Page 3 of 10 1 2 3 4 5 9 10
Re: Red Light Bandit 70 Challenger Indy debut Build Pics [Re: AMXDuster] #1288453
08/21/12 12:55 AM
08/21/12 12:55 AM
New Lenox, IL
AMXDuster Offline OP
New Lenox, IL
Dismantling the car exposed some of the tricks of the day to make the car light, but still strong.
Re: Red Light Bandit 70 Challenger Indy debut Build Pics [Re: AMXDuster] #1288454
08/21/12 01:01 AM
08/21/12 01:01 AM
New Lenox, IL
New Lenox, IL
More holes nicely aligned. Bagshaw is a perfectionist, so even if it would not be visible, it had to be done right.
Re: Red Light Bandit 70 Challenger Indy debut Build Pics [Re: AMXDuster] #1288455
08/21/12 01:15 AM
08/21/12 01:15 AM
New Lenox, IL
New Lenox, IL
The Ron Butler fabricated panels covering the cowl were carefully removed by Bucky and Cole so they could be cleaned up and re-installed. Once removed, more weight reduction artistry was revealed.
Re: Red Light Bandit 70 Challenger Indy debut Build Pics [Re: AMXDuster] #1288456
08/21/12 01:17 AM
08/21/12 01:17 AM
New Lenox, IL
New Lenox, IL
Another angle for instruction in Pro Stock construction circa 1970.
Re: Red Light Bandit 70 Challenger Indy debut Build Pics [Re: AMXDuster] #1288457
08/21/12 01:18 AM
08/21/12 01:18 AM
currently on moparts.
Race&Resto Offline
Race&Resto  Offline
They must have wore out few hole saw blades building it back then, so where was this one sitting all these years, sure will be a nice one once it's finished.
Re: Red Light Bandit 70 Challenger Indy debut Build Pics [Re: Race&Resto] #1288458
08/21/12 01:27 AM
08/21/12 01:27 AM
New Lenox, IL
New Lenox, IL
Lots of saw blades, no doubt. Side pic of car in process.
Re: Red Light Bandit 70 Challenger Indy debut Build Pics [Re: AMXDuster] #1288459
08/21/12 07:01 AM
08/21/12 07:01 AM
Mo.
racerx Offline
racerx  Offline
Mo.
So how fast was this car back in it's day?
Re: Red Light Bandit 70 Challenger Indy debut Build Pics [Re: racerx] #1288460
08/21/12 10:29 AM
08/21/12 10:29 AM
New Lenox, IL
New Lenox, IL
Racerx
Good question. I'm sure you know that Grumpy Jenkins had the first nine second Pro Stock run, a 9.98 at the 1970 Winternationals. Bagshaw's car was eventually in that range, and by the time the car was sold in 1974, Bagshaw reports that the car was running 9.20's at 145 mph.
Since we're talking horsepower, we were thrilled when Bagshaw agreed to do the rebuild on the Hemi motor that would go in the car. Bagshaw is longtime friends with Ron Shaver, owner of Shaver Specialties Racing Engines in Torrance, CA. Ron gladly offered Bill a space at his shop to build this motor. Bagshaw did an outstanding job putting it together with mostly period correct parts. Note Krylon "Cherry Red" engine block, as used by Bagshaw in 1970.
Re: Red Light Bandit 70 Challenger Indy debut Build Pics [Re: AMXDuster] #1288461
08/21/12 10:31 AM
08/21/12 10:31 AM
O-H-I-O
sixpackjeff Offline
sixpackjeff  Offline
O-H-I-O
Very cool!
Re: Red Light Bandit 70 Challenger Indy debut Build Pics [Re: AMXDuster] #1288462
08/21/12 10:35 AM
08/21/12 10:35 AM
New Lenox, IL
New Lenox, IL
At Shaver Specialties Racing Engines, the Bagshaw-built 426 engine was installed on the dyno. After some break in runs and a couple days of tuning, the motor produced 679 horsepower at 7800 rpm.
