Re: SO whats the REAL numbers?? Your guess vs Happy Dyno [Re: firefighter3931] #1294735
09/01/12 06:32 PM
09/01/12 06:32 PM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
It was
TQ 566 at 5400
HP 609 at 5900
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: SO whats the REAL numbers?? Your guess vs Happy Dyno [Re: Kam*Kuda] #1294736
09/01/12 06:34 PM
09/01/12 06:34 PM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
I may likely try to run it as is and get on the track this year. There are still some more work to get the procharger together.
I was expecting about 550hp
Re: SO whats the REAL numbers?? Your guess vs Happy Dyno [Re: Kam*Kuda] #1294737
09/01/12 06:47 PM
09/01/12 06:47 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
That would be great. Then we could bring this discussion full circle to a reality check. Of course, that is easy for me to say
Re: SO whats the REAL numbers?? Your guess vs Happy Dyno [Re: BSB67] #1294738
09/01/12 10:22 PM
09/01/12 10:22 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
609 hp not bad at all for the combo being N/A. What is the weight of the car its going in ? Ron
Re: SO whats the REAL numbers?? Your guess vs Happy Dyno [Re: 383man] #1294739
09/02/12 12:01 PM
09/02/12 12:01 PM
Shannonville, Ont
Blown 68 R/T Offline
Shannonville, Ont
Hey, No Firecores?WTF
Sparky's not going to like that!
Good #'s Kam Kamino
Should wake that B Body up once you have that Procharger installed.
I still have to get mine sorted out.
Re: SO whats the REAL numbers?? Your guess vs Happy Dyno [Re: Blown 68 R/T] #1294740
09/02/12 10:53 PM
09/02/12 10:53 PM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
The firecores wouldn't fit with the dyno headers They had to use some shop wires. Maybe the HP will go up now
1654.5 Mustang
1955 Land Rover
Re: SO whats the REAL numbers?? Your guess vs Happy Dyno [Re: Kam*Kuda] #1294741
09/03/12 09:42 PM
09/03/12 09:42 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
You are off my Christmas list, Rob. Great numkbers. How about happy customer, and real happy customer.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: SO whats the REAL numbers?? Your guess vs Happy Dyno [Re: Kam*Kuda] #1294742
09/11/12 10:31 PM
09/11/12 10:31 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
glad you got it running and had no issues
as for the "happy dyno" part.....
based on the BSFC numbers and fuel flow, it was making around 513hp uncorrected.
and the sheet shows an almost 15% correction factor.....which really seems a bit too high to me.
the sheet also shows a baro press of 29.8, so its doesnt seem like the dyno is located at a place where the elevation is real high.
i dont see why the correction would be nearly 15%.
i dont know if ive ever even seen 10% down here.
its usually between like 2.5% and 7.5%.
assuming you ran it down here, and it made the same 513hp uncorrected(in similar air as to what you had up there), and that day happened to be as bad as a 7.5% day........the corrected numbers would have been just over 550hp.....which is really more like what i would have expected.
EDIT- after crunching some of the numbers off that sheet.....they dont really work out correctly.
236.1lbs/hr of fuel, and a BSFC of .46 works out to 513.26hp.
however, 513.2 X C/F of 1.148 only comes out to 589.1....not 609.
609/ 1.148 is 530.4, not 513.2
236.1/530.4= .445.....not .46
so.....not a lot from that sheet makes much sense to me.
sometimes the decimal isnt carried out far enough on the BSFC number, which will skew the results a couple of HP......but not like the 15-20 i'm seeing here.
this is just an example of why the only dyno numbers i really care about are the ones i get myself.
Re: SO whats the REAL numbers?? Your guess vs Happy Dyno [Re: fast68plymouth] #1294743
09/12/12 12:20 AM
09/12/12 12:20 AM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
As Dwayne mentioned,a few things don't add up,but I also look at bsfc numbers and fuel flow numbers as a comparison from engine to engine.
Those numbers are based onl flow through flow meters that may not be properly calibrated . It is like comparing different flow benches.
The main problem I see is the correction factor changing that much over a short period makes me think there is a ventilation problem in the cell.
I like to see what other people get on their dyno,but like Dwayne,it is easier to trust one you know.
Is that a Mopar orange box ignition on there?
Re: SO whats the REAL numbers?? Your guess vs Happy Dyno [Re: Dunnuck Racing] #1294744
09/12/12 12:34 AM
09/12/12 12:34 AM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
Thanks It always seemed to be overly inflated numbers from that dyno.
Thanks for the thoughts Dwayne. That helps make some sense.
Dunnuck
We were chasing some ignition issues. It turned out to be the pin that holds the reluctor fell out and the reluctor was spinning on the shaft and the timing went CrAZY.
In the process we had tried an orange box in case the MSD box was a miss
1654.5 Mustang
1955 Land Rover
Re: SO whats the REAL numbers?? Your guess vs Happy Dyno [Re: Dunnuck Racing] #1294745
09/17/12 11:31 PM
09/17/12 11:31 PM
So. Burlington, Vt.
So. Burlington, Vt.
thats true, which is part of why i dont consider results from different dynos as necessarily able to be compared as truely "apples to apples".
however, the data aquisition software doesnt know if the flow meter calibration is accurate or not.
its just using the input from the sensor and doing the math to spit out the BSFC or BSAC number.
so, regardless of whether the flow meters are accurate or not, the math should always work out.
i have no personal experience with Depac data aquisition, but i wouldnt be surprised if there was some temperature/density correction for the fuel that doesnt show up on the sheet, but is part of their equation.
Rob, do you have a sheet with the uncorrected TQ and HP??
Re: SO whats the REAL numbers?? Your guess vs Happy Dyno [Re: fast68plymouth] #1294746
09/18/12 04:44 PM
09/18/12 04:44 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
i see the inertia factor was .40. we use .32 at my dyno shop. the higher the if, the higher the horsepower reads......
Re: SO whats the REAL numbers?? Your guess vs Happy Dyno [Re: Old School] #1294747
09/18/12 05:50 PM
09/18/12 05:50 PM
Northern Indiana
Northern Indiana
Dwayne,
I understand what you are pointing out,my thought was that if the flow meter is off,bsfc is off.
You can also enter the wrong specific gravity of the fuel and it will change the bsfc numbers.
As far as the depac goes,it had been sold in many versions for many dyno models. Some use temperature compensation,etc.for adjusting values and some did not. Dependent on how the dyno was equipped.
I usually graph corrected results against uncorrected to see if something odd jumps out at me.
Keith
Re: SO whats the REAL numbers?? Your guess vs Happy Dyno [Re: Old School] #1294748
09/18/12 06:03 PM
09/18/12 06:03 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
Can you still dyno a engine if the brake is not working right? We passed on a engine last week because we over heard the helpers fussing about it being useless to put the engine on the dyno when the brake was not right.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
