Re: ladder bar set-up ???? [Re: VernMotor] #1295942
09/04/12 06:14 PM
09/04/12 06:14 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
If you ask me.. the stall on that converter is kind of high. 5400 for a big block car..
thats what mine is and i have a 493 with EZ heads. smaller cam than the OP
Re: ladder bar set-up ???? [Re: VernMotor] #1295943
09/04/12 06:27 PM
09/04/12 06:27 PM
Plant city fl
70Dart499 Offline
70Dart499  Offline
Plant city fl
IMO if the ladder bar setup is in the budget, do it. I recently converted my Dart from SS springs to coil overs and DA shocks, and my 60' and my ET immediately dropped 2 tenths, and that was with a carb issue that caused the engine to run like crap. The car launches so much better with the ladders also, its smooth and straight every time. If you have the ladder bars done, have them done by a reputable shop that can adjust them properly before you take the car to the track and you probably wont really need to touch them unless you WANT to tweak on them. If you go to the ladders, you won't regret it. JMHO
1970 Dart Drag Car
Re: ladder bar set-up ???? [Re: VernMotor] #1295944
09/04/12 08:55 PM
09/04/12 08:55 PM
My current T/A 8 inch SS converter flashes to 5800 to 6000 RPM depending on the track elevation and weather, I shift it at or close to 7000 RPM and it drops back to 5800 to 6000 RPM according to the VDO Extreme playback tach. My old ten inch custom built converter flashed to 4400 RPM foot stalling and it would drop back more to around 4800 to 5200 RPM depending on the shift RPM, the 8 inch is .2 ET and 2 MPH faster than the ten inch was with no other changes I have a T/A 9 inch SS converter I will try next, test, test and test some more
Re: ladder bar set-up ???? [Re: Cab_Burge] #1295945
09/04/12 09:05 PM
09/04/12 09:05 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Wow I do not have as much HP . my 9" PTC flashes 4400 been thinking about bumping it up 200-400 rpms. but I would never go that high
Re: ladder bar set-up ???? [Re: HardcoreB] #1295946
09/06/12 01:11 PM
09/06/12 01:11 PM
ohio
67mprfan Online content OP
67mprfan  Online Content OP
ohio
i dont know jack sh%$ but the way i see your setup, it looks like an endless instant center. that is the same suspension pro stocks used in the 70s and it worked. i would lower the top bar a hole, maybe raise the spring eye a hole and work with what you have before spending the money on changing it. your car is not really that fast plus you have a huge tire on the back. i dont think ladders would pick you up that much
Well I read the original post this AM and I was thinking the exact same thing!...EVERYTHING Sixpac said. You have some decent pieces in that motor and at 3000lbs with driver SOMETHING ELSE is wrong. If everything looks safe under the car e.g.- weld integrity etc...I would only put a good pair of shocks on it. Maybe D.A. Strange without the coilovers or even the adj Rancheros. That MPH reflects about flywheel 525 HP. I'd suggest some of the more frequent oversites;
1)Hoodscoop and/or sealing problem
2)Carb improperly adjusted
3)What sparkplugs and gap AND wires? AND ignition?
You'd be surprised how much ET/MPH you can loose from those 3 alone.
yeah there is not much room between hoodscoop and carb
plugs ngk-8s with taylor 8 wires msd 7al box
carb is 1050 no pv 96-98 jets
because it's been so hot really haven't play with tuning engine anymore hopefully i can now it's cooling off
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: ladder bar set-up ???? [Re: sixpackgut] #1295947
09/06/12 01:17 PM
09/06/12 01:17 PM
ohio
ohio
I'm looking at trying moving the bars around to see if it helps don't know if you can tell by the pics but 1 arm is at a different angle than the other so more t n t is definatly in my plans
Re: ladder bar set-up ???? [Re: 67mprfan] #1295948
09/06/12 01:46 PM
09/06/12 01:46 PM
OH
TheBlackCar Offline
TheBlackCar  Offline
OH
My Duster has a leaf-link in it, but it differs a bit from what you have there. My upper housing bracket has 2 holes and the front is a modified stock framerail. The car doesn't have near the tire you do and 60'd in the 1.36-1.38 range at Norwalk, 1.40 everywhere else with a tired ole motor at 3150#.
As mentioned, I would address some other things before changing the suspension.
Good Luck
Re: ladder bar set-up ???? [Re: 67mprfan] #1295949
09/06/12 01:47 PM
09/06/12 01:47 PM
I would move both of your attachments down one hole Do you know the intersecting points(instant center maybe) of the current set up? If not look up how to compute the instant center of your set up and calculate it BTW, I seem to remember the reason the old Pro racers got away from the ladder link rear suspension was that they where breaking the main leaf at the front spring eyes Not good Is your leaf spring mounts to the rear end housing a floater? It doesn't look like it is the reason I'm asking, I'm not even sure if it should be or not
Re: ladder bar set-up ???? [Re: Cab_Burge] #1295950
09/06/12 02:40 PM
09/06/12 02:40 PM
OH
TheBlackCar Offline
TheBlackCar  Offline
OH
Cab, the lower mount is a housing pivot, as it should be. And you are correct about the stress on the spring eye, make sure it is clamped and keep an eye on it.
Re: ladder bar set-up ???? [Re: Cab_Burge] #1295951
09/07/12 12:26 PM
09/07/12 12:26 PM
ohio
ohio
No does not look like it
was going to take the car out but they are calling for rain so guess i have to wait beside i didn't get a chance to put the other set of slicks on
Re: ladder bar set-up ???? [Re: TheBlackCar] #1295952
09/07/12 12:32 PM
09/07/12 12:32 PM
ohio
ohio
Good Luck
My plan is try a 950 with a 1in spacer to see how that helps if you can see the pic the 1050 sits pretty high in the scoop
a cam change is in the winter project plans for sure
