Page 14 of 32 1 2 12 13 14 15 16 31 32
Re: my 69 rr black, pewter int and pewter painted roof [Re: rss] #1282490
05/11/14 10:40 PM
05/11/14 10:40 PM
new jersey
Black 69 Beeper Offline OP
new jersey
Thanks, I do take a lot of pride in my students. Unfortunately, a lot of them would love to have an older car but they have been priced right out of the hobby.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282491
05/18/14 09:02 AM
05/18/14 09:02 AM
new jersey
new jersey
I got the seams welded up on the cowl area. I melted the lead off the cowl, mig welded the seams solid, and used USC All Metal w/ high grade body filler to finish everything off. The cowl is now ready for 3 coats of epoxy prime and the areas that had filler work done will get coated with 3 coats of PPG K36 filler primer. The filler primer will get wet sanded with 500 grit and the cowl and engine compartment will be epoxy primed again with PPG DP90LF black epoxy primer. I like to let my fillers cure for at least 24 hours before i prime over them. Body filler shrinks and is omitting chemicals. I don't like to trap that stuff under the primer.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282492
05/18/14 09:03 AM
05/18/14 09:03 AM
new jersey
new jersey
other side.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282493
05/29/14 09:25 PM
05/29/14 09:25 PM
new jersey
new jersey
I got the cowl Epoxy primed with PPG DP90LF black. i will put 3 coats of PPG K36 filler primer on it, then wet sand it with 320 and then 500 after it is guide coated, then reseal it again with DP90LF. i will be ready to shoot color soon on the cowl and under the hood area.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282494
05/29/14 09:25 PM
05/29/14 09:25 PM
new jersey
new jersey
another shot of the cowl w/ the body work completed and epoxy primed.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282495
06/19/14 08:14 PM
06/19/14 08:14 PM
new jersey
new jersey
slow progress lately guys. still waiting on sheet metal. hopefully soon. I have been helping my dad with his 56 Chevy. I know its a Chevy but its from Arizona and anyone from the northeast knows what that means. he has had it 35 years and got it from a close family friend who past away, so its time to do the car. chassis is all finished. old school hot rod type here. 327, turbo 350, 4:11's etc. any old car is cool, i just prefer mopars.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282496
06/23/14 09:20 PM
06/23/14 09:20 PM
new jersey
new jersey
Just got word today that my quarters are in. I also ordered a new hood and door skins. last one I do, I want it done right. I did get the K36 filler primer on the cowl and inner fender wet sanded as well as the under hood area hand sanded to smooth the epoxy primer over spray. next comes DP90LF epoxy primer sealer and DCC black single stage color.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282497
06/23/14 09:21 PM
06/23/14 09:21 PM
new jersey
new jersey
I finished making this rear suspension dolly so i can get the car off the rotisserie and back on its body weight so i can get the quarters going.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282498
06/29/14 12:09 PM
06/29/14 12:09 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Hey Mike wanted to give you some incentive. My Satellite will be coming home within a week or two.
Ron
Re: my 69 rr black, pewter int and pewter painted roof [Re: RJS] #1282499
06/30/14 12:29 AM
06/30/14 12:29 AM
new jersey
new jersey
Awesome. post some pictures when you get it back.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282500
07/03/14 11:09 PM
07/03/14 11:09 PM
new jersey
new jersey
the road runners new tow vehicle.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282501
07/14/14 07:34 PM
07/14/14 07:34 PM
new jersey
new jersey
Well, even though i was disappointed with the chryslers at carlisle show, i did feel compelled to get something going on my car today. the sheet metal will finally be here in a week or 2. i don't plan on getting to nuts w that until fall. i did get the engine compartment epoxy primed w/ DP90LF. i am going to paint the engine compartment this weekend and inside the interior firewall area.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282502
07/14/14 07:35 PM
07/14/14 07:35 PM
new jersey
new jersey
engine compartment 2
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282503
07/14/14 07:35 PM
07/14/14 07:35 PM
new jersey
new jersey
engine compartment 3
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282504
07/14/14 07:36 PM
07/14/14 07:36 PM
new jersey
new jersey
engine compartment 4
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282505
07/14/14 07:37 PM
07/14/14 07:37 PM
new jersey
new jersey
cowl is all finished and ready to be painted with the engine compartment.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282506
07/18/14 10:28 AM
07/18/14 10:28 AM
Brantford Ontario
69_SIX_PACK Offline
69_SIX_PACK  Offline
Brantford Ontario
Keep up the great work!
Re: my 69 rr black, pewter int and pewter painted roof [Re: 69_SIX_PACK] #1282507
07/19/14 10:11 PM
07/19/14 10:11 PM
new jersey
new jersey
Well i was doing some research as to where the air grabber cable came through the firewall. it turns out there is a dimple on the firewall under the voltage regulator.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282508
07/19/14 10:12 PM
07/19/14 10:12 PM
new jersey
new jersey
i used a uni-bit to drill the hole. it is a little bigger than 3/4 inch.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282509
07/19/14 10:13 PM
07/19/14 10:13 PM
new jersey
new jersey
the cable uses the same rubber grommet as the antenna so you could use that hole as a guide. here's the finished hole with the grommet.
