Page 11 of 25 1 2 9 10 11 12 13 24 25
Re: new Moparts fastest car list, post yours! *DELETED* [Re: MegaDart] #12834
04/21/05 05:05 AM
04/21/05 05:05 AM
gregsdart Offline OP
Post deleted by gregsdart
Re: new Moparts fastest car list, post yours! [Re: gregsdart] #12835
04/21/05 05:11 AM
04/21/05 05:11 AM
--7 second zone ---
7.21 @ 193, 1.11 60', Hemifred, turbo Road Runner
7.68 @ 179.31, 1.08 60', 572stealth, '92 Dodge Daytona 572 B1MC, torqueflight, 2330#
7.91 @ 181, 1.27 60', valiant65, 65 Valiant, 3319#, twinturbo 353B1BA + lenco 5-speed
---8 second zone ---
8.02 @ 174+, The Haze, twin turbo 452"
Leon Hudson 65 Barracuda
[Email]8.14@169[/Email] with fogger and plate,Leon Hudson 65 Barracuda
8.17 @ 163, 408 cubes, Indy headed, fuel injected on alcohol,slingshot383
8.178 @ 167.12, 1.139 60', B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide
8.180 @ 165, SG303, 91 Daytona, 2420# 572 single 4, glide, just motor
8.24 @ 163, 1.15 60', Rapid588, 93'Dodge Stealth, 2490#, motor only.
8.36 @ 164, JoeZ, 1972 Challenger, 451 B1 Nitrous, 727, 10.5" tire, 3005#
8.52 @ 156.4, 1.17 60',SB412DUSTER 72 Duster,5.33 @ 126-1/8, 4link B/half 2424# 412/W7 NO P/A
8.57 @ 161, W8Duster, '71 Duster, 430 W8, single stage fogger, 'Glide, 29x10.5 (non W), 3350#
8.62 @ 157, TwinDick Racing, 73 Duster, 528, B1, Nitrous, Turbo 400, 10.5w 3340#
8.62 @ 156.4, 1.18 60', SB412DUSTER 72 Duster, 5.33 @ 126.9-1/8, 4link B/half 2424# 412/W7 NO P/A
8.68 @ 156, "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650#
8.77 @ 153.16, Gregsdart, 65 dart ,528cu 440-1, 3000#, 2780 den altitude. NA 6/26/04
8.78et 160.34mph Lenny Melton 1968 DART
3,540lbs 10.5 ET streets. This is areal street driven car.
8.781 @ 155.13, 1.261 60', Hemifred SOX&MARTIN DUSTER
8.908 @ 150.40, 1.245 60', RT540, 69 Coronet, 2840#, 540" B1BS-727TF
---9 second zone ---
9.15 @ 148.85, Megadart, 422" W5 headed sb, all motor, #2540
9.189 @ 145.66, Beeracuda, 74 Barracuda @ 4241' DA 2750#, 499/PG
9.274 @ 145.76, NHRAMARK, 70 Duster 3050 lbs, 540" Indy,
9.27 @ 144.50, 572charger 3850#, pump gas, 10.5street tires /4 1/2 " exhaust w/tail pipes/ 125 hp shot on leaf springs/ driven daily / not a race car !
