Re: tranny help please [Re: Greg Ducato] #1287640
08/20/12 10:40 AM
08/20/12 10:40 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
line pressure restrictions will cause a similar noise.
ck the cooler lines for a kink or bend .
I hate to say it but my guts says ft pump or torque conv failer is in your future.
Re: tranny help please [Re: John_Kunkel] #1287641
08/20/12 10:44 AM
08/20/12 10:44 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
no thoughts?
I have one...learn how too use the space bar.
It's TO... not TOO As in, "learn how to spell"
Re: tranny help please [Re: DAYCLONA] #1287642
08/21/12 08:32 PM
08/21/12 08:32 PM
Canada's West Coast
Graham Offline
Graham  Offline
Canada's West Coast
If it's the pump that is whining it could be that the filter is clogged as has been previously mentioned.
I think your easist check is to drop the pan and see if the filter is plugged up and if it is, what is the debris from.
Re: tranny help please [Re: meepmeep70] #1287643
08/30/12 10:56 AM
08/30/12 10:56 AM
weymouth,mass.
meepmeep70 Offline OP
weymouth,mass.
WELL,for the people who suggested converter,bingo,pulled old(fresh rebuild) tranny,then pulled converter,and the converter has broken up,taking the shaft with it. Know i had a problem with the tranny,i ordered a new one from John Cope racing(see my good guy alert post),and installing that,the old one is also being redone and will go on the shelf for back upthank you for all the folks who helped me,as usual moparts is awesome
Re: tranny help please [Re: meepmeep70] #1287644
08/30/12 10:59 AM
08/30/12 10:59 AM
weymouth,mass.
weymouth,mass.
shaft
Re: tranny help please [Re: meepmeep70] #1287645
08/30/12 11:05 AM
08/30/12 11:05 AM
scratchnfotraction Offline
yep,those are used parts now.
Re: tranny help please [Re: meepmeep70] #1287646
08/30/12 11:07 AM
08/30/12 11:07 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Wow , that bites Darren I hope you flushed the cooler circuit real good before installing the Cope trans. Any idea how that happened ? What convertor was it ?
Re: tranny help please [Re: JohnRR] #1287647
08/30/12 04:25 PM
08/30/12 04:25 PM
weymouth,mass.
weymouth,mass.
was A B&M converter,new less then a couple hundred miles,got on it just to pass a car turning right,nothing extreme and i heard a loud whizzing noise,cope tranny will be installed tomorrow morning (took the day off) and thanks john i will flush the lines
Re: tranny help please [Re: meepmeep70] #1287648
08/30/12 04:47 PM
08/30/12 04:47 PM
I guess thats the difference between a 4 pac and a 6 pac.
Re: tranny help please [Re: meepmeep70] #1287649
08/30/12 05:40 PM
08/30/12 05:40 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I'd be tempted to send a thank you Turd to B&M...
Re: tranny help please [Re: 1_WILD_RT] #1287650
08/30/12 06:23 PM
08/30/12 06:23 PM
weymouth,mass.
weymouth,mass.
Randy,B&M will get a big thanks for nothing,as most of us understand,converter is 3 yrs old,BUT was installed with the drive train after engine bay painted,then rolled around the garage to do the body work then paint,then assembly,so it has only a couple hundred miles,but being 3yrs old,pretty sure B&M could care less,none the less they will here my
