Re: PROJECT GAS SIPPER 67 Plymouth Valiant [Re: magnum440d100] #1286205
06/23/13 01:26 AM
06/23/13 01:26 AM
woodcrest, CA
magnum440d100 Offline OP
woodcrest, CA
Another of the old passenger side, next to the new one. I am holding the old one together for picture purposes
Re: PROJECT GAS SIPPER 67 Plymouth Valiant [Re: magnum440d100] #1286206
06/23/13 01:38 AM
06/23/13 01:38 AM
woodcrest, CA
woodcrest, CA
New one installed. No more distributor resting on fender
We think when the motor mount went, it caused the distributor to get knocked out of time. I ran out of time (no pun intended) to try and start her tonight.
Re: PROJECT GAS SIPPER 67 Plymouth Valiant [Re: magnum440d100] #1286207
06/23/13 01:41 AM
06/23/13 01:41 AM
woodcrest, CA
woodcrest, CA
Drivers side. No pics of it installed. Got too late
Re: PROJECT GAS SIPPER 67 Plymouth Valiant [Re: magnum440d100] #1286208
06/23/13 02:33 AM
06/23/13 02:33 AM
Florida STAYcation
dOc ! Online penguin-006
The village idiot's idiot
dOc !  Online Penguin-006
Florida STAYcation
....and your MPG goal is going to be ?......
Re: PROJECT GAS SIPPER 67 Plymouth Valiant [Re: dOc !] #1286209
06/23/13 02:35 AM
06/23/13 02:35 AM
woodcrest, CA
woodcrest, CA
Hoping to get close to 30 MPG's. My buddy tim is trying to talk me into fuel injection. We shall see haha
Re: PROJECT GAS SIPPER 67 Plymouth Valiant [Re: magnum440d100] #1286210
06/23/13 02:38 AM
06/23/13 02:38 AM
Florida STAYcation
Florida STAYcation
YOU will need one of my ONE HALF a THERMOquad conversions !
.....and take a guess at what the BEST MPG I have ever heard of on a /6 A-body stick shift car ....
Re: PROJECT GAS SIPPER 67 Plymouth Valiant [Re: dOc !] #1286211
06/24/13 12:30 AM
06/24/13 12:30 AM
woodcrest, CA
woodcrest, CA
She runs
So after fiddling around a bit, turns out I was a tooth off on the timing set. Pulled the cover off, re did the timing, put new points and a newer coil on, and she fired
Of course we had previously pulled the plugs, oiled the cylinders, and hand cranked her over a few times.
She fired up, and was firing on all 6 cylinders. There was a light thump/tap that my buddy says could be a main.
NO smoke though
So now I am going to buy stuff to finish the front of the motor (water pump, thermostat and housing, belts/hoses) reason being, is now it'll be able to be moved around the shop under its own power assuming the trans is any good.
But I have a lead on a 225 that supposedly runs great and come with a working 904 that's going to get gone through and dropped in. But for now, it runs for the first time in 10+ years
Re: PROJECT GAS SIPPER 67 Plymouth Valiant [Re: magnum440d100] #1286212
06/24/13 01:22 AM
06/24/13 01:22 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Definately is a 170...but what does the DW stand for?
D - Series (model year) 1968
W - Windsor engine assembly plant
170 - 170 CU displacement
2239 - Engine final assembly date from the 10,000 day calendar - Sept 14, 1967 (1968 model year)
0332 - 332nd engine assembled at the plant above on the date above.
Re: PROJECT GAS SIPPER 67 Plymouth Valiant [Re: Alaskan_TA] #1286213
06/24/13 01:26 AM
06/24/13 01:26 AM
woodcrest, CA
woodcrest, CA
Cool. Thanks
Now, would this motor be original to the car? Hood, fender, and some interior were from a 68 or 69. Could they have put the motor in there too?
Re: PROJECT GAS SIPPER 67 Plymouth Valiant [Re: magnum440d100] #1286214
06/24/13 01:33 AM
06/24/13 01:33 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Since the car is a 1967 model then yes, someone swapped the engine.
Re: PROJECT GAS SIPPER 67 Plymouth Valiant [Re: magnum440d100] #1286215
06/24/13 01:14 PM
06/24/13 01:14 PM
woodcrest, CA
woodcrest, CA
Time to post some pics of getting her running.
Here is a comparison of the old points and the newer (new never installed) blue streak points. Not sure if the old points should look like that where the lobe rides haha
Re: PROJECT GAS SIPPER 67 Plymouth Valiant [Re: magnum440d100] #1286216
06/24/13 01:17 PM
06/24/13 01:17 PM
woodcrest, CA
woodcrest, CA
So not only were the points not opening enough, and not adjustable enough to get proper gap, they looked like they had been there since 67.
Re: PROJECT GAS SIPPER 67 Plymouth Valiant [Re: magnum440d100] #1286217
06/24/13 01:23 PM
06/24/13 01:23 PM
woodcrest, CA
woodcrest, CA
As compared to the new one. Supposedly, this lady drove this car into the junkyard where my friend Dennis bought it from. She supposedly drove it every day with the broken motor mounts, spark plug wires rubbed through onto the shock tower, and who knows what else. The points tell a different story though. No way this car ran with those old points.
Re: PROJECT GAS SIPPER 67 Plymouth Valiant [Re: Alaskan_TA] #1286218
06/24/13 01:29 PM
06/24/13 01:29 PM
woodcrest, CA
woodcrest, CA
I figured as much. Well, since its not original, might as well get that 225 and drop her in. Just gotta get this car going good enough to move around the shop, and if code enforcement comes along, at least it starts.
I still hear a 440 calling my name for this car, but not the intentions I have for this car haha
