acceptable vaccuum for 340 #1281475
08/08/12 02:04 PM
08/08/12 02:04 PM
canada
sailboat Offline OP
sailboat  Offline OP
canada
My 1970 challenger T/A was just restored inclusive of a complete engine overhaul.Carbs were restored and dist. was replaced with a factory electronic with the orange box. The cam that was installed was a comp cam XE-268H-10, stock forged pistons with a true (so i am told) 10.5 compression ratio. My concern is, what should the vaccuum read at idle. My engine is reading 10 pounds. Car has twenty miles on the engine.
Thanks in advance.
Re: acceptable vaccuum for 340 [Re: sailboat] #1281476
08/08/12 02:40 PM
08/08/12 02:40 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
"" My engine is reading 10 pounds""
Is this a reading in D or is this in N?
With that CC cam, I would guess that you should have around 14" vacuum at 900-950rpms in N.
What is your initial timing? You might just be too low of initial with the cam swap.
Note: I almost put that same cam in my motor during my last cam swap.
Re: acceptable vaccuum for 340 [Re: YO7_A66] #1281477
08/08/12 03:46 PM
08/08/12 03:46 PM
What do you have?
Re: acceptable vaccuum for 340 [Re: RapidRobert] #1281478
08/08/12 04:03 PM
08/08/12 04:03 PM
canada
sailboat Offline OP
sailboat  Offline OP
canada
Vaccuum was checked with the car in neutral. Just called my mechanic to find out what the timing is set at and will post shortly. I called Comp cams and asked them what the vaccuum should read and their response was between 8and 12. I wanted another opnion. Based on the specs I have given, what should the timing be set at. I have been told that if it is too far advanced, it will cause too much "ignition" and damage the engine. If so, what is too much adn what is acceptable??
Re: acceptable vaccuum for 340 [Re: sailboat] #1281479
08/08/12 04:56 PM
08/08/12 04:56 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
""their response was between 8and 12.""
That seems like an in-D vacuum reading at around 900-950rpms or so.
Don't worry about the "too much advance" theory for now. Members like me will tell you to throw as much initial at it that you can until the starter gives you fits. Once you know how much it will take, then we can help you with the rest of the distributor setup. I would suggest that what ever initial that you currently have, bump it up my 5 and reset your N rpms and take another vacuum reading. Then bump it again and reset your N rpms, then take another vacuum reading. This test will give you some options. As long as the vacuum increases and your starter can spin it at startup, then it will be fine.
Reference: I ran 18 initial on my 340 with the stock starter and 24 with a mini starter.
Re: acceptable vaccuum for 340 [Re: YO7_A66] #1281480
08/08/12 05:20 PM
08/08/12 05:20 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
what is the elevation where you live?
Tony
70 AARCuda Vitamin C
Re: acceptable vaccuum for 340 [Re: YO7_A66] #1281481
08/08/12 05:33 PM
08/08/12 05:33 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Fix your initial timing. Sounds like your mechanics fell out of the 1970's and set it up timing via total method which is not the best way to do things.
Do as Y07 has suggested. More initial will clean up the idle and get it to run better at idle with more vacuum. You'll need to modify the distributor curve so your total number doesn't go out of range.
This car has the same cam, easily idles at 850 in park and 750 in gear, pulls 14". IIRC, it has 16-18 initial. If your car won't idle that low, the issue is likely in your ignition settings.
Re: acceptable vaccuum for 340 [Re: RobX4406] #1281482
08/08/12 07:31 PM
08/08/12 07:31 PM
canada
sailboat Offline OP
sailboat  Offline OP
canada
Thanks Guys. Just spoke to him and the timing is set at 8 degrees at idle?? runs at 33 degrees with the advanced disconnected reved up to 3000rpm?? Let me know your thoughts on this then I will tell you my tale of woe and my reason for posting this.
Re: acceptable vaccuum for 340 [Re: sailboat] #1281483
08/08/12 07:44 PM
08/08/12 07:44 PM
RobX4406 Offline
RobX4406  Offline
Needs AT LEAST twice what you have for initial. Must have looked at a service manual for that 8* reading. Throw all the out because even back then, they didn't run well with the recommended idle timing. Turn it to 16 and reset the idle speed. I'll bet it's snappier!
You then need to recurve the distributor, it has WAY TOO MUCH mechanical advance in it.
