Re: SWOLLEN OIL FILTER
[Re: MR_P_BODY]
#1288864
08/22/12 11:53 PM
08/22/12 11:53 PM
Posts: 1,062 Amherst,NY
challengermike
Amherst,NY
I have no issue , Run @ 85-90# pressure,, sounds as if it just bad filter?? but,,IDONO,, I run Fram so?? go figure!!
I would think he had pressures in the range of 110-115 at high RPM
Mine happened at idle, but it was caused by someone shimming the spring. Im sure the engine it came off of must of had no bearings left to need it shimmed that much.
