Re: 727 won't kickdown into passing gear..adjustment help..
[Re: John_Kunkel]
#1288093
09/07/12 08:05 PM
09/07/12 08:05 PM
Posts: 1,679 Mansfield,Ohio
moparrulzzz
Mansfield,Ohio
Be sure that WOT at the pedal is WOT under the hood; a misadjusted throttle cable will prevent the carb from going wide open.
Have somebody sit in the car and mat the pedal then see if you can push the carb/linkage back some more.
That was the 1st thing I checked John. WOT in car (floored) is also WOT throttle on carb
[Re: moparrulzzz]
#1288094
09/07/12 11:09 PM
09/07/12 11:09 PM
moparrulzzz
Mansfield,Ohio
Just reverified WOT when put to the mat. Can anyone advise me if I should drive it or not??
[Re: moparrulzzz]
#1288095
09/08/12 01:06 PM
09/08/12 01:06 PM
Posts: 21,555 N.E. OHIO, USA
A12
N.E. OHIO, USA
I had no problems driving mine when it was not down shifting by the throttle pedal for over a year, just used the lever and pulled it into 2nd or low when I needed it to downshift. Now that I'm thinking about it with the original governor it would downshift even with the lever if I was above a certain rpm or speed but would with the higher shift point "Hemi" governor hmmmmmmmmmmmmmm but no problems driving it like that from my experience. (you can change the governor with the trans in the car btw)
[Re: moparrulzzz]
#1288096
09/08/12 01:49 PM
09/08/12 01:49 PM
Posts: 26,046 Rio Linda, CA
John_Kunkel
Rio Linda, CA
You're not going to hurt the trans.
One more thing to check, disconnect the linkage from the top lever on the trans and operate the lever by hand...pull the lever firmly against the forward stop and make sure it has a nice firm stop then push it to the rear firmly against its stop and see if both directions have a nice firm stop.
In some rare cases the weld that holds the throttle lever shaft to the cam will break and allow the shaft to spin in the cam.
[Re: John_Kunkel]
#1288098
09/09/12 01:35 PM
09/09/12 01:35 PM
moparrulzzz
Mansfield,Ohio
Nice and firm stop both directions
Re: 727 won't kickdown into passing gear....update...
[Re: moparrulzzz]
#1288100
09/09/12 05:58 PM
09/09/12 05:58 PM
John_Kunkel
Rio Linda, CA
PTK has nothing to do with WOT kickdown.
[Re: ChargerCrazed]
#1288102
09/10/12 03:26 PM
09/10/12 03:26 PM
John_Kunkel
Rio Linda, CA
Nonsense, EVERY correctly operating Torqueflite (including the old iron ones) will kick down to 2nd at WOT. The reason it's called "part" throttle kickdown is because those transmissions equipped with it will kick down at less than WOT (part throttle).
