Re: Anyone Had A Cam Re-Ground... UPDATE
[Re: Maximus_Wedges]
#1278253
08/08/12 12:52 AM
08/08/12 12:52 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Mike, Bullet has re ground several cams for us. Tim knows his stuff and can "tweek" a grind to best for your combo. You won't be disapointed. Kevin
Not getting it ground... having new lifter bushings put in tomorrow but they will be taller
[Re: MR_P_BODY]
#1278257
08/11/12 10:40 AM
08/11/12 10:40 AM
Posts: 16,930 NC
440Jim
NC
I was looking at the lifters at full lift and about 25% of the oil supply hole was exposed
What block is this and what is the lobe lift?
On factory big blocks, I thought the IMM roller lifters were fine to at least 0.460" lobe lift.
[Re: 440Jim]
#1278258
08/11/12 11:30 AM
08/11/12 11:30 AM
MR_P_BODY
Production 340 block with lifter bushings... lobe lift is .439... with the taller bushings its no problem now but to be honest I dont think that the hole being exposed was really the issue... just the sloppy bushings.. this block didnt have oil holes in the bushings before so it was never a problem with oil but when I drilled them the sloppy bore to lifter showed excessive oil losses... in a little while I'll know if thats cured
[Re: MR_P_BODY]
#1278259
08/11/12 06:03 PM
08/11/12 06:03 PM
Posts: 2,364 PA
70HemiGTX
PA
Midway Peformance in Mt. Carmel, PA took my old cam with a wiped lobe and made me an identical match with the exception of the wiped lobe. Cost was about the price of a new cam. They can make you what ever you want. Doug is the machinest there, he is a few years younger than I am. We grew up in the same town. He is a hard core mopar nut, but will make anything for anything. www.midwayperformance.com is their web site.
[Re: 70HemiGTX]
#1278262
08/11/12 07:59 PM
08/11/12 07:59 PM
MR_P_BODY
With the taller bushings I dont need to grind the cam Today was good and bad... I got my oil pressure up... was at 78# so I'm sure the by pass was working... the bad... I was only getting oil to 1 rocker.. this is push rod oiling so it gets the oil through the bushing then the clearance of the bushing to the lifter is what actually oils... the bushing hole and the lifter holes are 90* to each other ... so I pulled it back apart and checked the one that was working.. that was also the largest bore diameter.. so I had all the others too close so oil wouldnt pass... I reamed out all of them another .0015... cleaned the block AGAIN...I got the crank back in, cam degreed, and 6 of the pistons ... will get the other 2 in tomorrow and get the heads on and check the rockers again... this is a PITA
[Re: Labratt]
#1278264
08/11/12 09:53 PM
08/11/12 09:53 PM
MR_P_BODY
NO quit in this guy! Mike,got my fingers crossed for the "fix"!
I feel it will work... its a balance between having enough and not to much to let needed oil slip past so thats why I kept the clearance low last time.. I should have done what Sean said but I stayed on the low side.... he has more experience than me... at least the one that was over size gave me a clue what to to..... I'm still learning
[Re: 70HemiGTX]
#1278266
08/12/12 12:48 AM
08/12/12 12:48 AM
MR_P_BODY
The other week I said to one of my friends who is also into car (owns a trans. shop also), "Why do we keep doing this stuff???" He just looked at me and . I think it is the fact of conquering the beast in the car.....
Yeah... sometimes I wonder.... I could be sitting back and sipping on a brew or watching the grass grow.... NAAA... I'm not into watching the grass grow... I guess I just like doing this stuff... been doing it all my life and building weird/oddball stuff... and I do like a challenge
[Re: MR_P_BODY]
#1278267
08/12/12 08:48 AM
08/12/12 08:48 AM
Posts: 2,364 PA
70HemiGTX
PA
It's like when I finish a project and it is ready to run, it just seems to have an anti-climactic moment. I just need to find another project to work on. With the exception of the yard.....
[Re: MR_P_BODY]
#1278269
08/12/12 01:45 PM
08/12/12 01:45 PM
Triple Threat
Renton Washington
Mike,
I can tell you're a guy that likes to be busy and tinkering on things though. You'll always find something to build one way or another. Where most guys buy the part, you will build it.
You're reaching the light and the end of the tunnel!
[Re: Triple Threat]
#1278270
08/12/12 02:03 PM
08/12/12 02:03 PM
MR_P_BODY
Well all the rockers are oiling now... and holding good pressure... at about 600 rpm(crank) its 75# just need to put the pan back on and the intake and adjust the rockers... oh yeah put the headers on and its set to go to the dyno tomorrow for set up... hopefully be on the dyno Tuesday... need to gather up some parts and stuff to take to the dyno... jet box and the 1050 with adapter... few sets of plugs... I'll take my timing light also just to verify we both read the same...I think thats about it
[Re: Triple Threat]
#1278271
08/12/12 02:08 PM
08/12/12 02:08 PM
MR_P_BODY
Mike,
Yeah I love tinkering and building stuff... LOL... I'm just a cheap bast*&d... naa... I like making stuff
[Re: MR_P_BODY]
#1278272
08/12/12 04:14 PM
08/12/12 04:14 PM
MR_P_BODY
Little change in plans... I think I'm gonna drop the engine off on Tuesday... suppose to rain here tomorrow so I dont want to take it on my small open trailer and my small enclosed doesnt have any hold downs so tomorrow I'll get some hold downs mounted in the enclosed... gotta see when I can get on the dyno ... the other day when I was there he had 2 engines going on and they were pretty busy... all I need to do is mount the water pump and motor plate but right now the paint is drying so I think its time to kick back and watch some racing and suck down a few brews
