Re: Bodyman needs Engine Advice
[Re: DaytonaTurbo]
#1289358
08/23/12 01:50 PM
08/23/12 01:50 PM
Posts: 75,326 A gulag near you.
JohnRR
A gulag near you.
For what he's doing, I think he would be better off finding a used edelbrock ch4b intake. With stock heads and low CR, the holley street dominator is less than ideal.
[Re: 70VERT]
#1289362
08/23/12 08:19 PM
08/23/12 08:19 PM
RapidRobert
Yes there's been enough reported problems with the newer orange boxes (plus it's pricey) that I would highly suggest going elsewhere. Even tho there's many ways/options to go, a generic parts house ECU will get you up and running cheaply with more than enough ign power for now. The rest of your choices look good however I would mockup and check lifter preload before I committed to a particular pushrod length. I'd sure be nice if you could get some 915 closed chambered heads for the CR boost & even with slight milling (maybe a .030" truing cut) your pushrods (preload) may be good as is plus you could use the shortblock as is as opposed to boring/honing (& possibly balancing)for new pistons. Minimize the downtime.
