Re: Another Whats the HP
[Re: gregsdart]
#1284945
08/17/12 09:26 AM
08/17/12 09:26 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Sorry to hear about this, Mike. Hope it isn't serious ![](/ubbthreads/images/graemlins/frown.gif) I am sure you will post results, and many will learn from it.
Thanks guys... I'm thinking it has to be a rod bearing but I didnt feel any bad... but to loose 100#tq it has to be something at a distance from the C/L.. I'll pick it up this morning and get it on the stand ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1284946
08/17/12 04:06 PM
08/17/12 04:06 PM
MR_P_BODY
The only thing I see is where some dirt/debris on a couple of piston skirts scratched the bores.. 2 have a pretty good scratch .... all the bearings looked fine... so I still dont know where all this alum partials came from ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1284948
08/17/12 05:21 PM
08/17/12 05:21 PM
Posts: 20,673 in a cattle trailer down by th...
Guitar Jones
Check those pushrods Mike.
[Re: Labratt]
#1284952
08/17/12 10:18 PM
08/17/12 10:18 PM
MR_P_BODY
Mike..what about the cam bearings? Hard to believe it wasn't one of the rods! All the main bearings were OK as well? Please let us know as soon as you find the "culprit"! Losing 100 ft. lbs....it has to be something that sticks out like a sore thumb! Keeping my fingers crossed!
I had Larry stop by to take a look at it... he said the scuffed walls would eat the torque but he is stumped as to where the material came from... cam bearings looked fine, pushrods were fine, dist bushing is fine... one of the main bearings has a line in it that he said looked weird so he is gonna stop by with his bore gauge to see if that one main is ok but thats the only thing he sees but he has no idea where the crap/alum came from... neither do I... like someone went into the shop and dumped alum in it ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1284953
08/17/12 10:38 PM
08/17/12 10:38 PM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
I would now think it's the carb. ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) Power went down after messing with the carb.. Try a different one. You already washed the rings out with it once. Maybe it did it again. ![](/ubbthreads/images/graemlins/Twocents.gif) As far as the metal.. Maybe you just missed something in cleaning.. ![](/ubbthreads/images/graemlins/blush.gif) I've done that before. Chris..
[Re: Chris'sBarracuda]
#1284954
08/17/12 10:57 PM
08/17/12 10:57 PM
MR_P_BODY
Chris..
I washed that block 3 times before I assembled it
I can say that St. Clair treated me right when it came to price when I picked up the engine.... IF I ever get this thing right it'll go back there to the dyno ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Labratt]
#1284956
08/18/12 01:31 AM
08/18/12 01:31 AM
MR_P_BODY
Mike,glad Larry took care of you! They are good people,for sure! Hard to believe you haven't found anything that stands out from the norm! Keep us informed if you find out anything!
Larry didnt have a clue where that alum came from and I really dont know either.... it was in the pan and the filter so it had to start from in the pan but it was in the bearings also... so that would mean it was in the oil gallies also or it got through the filter(which I doubt).... I cleaned that block 3 times before I started assembly so I dont know... looks like I'll order up new main and rod bearings and do a hone then clean it AGAIN and try 1 last time... I think I'll pull the heads apart to check them real close and clean them... thats all I can think of... I have 2 more 340 blocks that are bored but I would have to have either of them decked to my set up but that will be my last resort.... still think I should have done a WOT run.... that would have found the problem ![](/ubbthreads/images/graemlins/flame.gif) ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1284957
08/18/12 08:43 AM
08/18/12 08:43 AM
Posts: 1,212 Canton, Ohio
Crazy68Dart
Canton, Ohio
Maybe the junk was in the filter when you spun it on, brand new out of the box, who knows, crazier things have happened. ![](/ubbthreads/images/graemlins/shruggy.gif)
383, Hemi 4-Speed, AlterKtion, D60
[Re: Crazy68Dart]
#1284958
08/18/12 08:58 AM
08/18/12 08:58 AM
MR_P_BODY
Larry asked that same thing... was it a new filter.. yes it was... yeah anything can happen I guess ![](/ubbthreads/images/graemlins/wave.gif)
