Maximum 1969 Dodge Charger tire size with 15 inch wheel #1290912
08/24/12 10:28 PM
08/24/12 10:28 PM
Arizona
az426john Offline OP
Arizona
What is the largest tire size that will reasonably fit a stock ride height 1969 Dodge Charger with 15 inch stock mopar wheels.
Re: Maximum 1969 Dodge Charger tire size with 15 inch wheel [Re: az426john] #1290913
08/24/12 10:45 PM
08/24/12 10:45 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
15x7 275/60/15 15x6 235/70/15
Coming soon!!!!
Re: Maximum 1969 Dodge Charger tire size with 15 inch wheel [Re: Mr.Yuck] #1290914
08/25/12 01:22 AM
08/25/12 01:22 AM
Ashville, Manitoba, Canada
superbeeman69 Offline
super street
super street
Won't a 15x8 steel wheel with 4.5 inch BS fit with a 275/60/15 tire?
1970 FM3 Coronet 440, 1971 FJ6 Dude D100
Re: Maximum 1969 Dodge Charger tire size with 15 inch wheel [Re: superbeeman69] #1290915
08/25/12 09:03 AM
08/25/12 09:03 AM
Crofton, Ky.
rattler Offline
rattler  Offline
Crofton, Ky.
I just put 15x8's on my GTX. 245x60's on the front and 255x60's on the rear.
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
Re: Maximum 1969 Dodge Charger tire size with 15 inch wheel [Re: rattler] #1290916
08/25/12 02:08 PM
08/25/12 02:08 PM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
I have 15x8.5s on the back with 275 60R15s and once in a while it'll rub on the right side. Fronts are 15x6 with 215s, so no issues there.
Re: Maximum 1969 Dodge Charger tire size with 15 inch wheel [Re: pinkduster] #1290917
08/25/12 02:31 PM
08/25/12 02:31 PM
Arizona
Arizona
Thanks for your replies. It will save a lot of time, trial & error.
John
Re: Maximum 1969 Dodge Charger tire size with 15 inch wheel [Re: pinkduster] #1290918
08/25/12 03:22 PM
08/25/12 03:22 PM
super street
super street
What is your back spacing? I know 4.5inch is close...would a 15x8 with a 4 inch back space work?
Re: Maximum 1969 Dodge Charger tire size with 15 inch wheel [Re: superbeeman69] #1290919
08/25/12 03:48 PM
08/25/12 03:48 PM
Birmingham, England
Mick70RR Offline
Mick70RR  Offline
Birmingham, England
10" with 5 1/2" backspace on the back of my Road Runner. Tyres are 275 60R15. I would guess these would fit a Charger easily because the wheel well looks wider.
1970 Road Runner 505 cid MCH CNC ported Stealth heads MP 528 camshaft 4 speed GV overdrive 11.98 @ 117 on street treads
Re: Maximum 1969 Dodge Charger tire size with 15 inch wheel [Re: Mick70RR] #1290920
08/25/12 04:06 PM
08/25/12 04:06 PM
super street
super street
Is your suspension preloaded in this picture? Or at normal ride height? I ask because your 15x10s don't look that far up in the wheel well. Looks like Caltrac suspension too...how do you like it?
Re: Maximum 1969 Dodge Charger tire size with 15 inch wheel [Re: superbeeman69] #1290921
08/25/12 04:18 PM
08/25/12 04:18 PM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
I just ordered standard back spacing wheels from Newstalgia Wheel. It is 3.75. You could easily go with 4 inch back spacing, but I don't know if that's a custom order or not. My once in while rub problem probably has more to do with the 43 year old 243,000 mile springs. Also, my Charger's rear is really off to the right from the factory. Often wondered why they did that.
Re: Maximum 1969 Dodge Charger tire size with 15 inch wheel [Re: superbeeman69] #1290922
08/25/12 04:20 PM
08/25/12 04:20 PM
Birmingham, England
Mick70RR Offline
Mick70RR  Offline
Birmingham, England
I think the picture was taken just as I launched off the line. The rear fender is normally a few inches below the top of the tyre. I'm not a serious racer, the Caltracs were a slight improvement. I now run them on the top hole, back them off so they don't bang on the street and don't adjust them at the track. Since the picture was taken I have also stopped using drag radials because they were only lasting a few thousand street miles and cost too much to import. My best times have been run on every day street tyres.
Re: Maximum 1969 Dodge Charger tire size with 15 inch wheel [Re: Mick70RR] #1290923
08/25/12 07:11 PM
08/25/12 07:11 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
These are Cragar 500Series Eliminator 15x8's (all 4) with 4.5" back spacing
Mickey Thompson Sportsman S/T 245/60/15 front & 295/50/15 rear
Fit with zero issues
1MYTGTX
Re: Maximum 1969 Dodge Charger tire size with 15 inch wheel [Re: 1MYTGTX] #1290924
08/25/12 07:12 PM
08/25/12 07:12 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
nudder
1MYTGTX