9.29 @ 143.8, 1.27 60', BEST MACHINE, 65 Coronet 3460# 511,B1BS,10.5W,3.5"X pipe w muffs, All Motor and Foot Brakin
9.33 @ 142, 1.23 60', 1BADLILCHARGER '81 Charger 2300#, 440/727w/brake, Eddys,
9.34 @ 144.97 Street legal, 10.5 tires, through the muffs, 3450 lbs. TheOtherDodge
9.35 @ 144.66, Bad66, '66 Dart GT, 471 B1 stroker...,all throttle no bottle
9.43 @ 126, sloride, shutoff @ 1000', testing 70 cuda 572 indy head 3500# street trim w/225 shot, 9.99 @ 136 on motor
9.47 @ 142.5, MR P BODY, 395 ci W-2 2430#
9.59 @ 142, Biginchmotor, 72 Barracuda, 3000#, 500 inch motor, 727 auto no trans brake, super stock springs, 4.30 gear
9.692 @ 136.2, 1.326 60', 440Jim, '69 Dart GTS, 3120#, 471 CID, ALL MOTOR
9.81 @ 137, acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire
9.82 @ 135.89, Mopargilley, 68 Barracuda, 400" W-2 motor 3170# stock 727 W/brake 4:56gear 11.5 tire
9.84 @ 134.90, Bumps440. 69GTX 3240#, all motor, 446ci, stageIV iron heads, Footbraker
9.85 @ 135 398-W2 Duster398
9.85 @ 132.2, DCI, 38 Simca 225ci Slant 6/904, 1/8 6.10 @ 109.8, 2315#, Turobcharged 12# of boost EFI on Methanol
9.87 @ 138, Bigcube '69 Dart , 2950#, all motor, 11:1comp 476cid
9.94 @ 133.99, b3422w5, 70 duster, 422w5, 3380#, 727, leafs
9.96 @ 134, DavidDean, 71 Duster, 5500'DA 413" 904 SB 2850# 6.18 @ 109 1/8 3500'DA
9.91 and 142 mph,440 906 heads, Mrsixpak
9.972 @ 131.56, 1.350 60', Sleepyhead416
---10 second zone---
10.03 135 through exhaust
on dot tires paul swigart 69 pro street cuda
10.05 @ 133.59, 1.39 60', Duster John, 73 duster, 6.40 @ 107.90 1/8, street car pump gas, mufflers, 10.5"tires,#3400
10.13 @ 135.2, 1.506 60', Tig, '74 Challenger, 528ci, Indy -13 heads, 3916# W/D, N/A.
10.18 @ 132.45, 1.394 60', ProSport, '73 Dart Sport, 451 with E-heads & MP 590 cam, 3,035#
10.18 @ 130.5 1.39 60', J-BODY, 80 Mirada, 498 Stage VI heads 3380#
10.22 @ 132.37, 1.498 60', Clutch, 88 D100, 512ci NA
10.23 @ 130.50, 1.41 60', Marvo451 '71 Duster, 451 RB. Iron 452 heads, pump gas, flat tappet cam
10.24 @ 128, 1.36 60', 10sec440, 440RB 452 heads 590cam pump gas 3400#
10.40 @ 129.1, a10sec70cuda, 446 cid, 3700#, all motor street car, through mufflers on 10.5"
10.45 @ 127, StrokerPost 67 Dart Sedan, 414 SB, 3290#, factory iron heads, all motor.
[Email]10.50@129[/Email] KOS Nick 70dart driven to the track,trw flat top,stock rod 446,iron indy head 1050dom 3500#.
