Re: 440 SOURCE QUALITY?
[Re: DconD100]
#1280998
08/09/12 02:04 AM
08/09/12 02:04 AM
Posts: 5,949 British Columbia
chrisf
British Columbia
I asked who to use and he said scatt is the best of the best
I'd be willing to bet a nickel he's a Scat vendor.
you win the prize. they are
[Re: 2boltmain]
#1281000
08/09/12 06:40 PM
08/09/12 06:40 PM
moparpollack
Lil Herman
Lil Herman
85086
Meh, got some stuff from them for the 440 I'm putting together.... I suppose the stuff is decent. I guess depending how much is spent towards a given item it gives a bit of insight to the quality of the part. Rule of thumb in some cases I guess.
What are you saying with this statement? The tone is negative/insinuating 440 Sources' parts are bad yet your parts are fine? You do not specifically state whats bad with your source parts.
I think he's saying hat you get what you pay for you could spend more for higher quality.
[Re: Commando1]
#1281001
08/09/12 07:11 PM
08/09/12 07:11 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
I just got off the phone with someone who asked me what I thought about Walmart. I said their stuff was $%#@!. But I go there 2 - 3 times a week...
X2 and i've watched all the documentaries AND the South Park episode!
[Re: moparpollack]
#1281002
08/09/12 07:55 PM
08/09/12 07:55 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
The way I see this deal, with the chinese cranks and rods, the difference between mfg A and mfg B is the finish machining. A might be better than B, maybe not. Outside of K1, Id assume and figure on the cranks needing work...rods also...
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
