505cui stroker - dished or flat ?
#1279183
08/04/12 02:47 PM
08/04/12 02:47 PM
Posts: 33 germany
smoke
germany
505cui - Stroker question:
I was reading that many people are happy with their 440source-stroker kits. I’ve two of these sets in the focus:
One with dished pistons and the flat version. Since I’m looking for the lighter one, the flat would be my first choice. Does anyone know how much more grams the dished version has? They do not have this data on their page. Secondly the alu heads I have are around 75cc. This will pump the cr to 12.3:1 with the flats. Which is a ‘lil too much for a street-friendly ride I think. I’d be more happy with cr around 11:1 to 11.5:1
Should I get the dished version with 10.9:1 or taking the flats including thicker (0.60 or 0.80) gaskets ? Or do I run with the thicker gaskets in other problems?
thanks
Re: 505cui stroker - dished or flat ?
[Re: smoke]
#1279186
08/04/12 10:21 PM
08/04/12 10:21 PM
Posts: 43,352 Bend,OR USA
Cab_Burge
thanks
My 518 C.I. 400 stroker has a set of Ross custom 22 CC dish(complete dish, not reverse domes) that where originally set up at -.025 deck height with 84 CC open chamber iron heads and a Fel Pro .042 thick head gasket, that ended up making 9.25 to 1 comp. ratio. I switched heads two years later to a set of Eddy RPM(closed chambers) with 84.cc,I also switched the crankshaft from 4.25 stroke to 4.300 to make the motor a zero deck with Eddy RPM heads, I later switched those heads to a set of Indy SR with 75 CC chambers, ended up with 10.78 to 1 comp. with a .054 thick Cometic head gasket. It is barely pump gas friendly using Oregon non ethanol premium If I had to do it over I would start out with a reverse dome piston so I could get a decent quinch area in the top of the cylinders, not a complete dish piston
[Re: Cab_Burge]
#1279187
08/05/12 05:39 AM
08/05/12 05:39 AM
Posts: 33 germany
smoke
germany
Thanks for all of your input.
Yes the heads are indy 440 EZ opened to mw-size. They should have 75cc. But i'll check to be sure.
It seems that all of you are valueing the quench (this means going with heavier dished pistons) much higher than the weight advance of the flats (and using thicker gaskets). Is there no way to combine flat pistons and quench in this stroker build? Machining the pistons? What costs to expect roughly?
________________________________ regards
[Re: Dodgem]
#1279190
08/05/12 11:40 AM
08/05/12 11:40 AM
Posts: 33 germany
smoke
germany
so what cam converter and gears?? also what is the intended use?
@dodgem,
compcams suggested a hydraulic cam for maintanance reasons. They offered: Thumpr™, 283THR7 Car will be 4 speed with 3,54 gears street use, maybe once/twice seeing the strip. slightly rough idle accepted
question: Is there an hp-advantage zero-decking vs. -0.015 "in the hole" ?
Best, smoke
[Re: smoke]
#1279191
08/05/12 11:57 AM
08/05/12 11:57 AM
Posts: 52,972 Romeo MI
MR_P_BODY
@dodgem,
Best, smoke
Being a street car I would run the dish piston at 0 deck, .039 gasket... that'll give you the quench and your comp that you want... it would end up saving you money(if you go with Felpro gaskets)... then if you want(and probably should) you can advance the cam for better low end power... which closes the intake valve sooner on the piston stroke.... remember that the static compression is just a math number and the dynamic is when comp really starts so the CAM is the big part
[Re: smoke]
#1279192
08/05/12 03:48 PM
08/05/12 03:48 PM
Posts: 75,125 A Banana Republic near you.
JohnRR
Doesn't the source use KB Icon forged pistons ? With a little searching on the internet I find the KB Icon flat top at 577g and the dish at 592g , hardly anything to worry about .
You want to build the engine which your quench distance as close to .040 as possible. Bringing the pistons to zero deck and using a .039-.041 gasket is the best way to do it.
The HP difference won't be a lot difference, but the street friendly nature with available pump fuel is what your bigger concern seems to be so that is what you should do.
[Re: JohnRR]
#1279193
08/05/12 04:45 PM
08/05/12 04:45 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
You can build the same quench with flattops and dished pistons. Thats why the dished pistons are still flat on half of the top as thats the part where it will make quench which is the same height as the flattops. Problem is on some with certain cc heads you may have to much comp for pump with the flattops. I know I was close to 12.0 with my Indy heads and flattops so I had to use the dished pistons to keep the quench at .045 and drop the comp some as I am at 10.6. Now if I would have used 84cc Eddy heads instead of 75cc Indy heads I may have gotten away with flattops as my comp would have been lower. With the Indy heads I believe you will need to use the dished piston and you can have quench with a lower pump gas friendly comp. I believe the flattop piston will have your comp to high for pump. Ron
[Re: smoke]
#1279197
08/05/12 06:24 PM
08/05/12 06:24 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
@dodgem,
Best, smoke
well o deck with a .039 gasket gives .039 quench -.015 gives a quench of .054 not quite as good.
that is a mild cam definately go dish!
[Re: RobX4406]
#1279199
08/05/12 06:38 PM
08/05/12 06:38 PM
Posts: 33 germany
smoke
germany
@Rob since i wanted a maintenance-friendly cam, they advice me to go with a hydraulic flat tappet... I told them : slightly rough idle accepted ..... so in the end they came up with the 287thumpr. Ok, of course i'll not buy directly over the phone without consulting the wise guys here thanks
