Re: Factory cross bolted 4 bolt main RB block [Re: autoxcuda] #1277981
08/03/12 03:35 PM
08/03/12 03:35 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
And no casting numbers...
Fall Fling 28 October 19, 2024 at Woodley Park, Van Nuys CA
300+ Mopars, 125+ swap, midway, Friday Malibu cruise,
Re: Factory cross bolted 4 bolt main RB block [Re: autoxcuda] #1277982
08/03/12 03:50 PM
08/03/12 03:50 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
And no VIN or VIN pad...
I think this was someone's heavy handed approach to saying,
"NOT FOR RESALE"
...no $h!t !!
Re: Factory cross bolted 4 bolt main RB block [Re: autoxcuda] #1277983
08/04/12 12:57 AM
08/04/12 12:57 AM
State of Fascism
52savoy Offline
52savoy  Offline
State of Fascism
Chrysler recommended Marine block pn3690030 for Grand National racing. The HEMI fuel block was 3690010
No (normal)casting numbers
Some Marine blocks had the webbing on the skirts and some not. Some had webbing and 2 or 4 bolt mains.
Curious
http://www.justanswer.com/boat/3xm5m-recently-purchased-426-chrysler-engine-told.html
the old moparts discussion I mentioned: https://board.moparts.org/ubbthreads/showflat.php?Cat=0&Number=6151728&Main=6151567
It correlates for me
Re: Factory cross bolted 4 bolt main RB block [Re: Bishop] #1277984
08/04/12 01:53 AM
08/04/12 01:53 AM
AndyF Offline
AndyF  Offline
Cool deal. I saw one of those blocks about 20 years ago in a guy's garage when I went to buy some parts. That was before digital cameras or cell phones so I wasn't able to get a picture. But it was the same deal. Wedge block with cross bolted mains and a 1964 date stamp. He said he had gotten it from a NASCAR guy.
Re: Factory cross bolted 4 bolt main RB block [Re: AndyF] #1277985
08/05/12 12:29 PM
08/05/12 12:29 PM
Cincinnati OH
Bishop Offline OP
Bishop  Offline OP
Cincinnati OH
Well I plan on taking it to the Mopar nats and seeing if some of the old timers can shed some light on this block! Thanks for all the replies.
Brian
Re: Factory cross bolted 4 bolt main RB block [Re: Bishop] #1277986
08/05/12 09:58 PM
08/05/12 09:58 PM
Cincinnati OH
Bishop Offline OP
Bishop  Offline OP
Cincinnati OH
It must be worth something to someone I just had a PM offering me 5K for the block, what is this thing?
Brian
Re: Factory cross bolted 4 bolt main RB block [Re: Bishop] #1277987
08/05/12 10:08 PM
08/05/12 10:08 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Here's a couple questions for you (again) can you please post pics of the stampings and any other numbers you found? Was there anything special about the 64 Plymouth it came out of (trunk).
Re: Factory cross bolted 4 bolt main RB block [Re: Bishop] #1277988
08/05/12 10:08 PM
08/05/12 10:08 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
Brian
Call Herb Mcandless, his son is on moparts maybe he can chime in and get him to look at the pics here. or speak with him at the Nats.
MLR426
Re: Factory cross bolted 4 bolt main RB block [Re: MLR426] #1277989
08/06/12 01:22 AM
08/06/12 01:22 AM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
IIRC in mid 71 Chry made a small run (100 or so)of 426 wedge blocks for Nascar and drag racing.I can't recall if the bosses for the cross bolts were cast in.I do believe there was also some IND and Marine 426's that included the bosses for the cross bolted mains.I rebuilt a pair of Marine 426 many years back that had the cross bolted mains but the rest of the parts were 426 S type parts plus the marine gear and the gear drive for the reverse rotation required for one of the dual marine engines.
Leave the gun.......take the Cannoli's....Mike
Re: Factory cross bolted 4 bolt main RB block [Re: mike s] #1277990
08/06/12 10:28 AM
08/06/12 10:28 AM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Dan Dvorak ran a '70s cast 4.25" block in his cars. The thing that made it better than a typical '60s cast 426 block was it used a 440 water jacket making the cylinder walls an extra .070 thicker. Dvorak did have a cross bolt wedge block at one time but I believe it was a converted Hemi block.
Back in the days before aftermarket BB wedge heads, I saw a set of heads that had no casting numbers, the external appearance of a 452 head and Max Wedge size ports. The owner was from NC and said they were used by Petty after the Hemi was banned and before the small block program started.
Re: Factory cross bolted 4 bolt main RB block [Re: mike s] #1277991
08/06/12 11:38 AM
08/06/12 11:38 AM
State of Fascism
52savoy Offline
52savoy  Offline
State of Fascism
Read my post.... 426 wedge block pn3690030
Re: Factory cross bolted 4 bolt main RB block [Re: Bishop] #1277992
08/06/12 10:36 PM
08/06/12 10:36 PM
Chicago
curbman68 Offline
curbman68  Offline
Chicago
Brian
Should have taken that money and ran.
Re: Factory cross bolted 4 bolt main RB block [Re: curbman68] #1277993
08/07/12 07:10 PM
08/07/12 07:10 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
Brian
i agree..
Re: Factory cross bolted 4 bolt main RB block [Re: ph23vo] #1277994
08/07/12 08:08 PM
08/07/12 08:08 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Brian
i agree..
I'd have been on his doorstep and given him a big kiss to boot !