10.50 @ 127.00, daron 73 duster, sb street car
10.52 @ 130, BB70DUSTER, 400 stock bottom end w/ E heads on squeeze, and on pump gas
1968 dart 365ci mildly ported iron heads on alcohol 10.54 at 124mph,2933lbs 590cam,1968 dart 365ci mildly ported iron heads on alcohol Dare dude
10.59 @ 124, 1.45 60', mopar65, 65 Plymouth 3500# 446 w/E heads
10.64 @ 124.50, 1.49 60', RVA, 440ci 3165#
10.65 123.43 1.45 60ft 68 Dart,3160lbs,crate 360 W2 heads,904,s/s springs,10 1/2 inch slicks,mufflers, 11secdart
10.68 @ 128.3, 1.54 60', TimMoffett, 69 Charger, 4-speed Street Car, 3900# with full exhaust
10.68 @ 127.38, eeka440 73 Swinger 446 906's auto
10.70 @125 60' 1.50 3700 race weight 10secGTX
10.76 @ 124, Mopartony, 68 Dart 470cid, 727
10.86 @ 118, 85 Camaro SB 385cid 3380Lbs P/Windows all steel street legal & driven (let off)
---11 second zone ---
11.10 @ 121.34, 1.54 60', Bubba, '80 Mirada, 440, 3855#
11.24 @ 119.3, 1.58 60', ZIPPY '69 GTX Street Car, 451CI,
11.26 @ 119, 1.51 60', fast68plymouth, 68 Satellite, 383, 3675#
11.30 @ 118.98 1.60 60', TC67CUDA, 440, 346heads, 727 thru mufflers 3400# w/driver street tuned
11.317 @ 120.209, 1.542 60', Mark Gates, 7.17 1/8, iron head 451/727/3.91 8 3/4 #3765 AMC Pacer
11.33 @ 118.9, 1.60 60', LAR_414, 1969 Dart GT, 3350# race wt, 414 stroked smallblock w/ factory J heads, solid cam and pump gas
11.40 @ 121.80, 1.63 60', aarlucas, '70 cuda, 451"6 PK, 3680#, 2.5" exh sys,pump gas, 3.91, auto
11.40 @ 119.18, w2_360duster, 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020# w/o driver
11.46 @ 115 1.55 60' Don1 75 Duster 360 3000# w/driver
11.60 @116-69 superbee 440-6 pack-3800# BEEQUICK
11.62 @ 114 mph, 1.64 60' in a 3300# 69 fast back cuda street car...Phill
11.67 @ 116 RoadRnnr69, 1969 RoadRunner 500 stroker, auto 4:10 gears Street tires, full exhaust , 93 octane.
11.708 @ 114.24, 1.674 60', tboomer '64 Dodge 330 sedan, 3460# 446" 3.91 gears...
11.72 @ 113, 440Jim, '73 Cuda, 3700#, hyd cam, 446CID, street
11.75 @ 113, 1.57 60', 68DART360, pump gas street tires
11.76 @ 116.57, 1.65 60', 493Charger, 68 Charger R/T auto. 493" 3750#
11.78 @ 114, Sledgehammer, '71 Dart Swinger, 3470#, 366ci J-headed Small Block 904 Auto on street tires
11.85 @ 116.6, 1.65 60', 68LAR, '68 Road Runner 3926#, 4 SPEED street car
11.877 @112.52, 1.59 60', 6PKBEE, Aspen R/T 360/904/3.91
11.90 @ 111.6, 1.62 60', Glen440, 77 Volare 440/727/4.10
11.97 @ 111, 1.65 60', topfueldart, 70 challenger 446, bone stock 906's, hyd cam
---12 second zone ---
12.02 @ 110, 1.58 60', cudadan
12.03 @ 111, 1.72, '66 Fury, 446/727, Edelbrocks, 3800 stall, 4:10's, 3960lbs w/driver Sportfury440
12.07 @ 108, 1.72 60', Mikesduster, 72 duster, 340, street trim
12.19 @ 105.88, 1.595 60', quickd100, 7.621 @ 87.04 1/8
12.305 @ 112, 1.88 60', Jon Smith 69 charger 493" full street trim, 7.94 @ 90 1/8
12.85 @ 105.43, 1.82 60', 67Charger, '67 Charger, 440/727 (full man.), 4.10's, 3750# w/ me
Re: new Moparts fastest car list, post yours! [Re: gregsdart] #12836
04/21/05 11:39 AM
04/21/05 11:39 AM
Kissimmee, Florida
aarlucas Offline
aarlucas  Offline
Kissimmee, Florida
--6 second Zone --
6.69 @ 207 Allen Johnson, 2005 Dodge Stratus 500ci PS Hemi
--7 second zone ---
8.14 @ 169,with fogger and plate,Leon Hudson 65 Barracuda
8.78 @ 160.34mph Lenny Melton 1968 DART
9.39 @ 144.91, TheOtherDodge,498, Auto, 3450 lbs, true 10.5 tires, through the mufflers on stock suspension
10.03 @ 135 through exhaust
10.50 @ 129 KOS Nick 70dart driven to the track,trw flat top,stock rod 446,iron indy head 1050dom 3500#.
