What is this????? #1285891
08/15/12 07:36 PM
08/15/12 07:36 PM
El Dorado Ca
65signet Offline OP
65signet  Offline OP
El Dorado Ca
Does anybody know what type of posi or locker this is. I have not seen this one
1965 Plymouth Barracuda 273 M/SA
1970 Plymouth Duster 360/904 10.60s with J heads
Re: What is this????? [Re: 65signet] #1285892
08/15/12 07:49 PM
08/15/12 07:49 PM
Cab_Burge Online work
Cab_Burge  Online Work
How about Mini Spool
Re: What is this????? [Re: Cab_Burge] #1285893
08/15/12 08:26 PM
08/15/12 08:26 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Thats right ! a lot of dirt track guys run them. Not sure how well they would hold up drag racing. I have put 4-5 of them in dirt cars.
Re: What is this????? [Re: VernMotor] #1285894
08/15/12 08:41 PM
08/15/12 08:41 PM
El Dorado Ca
65signet Offline OP
65signet  Offline OP
El Dorado Ca
So no good for drag racing then!!!!!
Re: What is this????? [Re: 65signet] #1285895
08/15/12 10:47 PM
08/15/12 10:47 PM
maryland
buck440 Offline
buck440  Offline
maryland
i ran one in my 67 charger for years street an strip no problems
Re: What is this????? [Re: buck440] #1285896
08/16/12 11:04 AM
08/16/12 11:04 AM
Central California
MoParFish Offline
MoParFish  Offline
Central California
Yep, it's a mini spool. We ran one years ago never a problem...
Sworn Member Central Valley MoPar Drag Pack. You can reach me at (done-et-chasing@going-rounds.gone)... :-)
[img]https://s6.postimg.org/v3mbggksx/SAC16.jpg[/img]image hosting more than 5mb
Re: What is this????? [Re: MoParFish] #1285897
08/16/12 12:25 PM
08/16/12 12:25 PM
Tucson AZ.
RADAMX Offline
RADAMX  Offline
Tucson AZ.
As with any spool you should have aftermaket axles.
The real disadvantage with a mini spool over a real spool is weight.
The advantage is you don't have to set up the gears again.
Cost for the part is less then a real spool but not by that much.
Re: What is this????? [Re: RADAMX] #1285898
08/16/12 02:48 PM
08/16/12 02:48 PM
El Dorado Ca
65signet Offline OP
65signet  Offline OP
El Dorado Ca