33 Total is kind of light for total on an open chambered SB.
Re: acceptable vaccuum for 340 [Re: sailboat] #1281484
08/08/12 07:54 PM
08/08/12 07:54 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Needs more initial, 33 degrees total is in the range, small blocks typically like 34 but experiment some.
I'd run 15-20 initial. You can do it the easy way and hook the vacuum advance to manifold vacuum if you're only concerned with increasing idle quality and not performance, or just as a temporary solution. You may end up with some other undesirable symptoms depending on the rest of the setup though, but probably not. You will just be losing some off idle performance.
Re: acceptable vaccuum for 340 [Re: GTX MATT] #1281485
08/08/12 10:01 PM
08/08/12 10:01 PM
canada
sailboat Offline OP
sailboat  Offline OP
canada
what would those undesireable symptoms be??
Re: acceptable vaccuum for 340 [Re: sailboat] #1281486
08/08/12 10:25 PM
08/08/12 10:25 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
""what would those undesireable symptoms be??""
I have been running manifold vacuum for about 4 months now. I have 18 initial timing (only during cranking, once the engine fires and the manifold vacuum is reached, then the extra 14 degrees is in) and 32 degrees at in-D-idle.
The only issues that I have found:
- idle circuit needs to be richer to run the extra idle timing.
- With my auto, once I had my in D rpms tuned and then I put the car into P or N, the idle rpms would climb about 200rpms and make the engine deisel during shot off. I added an idle solenoid and the problem solved.
- My vacuum can is designed for 12"hg at idle in D (or in N for a manual). I had to tune my idle to get the 12"hg in D, but once I did, the engine idles great in D. I have ran with 11 3/4"hg and had no ill affects. I also tried 11 1/2"hg and the idle started to wonder. So as long as I have 11 3/4" or more in D, then it idles great with 32 degrees of timing.
Re: acceptable vaccuum for 340 [Re: YO7_A66] #1281487
08/08/12 10:35 PM
08/08/12 10:35 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
good info
Re: acceptable vaccuum for 340 [Re: sailboat] #1281488
08/09/12 02:05 AM
08/09/12 02:05 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
I've never really had an issue, but the possibility exists. You could end up with an idle thats a little bit tough to idle down. The most likely problem is an idle that drops too far once you get it into gear. It could idle at 1300 in park/neutral but drops to 700 in gear because the vacuum drop once in gear gets exacerbated when the timing retards with it, further reducing vacuum. This is most likely to happen in a low vacuum, low initial advance situation like yours. I suppose you could end up with a strange off idle transition too.
Either way it wont hurt to try. Some people freak out at the idea of using manifold vacuum. I remember having a long, argumentative type thread on here a few years back about this. I've since noticed that people keep coming on saying that FBO recurved their distributors for manifold vacuum and set it up for manifold vacuum. Although I never set up a curve any different, I set the idle where the engine likes it and total where it likes it. Then I add the manifold vacuum to further increase idle quality.
The only difference is that the ported vacuum port SHOULDN'T pull vacuum at idle. It will if it is exposed from the throttle blades being open too far, i.e. the carb is off the idle circuit. Ported vacuum is actually an emissions device, and cars used to run manifold vacuum for years.
Re: acceptable vaccuum for 340 [Re: GTX MATT] #1281489
08/09/12 06:05 PM
08/09/12 06:05 PM
canada
sailboat Offline OP
sailboat  Offline OP
canada
Thanks for the info everyone. Here is my tale of woe. I recently completed a complete 100% restoration on my 70' Challenger T/A that I purchased new back in 1971. The car had been of the road since 1988 and stored in my garage. No price was spared in the restoration with the exception of the windshield wiper motor! Several service dealers in my city recommended this machine shop to me for the engine rebuild. I met and spoke with the owner/operator about all of my past experiences, and previous problems, with this 340. He seemed to know what he was talking about, plus he was recommended as "knowing his stuff". Talked to several other shops as well and got estimates from two others. Both other shops were substantially cheaper than the person that was recommended to me. I didn't want it cheap, I wanted it right. I gave him the go ahead to do the engine. I wanted him to rebuild the engine, assemble the engine and then put it on a stand and run it, and tune it. Upon complettion of the engine, my body rebuilder picked up the engine and installed it in the car. When the car was finally completed, my car rebuilder dropped the car off to me in an enclosed trailer. We backed the car out of the trailer and I drove it around the block. The car seem to run fine, but I noticed it had a slight tapping sound. I called the engine rebuilder and voiced my concerns and his excuse was that it was "these new HP cams" and that it would quiet down after some miles. Long story short? It never did. I drove the car for 23 miles in total. As the car revved up to shift (automatic, not standard) the tapping/clicking, became much more noticable. I called him again. He advised me to have my garage look at it as the timing may have been set too high. His interpretation of the noise was "pinging" and not tapping or clicking.