10.65 @ 123.43 1.45 60ft 68 Dart,3160lbs,crate 360 W2 heads,904,s/s springs,10 1/2 inch slicks,mufflers, 11secdart
10.70 @ 125 60' 1.50 3700 race weight 10secGTX
11.40 @ 121.80, 1.63 60', aarlucas, '70 cuda, 451"6 PK, 3700#, 2.5" exh sys,pump gas, 3.91, auto
11.60 @ 116-69 superbee 440-6 pack-3800# BEEQUICK
11.877 @ 112.52, 1.59 60', 6PKBEE, Aspen R/T 360/904/3.91
Re: new Moparts fastest car list, post yours! [Re: aarlucas] #12837
04/21/05 01:58 PM
04/21/05 01:58 PM
Texas
Beeracuda Offline
super gas
Beeracuda  Offline
super gas
Texas
--6 second Zone --
--7 second zone ---
9.063 @ 146.23, Beeracuda, 74 Barracuda, 2800#, 499/PG
Re: new Moparts fastest car list, post yours! [Re: Beeracuda] #12838
04/21/05 08:48 PM
04/21/05 08:48 PM
USA
dodge_nut Offline
dodge_nut  Offline
USA
--6 second Zone --
--7 second zone ---
12.17 @ 108 1.77 60', dodge_nut, 71 Charger, 440/727
Re: new Moparts fastest car list, post yours! [Re: Beeracuda] #12839
04/21/05 08:48 PM
04/21/05 08:48 PM
CheddarHead till October
weedlayer Offline
weedlayer  Offline
I was in here once before, but have been deleted I see. wasamadda? don't like cheeseheads??
I'll slip my little block in there ahead of Chip
pretty cool to have AJ listed here
--6 second Zone --
--7 second zone ---
10.325 @ 128.36, 1.405 60', weedlayer, ugly year, sb Challenger, 3430#
Re: new Moparts fastest car list, post yours! [Re: weedlayer] #12840
04/22/05 12:04 AM
04/22/05 12:04 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
--6 second Zone --
--7 second zone ---
12:91@102, 1.72 60', Slantzilla, '66 Valiant post car, 232 ci Slant, Keith Long full manual 904, 3.91, 100 Top Gun shot, 3250#.
Re: new Moparts fastest car list, post yours! [Re: slantzilla] #12841
04/22/05 02:17 AM
04/22/05 02:17 AM
Mobile Alabama
SB412DUSTER Offline
SB412DUSTER  Offline
Mobile Alabama
--6 second Zone --
--7 second zone ---
Re: new Moparts fastest car list, post yours! [Re: SB412DUSTER] #12842
04/22/05 01:54 PM
04/22/05 01:54 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
--6 second Zone --
--7 second zone ---
8.02 @ 174+, The Haze, twin turbo 452", Leon Hudson, 65 Barracuda
8.14 @ 169,with fogger and plate,Leon Hudson, 65 Barracuda
8.78 @ 160.34mph Lenny Melton 1968 DART 3,540lbs 10.5 ET streets. This is areal street driven car.
9.34 @ 144.97, TheOtherDodge,498, Auto, 3450 lbs, true 10.5 tires, through the mufflers
10.54 @ 124, 2933lbs 590cam,1968 dart 365ci mildly ported iron heads on alcohol Dare dude
Re: new Moparts fastest car list, post yours! [Re: TheOtherDodge] #12843
04/27/05 12:52 AM
04/27/05 12:52 AM
Kentucky
Greencospeedshop Offline
Kentucky
--6 second Zone --
--7 second zone ---
10:14@129.70 70 Challenger 040 over 440 eddie heads .footbrake.
