10:05 AM
09/09/12 10:05 AM
Posts: 20,666 in a cattle trailer down by th...
Guitar Jones
Great idea. I know Myron has worked long and hard to achieve his success. Congrats again Myron!!
[Re: j.mcconnell]
#1296495
09/10/12 12:55 PM
09/10/12 12:55 PM
Posts: 5,895 Florida
Locomotion
I thought you ran heavier last year, like I/CM. Did you change the combo or just shed weight?
Thanks!
I normally run J/CM which is 3,530 lbs minimum w/driver. I sometimes go to K/CM with a 3,690 lb minimum for a record run, if there might be traction concerns or to get away from any other fast J/CM cars. I may have run I/CM, but at J weight, at one race in San Antonio years ago as a courtesy to a friend who was in J/CM also.
Lisa and Eddie Bolton usually run their car in G, H & I believe I/CM.
Lisa is a very tough competitor, won the last Moser Axle Mania Shootout that IHRA had and was the only Stocker to ever do it against all of the other classes. I was a runner-up once.
Another tough race/racer was Missy Phillips in an A/CM Nova in the semi's. We both had .033 lights and both ran dead on to the hundredth. But I beat her by .004 which clinched my #2 spot in Stock for Div. 2.
Gotta watch them girls! lol
