Parts still available from Chrysler
#124
04/14/03 09:38 AM
04/14/03 09:38 AM
Posts: 11,854 Georgetown Ontario Canada
anlauto
I found this list of parts on another web-site... It's an accurate list of parts still available from your local Chrysler dealer as of a couple of months ago.......... door lock cylinder gaskets 55074799 fuel level ground strap 2258862 speedo cable 04897646AA valve stem extenders 02401840 brake backing plugs 2072614 hood pop up spring 2935375 clutch boot 3515300 dimmer switch 1881938 glove box lens 2822583 torsion bar boots 2071173 fuel pump bolt 6023526 seat knob 2583623 rear diff vent 4032798 short battery "J" bolt 2534814 long battery "J" bolt 2074089 throttle cable hold down clamp 2402210 nut for above 6025006 front shock washers 2206925 bottom rear shock washer- inner 1319555 bottom rear shock washer- outer 1319554 steering box bolt 6028193 Hurst 4 speed shifter mechanism 4019122 Chrome LH remote "A" and "B" 68-70 Mirror 3695508 14" trim ring (wheel) 2944424 1990 truck exterior door handles 4217710 and 4217711 70-71 square 4 speed shifter boot 3467770 Dana 60 cover gasket 3634985 gas tank filler grommet 3404182 tank sender seal 1948757 t-stat housing 3698565 upper control arm bumper 4014050 lower control arm bumper 2948716 3/8th fuel sender filter 2534111 26" fan shroud 69-71 2998326 71 "B" body washer bottle 3431074 63-up bellhousing shift fork boot 3515300 8 3/4 Diff nuts 6028915 diff u bolts 3491296 nuts above 6023018 rear leaf spring bushing 1940725 sunvisor tips 2789037
I found it to be quite interesting, thought I would post it here.......
CHECK OUT MY NEW WEB SITE !
Re: Parts still available from Chrysler
[Re: anlauto]
#125
04/14/03 09:42 AM
04/14/03 09:42 AM
Posts: 1,632 TN
JS29R0B
TN
[Re: anlauto]
#126
04/14/03 10:01 AM
04/14/03 10:01 AM
Posts: 16,619 Almost Heaven
B_Body_Bob
Master of nothing
Master of nothing
Almost Heaven
Accurate but not exhaustive, 2996454 is a console 4-speed boot, available for order at $66.45. There's probably more too.
What's the URL for the website you found those on?
Bob
Everybody makes fun of a hillbilly until they need something fixed
[Re: B_Body_Bob]
#128
04/14/03 10:26 AM
04/14/03 10:26 AM
anlauto
I got the list off of Dodge-Charger.com It was posted by a friend from Alberta, he does a lot of 71 B-Body stuff.