Re: Red Light Bandit 70 Challenger Indy debut Build Pics [Re: AMXDuster] #1288463
08/21/12 10:45 AM
08/21/12 10:45 AM
New Lenox, IL
New Lenox, IL
Finished Red Light Bandit 426 Hemi engine, complete with Holley carbs found by Moparts legendary HemiFred. The carbs were then sent to Holley, and restored to new condition. Bagshaw then contacted Ron Butler and asked him to duplicate the trick carb linkage that they used back in 1970. To our delight, Butler agreed to make the linkage, and even by today's standards, it still looks state of the art.
Re: Red Light Bandit 70 Challenger Indy debut Build Pics [Re: AMXDuster] #1288464
08/21/12 04:34 PM
08/21/12 04:34 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
What a great car to restore. I've heard Bill has intense notes from every car he raced. I would image this car has nearly unmatched ability to document and recreate the car to a specific time point.
Troy here worked for Bill for years at Pro Parts. IIRC, there were specific instructions on how to sweep the floors!
Re: Red Light Bandit 70 Challenger Indy debut Build Pics [Re: autoxcuda] #1288465
08/21/12 05:01 PM
08/21/12 05:01 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Sounds like my Dad, He was in floor covering and that man would chew my azz if I "swept up dust" rather than sweep the floor...
Re: Red Light Bandit 70 Challenger Indy debut Build Pics [Re: Moparnut426] #1288466
08/22/12 07:45 AM
08/22/12 07:45 AM
New Lenox, IL
New Lenox, IL
Not surprised about Bagshaw's instructions on sweeping, he definitely likes things done right. That's why his race cars were so impeccable.
Back to build pics... still checking out dismantled shell with floor work done, Bucky is showing present owner of the RLB, John Gastman, sections of floor that had to be trimmed to work around cage. The idea was to leave Ron Butler's work undisturbed.
Re: Red Light Bandit 70 Challenger Indy debut Build Pics [Re: AMXDuster] #1288467
08/22/12 07:55 AM
08/22/12 07:55 AM
New Lenox, IL
New Lenox, IL
Speaking of the work of Ron Butler, here's a quick pic of the engine compartment panels from the original car that have been cleaned and stripped.
Re: Red Light Bandit 70 Challenger Indy debut Build Pics [Re: AMXDuster] #1288468
08/22/12 07:58 AM
08/22/12 07:58 AM
New Lenox, IL
New Lenox, IL
A lot of time was spent looking at pics of the car in its original state, and making sure to return it to period correct status. Left to right, Bucky, Cole (fabricator), and present owner John Gastman.
Re: Red Light Bandit 70 Challenger Indy debut Build Pics [Re: AMXDuster] #1288469
08/22/12 08:03 AM
08/22/12 08:03 AM
New Lenox, IL
New Lenox, IL
Cowl panel set on the car, not yet installed.
Re: Red Light Bandit 70 Challenger Indy debut Build Pics [Re: AMXDuster] #1288470
08/22/12 08:05 AM
08/22/12 08:05 AM
New Lenox, IL
New Lenox, IL
Ron Butler inner fender panel, stripped, set on the car, not installed.
Re: Red Light Bandit 70 Challenger Indy debut Build Pics [Re: AMXDuster] #1288471
08/22/12 08:08 AM
08/22/12 08:08 AM
New Lenox, IL
New Lenox, IL
Butler cage front bar, cleaned up.
Re: Red Light Bandit 70 Challenger Indy debut Build Pics [Re: AMXDuster] #1288472
08/22/12 08:16 AM
08/22/12 08:16 AM
New Lenox, IL
New Lenox, IL
We left Bucky's shop, but not without a quick look at his SS/AH race car. We are big Bucky fans, and certainly wanted to see Bucky spend time getting ready to race. Bucky ended up having to sacrifice testing time on his race car in order to complete the Red Light Bandit, and it was much appreciated.