Re: new Moparts fastest car list, post yours! [Re: gregsdart] #12844
04/27/05 06:06 PM
04/27/05 06:06 PM
Abilene,Texas
ram87 Offline
ram87  Offline
Abilene,Texas
1968 Hattiesburg, Ms.
1968 Sports Satellite, 383CI +.030, factory rated 330 HP, Advertised shipping weight 3475 Lbs., 4 speed. Legal NHRA G/Stock. Ran a 12.60 @112 MPH on Carmen Rotunda 12.73 @ 108 MPH national record. Remember a legal G/S had to run on 7 inch wide tires (if anybody can remember that far back).
Re: new Moparts fastest car list, post yours! [Re: ram87] #12845
04/28/05 09:04 PM
04/28/05 09:04 PM
upstate western ny
sogtx Offline
sogtx  Offline
upstate western ny
Just in case your reading , I think my cars faster than yours in the quarter quad
Re: new Moparts fastest car list, post yours! [Re: Greencospeedshop] #12846
04/29/05 11:10 PM
04/29/05 11:10 PM
LEBANON;PA
daron Offline
daron  Offline
LEBANON;PA
10.48@128.96smblock all street nonported indyheads
Re: new Moparts fastest car list, post yours! [Re: Greencospeedshop] #12847
04/30/05 02:36 PM
04/30/05 02:36 PM
Easton, PA
68DART360 Offline
68DART360  Offline
Easton, PA
--6 second Zone --
--7 second zone ---
11.50 @ 115 1.55 60' 68DART360 ,904, 3200 lbs,eheads, pump gas,full exhaust, 10" tire SS springs
Re: new Moparts fastest car list, post yours! [Re: 68DART360] #12848
05/01/05 12:57 AM
05/01/05 12:57 AM
Erda, UT
67Charger Offline
67Charger  Offline
Erda, UT
--6 second Zone --
--7 second zone ---
12.393 @ 108.432, 1.67 60', 67Charger, '67 Charger, 440/727 (full man.), 4.10's, 3750# w/ me
12:91 @ 102, 1.72 60', Slantzilla, '66 Valiant post car, 232 ci Slant, Keith Long full manual 904, 3.91, 100 Top Gun shot, 3250#.
11.33 @ 118.46 on motor
10.75 @ 125.35 w/ a little spray
Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race
Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
Re: new Moparts fastest car list, post yours! [Re: 67Charger] #12849
05/03/05 12:04 PM
05/03/05 12:04 PM
SE Nunya
Bubba Offline
Bubba  Offline
SE Nunya
--6 second Zone --
--7 second zone ---
10.98 @ 122.29, 1.55 60' Bubba, '80 Mirada, 440, 3855#
Re: new Moparts fastest car list, post yours! [Re: wyoming] #12850
05/06/05 03:01 PM
05/06/05 03:01 PM
hey guys , im new to your forum but glad i found it ! your cars are great ! i was around for the muscle car era & the factory wars ! it was a great time . ford , chevy & of course mopar were hard at it . mopar had the infamous top end charge that was devistating to all comers . i saw many of the "big" names in person at scramento raceway in the 60/70's ! your cars are a great reminder of "THE DAYS" when cars ruled . i think that it is awesome that people have restored & kept the great cars alive ........ thx steve
Re: new Moparts fastest car list, post yours! #12851
05/06/05 05:11 PM
05/06/05 05:11 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
Everybody check their #'s, somebody's got it all screwed up...
-6 second Zone --
--7 second zone ---
9.08 @ 149.75, Megadart, 422" W5 headed sb, all motor, #2540
Re: new Moparts fastest car list, post yours! [Re: MegaDart] #12852
05/06/05 11:38 PM
05/06/05 11:38 PM
-6 second Zone --
--7 second zone ---
8.13 @ 168, 1.165, 412ci all motor, glide, Dodge Omni
Re: new Moparts fastest car list, post yours! [Re: MegaDart] #12853
05/08/05 08:10 PM
05/08/05 08:10 PM
-6 second Zone --
--7 second zone ---
12.07 @ 108, 1.72 60',3250 lbs, Mikesduster, 72 duster, 340, street trim