made an appointment with my service mechanic (third party now)that i deal with with my fleet service to have this noise checked. Dropped the car off. As soon as i arrived home i had a call from my fleet service mechanic who then told me that the motor was going to have to come out of it because one of the crank berings was gone. Needless to say, i was shocked. My service guy had taken the car out on the paved sideroad, stepped on it and, bang, the tap became a knock.
Called the engine rebuilder and told himn to get over and see this thing. He did, and all agreed the engine had to come out. Problem was serious, especially after an $8,800.00 rebuild with 23 total miles!! I had my service mechanic take the engine out of the car and take it over to the rebuilder. Two days later I get a call from him and he tells me #7 bearing failed and it failed because of these possible reasons:
1) I didn't use high octane fuel and the bering was caused by ignition(of course high Octane pup gas was used!)
2) Engine must have over heated (it didn't. it ran very cool with the gauge showing always to the far left of the middle)
3) My gauge or sending unit must be faulty ( it wasn't. Just put another send ing unit it the engine and it reads the same. Entire cooling system, hoses, rad, water pump, stat were all new.)
4) timing must have been too far advanced and destroyed the engine due to pre-ignition (it was set at 8 degrees!!)and he set it!
Rad and engine must have pugged up because there was black residue in the rad and engine ( the was some, but the new installer said it was from the debris from the engine rebuild. He said he baked the engine to clean it)
Needless to say, he wasnt going to give me any warranty on the engine. After some pressure form myself and my service mechanic he said he would cover it all, including the re and re. When the engine was done, i was away on holidays whn i had a call from my service mechanic who told me that the rebuilder mwouldn't release the engine to him and that he wanted to be paid for the parts and now wasn't going to cover the re and re. To get the engine back i told him to pay him for the crank bearings and that I would cover him for the re and re. My service mechanic has now put the engine back in the car and I got it back yesterday. Appearantly the engine rebulder didnt even thake the crank out of the engine, he just put bearings on the crank and put it back together. Again, long story short? Another $1300.00 and a very bad experience. All of the above brings me to my vaccuum and timing questions. This idiot that rebuilt my engine has blamed pre-ignition for this Bering letting go in my motor. We dont think that is the case at all. When my service mechanic asked for the old berings he regfused to give them to him. I dont want to go through this again. Your thoughts on the above? How should this engine be set? What should the timing be? Do I need to recurve the dist and how does one do that? Is premuim pump fuel fine?
Thanks to all before hand
JIM
Re: acceptable vaccuum for 340 [Re: sailboat] #1281490
08/09/12 06:24 PM
08/09/12 06:24 PM
I'd find the initial the engine wants with the "vacuum gauge" method then with that figure in hand shorten the slots to get 35 total (checked with vac advance capped). If it has a true 10.5 scr then pump premium may not cut it. In the meantime I'd for sure be talking to a lawyer & gearing up for some serious court action (that's alot of money and he did it twice)
Re: acceptable vaccuum for 340 [Re: RapidRobert] #1281491
08/09/12 06:37 PM
08/09/12 06:37 PM
RobX4406 Offline
RobX4406  Offline
If that thing wasn't completely torn down and cleaned out, you'll be doing it again fairly soon is my guess.
Re: acceptable vaccuum for 340 [Re: RapidRobert] #1281492
08/09/12 06:43 PM
08/09/12 06:43 PM
canada
sailboat Offline OP
sailboat  Offline OP
canada
what would cause that #7 bearing to go in 23 miles??
Re: acceptable vaccuum for 340 [Re: sailboat] #1281493
08/09/12 06:48 PM
08/09/12 06:48 PM
dirt, inadequate clearance (oil/side), misassembly, inadequate oiling
Re: acceptable vaccuum for 340 [Re: RapidRobert] #1281494
08/09/12 06:51 PM
08/09/12 06:51 PM
canada
sailboat Offline OP
sailboat  Offline OP
canada
would pre-ignition cause that in 23 miles?
