Re: Drum to disc conversion on 70 E-Body with Hotchkis TVS
[Re: AndyF]
#1292626
08/31/12 10:09 AM
08/31/12 10:09 AM
Posts: 403 30 miles west of EuroDisney
fbernard
Too late for you
Considering I have a car with absolutely no E-brake or parking brake (could be worse, it's a stick car, I always park in gear), it may not be too late, I'll have to address this problem eventually. I've toyed with other ideas (retaining the Wilwood calipers, fabbing up brackets, getting rid of all the aluminum bracket/backing-plate/drum brake arrangement, and finding another parking brake solution (little mechanical calipers with small puck-like pads). I have a feeling starting from scratch might be easier.
By the way, does anyone make a sort of spanner wrench for the bearing adjustment?
[Re: AndyF]
#1292627
08/31/12 11:46 AM
08/31/12 11:46 AM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
Thanks Andy... every fraction of an inch matters for my setup.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: pro451bee]
#1292628
08/31/12 11:59 AM
08/31/12 11:59 AM
Mopar Mitch
Thanks pro451 for the info on the Baer Iron Sport setup.
Mopar Mitch
[Re: Mopar Mitch]
#1292630
08/31/12 12:57 PM
08/31/12 12:57 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
If it is that small amount (and going to make a difference), you could always have the mounting pads of the wheels cut that much to even things back up.
Usually enough meat on them to skim some off if needed.
