Re: 9/17/68 383 block in 70 Roadrunner...#s matching? [Re: 70 Roadrunner*] #1296373
09/04/12 01:38 AM
09/04/12 01:38 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
E3 97622
PP8332239 01 70
Like John suggested - Need some clarification above, but .....
RM23N0G113812 = attempt at a "re-stamp" of your VIN#
I removed my WAG
PP833 = New Process 4-spd transmission
2239 = transmission assembly date - Thursday, 9/14/67 (1968 model year)
0170 = transmission unit number
Re: 9/17/68 383 block in 70 Roadrunner...#s matching? [Re: 6bblgt] #1296374
09/04/12 01:55 AM
09/04/12 01:55 AM
Vancouver,Canada
70 Roadrunner* Offline OP
Vancouver,Canada
John and Dan here is the pad on the passenger side of the car...
Re: 9/17/68 383 block in 70 Roadrunner...#s matching? [Re: 70 Roadrunner*] #1296375
09/04/12 02:02 AM
09/04/12 02:02 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Another poor attempt at a re-stamp.
Re: 9/17/68 383 block in 70 Roadrunner...#s matching? [Re: Alaskan_TA] #1296376
09/04/12 02:24 AM
09/04/12 02:24 AM
Vancouver,Canada
Vancouver,Canada
Here's the tag on the drivers side...man I was having such a good day,thinking maybe,possibly that I might have something a little special.Don't get me wrong,I love my car...but it would have been pretty cool all things considered...
Boy if I could get my hands on that guy...oh well it's still a pretty darn nice 383 70 RR with an 18-spline 4spd and a Dana-60...have to look on the positive side...thanks guys for hanging in there and helping a new guy out.Very much appreciated !
Re: 9/17/68 383 block in 70 Roadrunner...#s matching? [Re: 70 Roadrunner*] #1296377
09/04/12 02:31 AM
09/04/12 02:31 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
All the casting numbers are typical of PP833 4-speed transmissions. Do you know for a fact that it is 18-spline? Are there dual mounts for a shifter on the tailshaft?
Re: 9/17/68 383 block in 70 Roadrunner...#s matching? [Re: 6bblgt] #1296378
09/04/12 03:12 AM
09/04/12 03:12 AM
Vancouver,Canada
Vancouver,Canada
Dan do you mean like the B/E tail shaft? One spot forward for the B shifter and one aft for the E ? I don't think it does but I had the tranny out when I bought it and had it re-built.The guy who re-built it commented on it being an 18-spline unit.Once again I show my novice knowledge...
Re: 9/17/68 383 block in 70 Roadrunner...#s matching? [Re: Alaskan_TA] #1296379
09/04/12 09:58 AM
09/04/12 09:58 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What he said . The casting number on the shift cover is meaningless for the most part , every single 4 speed has that same cover and same number , other than the date being changed daily.
Also you car would not have had a Dana 60 from the factory .
Re: 9/17/68 383 block in 70 Roadrunner...#s matching? [Re: 70 Roadrunner*] #1296380
09/04/12 10:00 AM
09/04/12 10:00 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Yes the forward and rear mount points. If it doesn't have one then it would have a 69 trans crossmember installed because the trans mount point was moved for the 70 model year .
Re: 9/17/68 383 block in 70 Roadrunner...#s matching? [Re: JohnRR] #1296381
09/04/12 12:01 PM
09/04/12 12:01 PM
Vancouver,Canada
Vancouver,Canada
I believe it's a 67 4spd unit.I can't believe someone would go to that extent to [Edited by Moparts - Family Friendly Site - Keep it clean] someone into thinking it is or may be a numbers matching car.Not that I was told it was in the first place but after seeing these stamps someone was definitely trying to [Edited by Moparts - Family Friendly Site - Keep it clean] someone...I still love this 70 at any rate and again guys I really appreciate all your help.This site has been a ton of help for me ever since I bought this car...cheers
Re: 9/17/68 383 block in 70 Roadrunner...#s matching? [Re: 70 Roadrunner*] #1296382
09/04/12 12:14 PM
09/04/12 12:14 PM
North Pole,New York
formula_s Offline
formula_s  Offline
North Pole,New York
So no way it's the original engine? I'm just trying to figure this all out...and yes,I'm new-ish to the car as well as the hobby.But man I love this car...
As you get older you'll learn never to 'love' something that can't love you back.
Re: 9/17/68 383 block in 70 Roadrunner...#s matching? [Re: 70 Roadrunner*] #1296383
09/04/12 12:15 PM
09/04/12 12:15 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
68 , that ID pad is not present till the 68 model year .
Money makes people do stupid things.
Re: 9/17/68 383 block in 70 Roadrunner...#s matching? [Re: JohnRR] #1296384
09/04/12 12:22 PM
09/04/12 12:22 PM
Vancouver,Canada
Vancouver,Canada
"As you get older you'll learn never to 'love' something that can't love you back."...I'm 46 and I think I've got that one figured out just fine...it's a figure of speach...I still love that car...
and John 68 it is...thanks for your help!
