Re: Thermoquad issues.... [Re: kilroy] #1277729
08/01/12 10:12 PM
08/01/12 10:12 PM
Stone Mt, GA.
DEMONSIZZLER Offline
super gas
super gas
Stone Mt, GA.
Thanks kilroy!
Yes as Kilroy said, if the accelerator pump shot is weak and not a solid stream for the whole duration of the accelerator pump travel, that will cause a big bog. Check the pump shot with the engine off and you can see the stream better. The pump well needs to be totally free of dried gas, corrosion and the plunger(viton rubber or leather)must be in very good shape to function properly in the well id. You can take the id of the well and clean it with a piece of 600 grit sandpaper with light oil on it. Just don't gouge the well id but clean it up if needed.
You can knock out the pump with a punch or #2 Phillips screwdriver by knocking on the top side of the end of the pump stem.
Re: Thermoquad issues.... [Re: DEMONSIZZLER] #1277730
08/02/12 08:11 AM
08/02/12 08:11 AM
Lexington NC
twinscrew698 Offline
Lexington NC
Welcome back Demonsizzler!!
Good to see your input here!
Re: Thermoquad issues.... [Re: twinscrew698] #1277731
08/02/12 01:07 PM
08/02/12 01:07 PM
Tennessee
meep_meep Offline OP
Tennessee
ok folks, i got the top off the carb...the pump plunger looks to be in great shape...But i think i found the problem....I read that i should have a setting of 27/32nds on the floats, i have almost an inch and a 1/4 on both floats...this would most definitely cause a lean issue and poor pump shot lol
I need to verify that 27/32nds is the correct setting on the floats...
Re: Thermoquad issues.... [Re: meep_meep] #1277732
08/02/12 01:15 PM
08/02/12 01:15 PM
Tennessee
Tennessee
here's what i have....
Re: Thermoquad issues.... [Re: meep_meep] #1277733
08/02/12 02:09 PM
08/02/12 02:09 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
I think i'm gonna replace the pump plunger, and take a look at the transfer tube also...thanks for the tip on that
While the top of the carb is off, carefully inspect the pump plunger bore in the casting for heavy pitting. This will cause some pump issues.
Re: Thermoquad issues.... [Re: Dave Watt] #1277734
08/02/12 02:10 PM
08/02/12 02:10 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
I'm also wondering if the metering rod tree is adjusted properly. This can be a throttle transition problem.
Re: Thermoquad issues.... [Re: Dave Watt] #1277735
08/02/12 02:12 PM
08/02/12 02:12 PM
Tennessee
Tennessee
the plunger looks to be in new condition...no pitting at all, same story with the rest of the carb internals..i believe it's had a recent rebuild...but they forgot to set the floats correctly...
Re: Thermoquad issues.... [Re: Dave Watt] #1277736
08/02/12 02:13 PM
08/02/12 02:13 PM
Tennessee
Tennessee
I tried multiple settings on the tree, it made no difference...
Re: Thermoquad issues.... [Re: meep_meep] #1277737
08/02/12 02:14 PM
08/02/12 02:14 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
The plunger seal itself or the aluminum bore where the plunger rides? The aluminum bore in the carburetor top can't have any pitting.
Re: Thermoquad issues.... [Re: Dave Watt] #1277738
08/02/12 02:19 PM
08/02/12 02:19 PM
Tennessee
Tennessee
the shaft hole/bore is in good shape, verified this by hand...the plunger goes up/down smoothly....
Re: Thermoquad issues.... [Re: meep_meep] #1277739
08/02/12 03:15 PM
08/02/12 03:15 PM
Tennessee
Tennessee
fixed it
I set the floats at 29/32nds....she's running good now...thanks for all the help folks..
video
Re: Thermoquad issues.... [Re: meep_meep] #1277740
08/02/12 05:55 PM
08/02/12 05:55 PM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
SUHWEET!!! Sounds real good!!
Thanks for the followup.
John
Re: Thermoquad issues.... [Re: SattyNoCar] #1277741
08/02/12 05:58 PM
08/02/12 05:58 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Did you make any of the other suggested changes or did simply adjusting the floats fix the problem?
Re: Thermoquad issues.... [Re: ScottSmith_Harms] #1277742
08/02/12 06:02 PM
08/02/12 06:02 PM
Tennessee
Tennessee
I only adjusted the floats, since it was obviously the problem after inspection of the pump plunger turned out negative(it was in good shape)
Re: Thermoquad issues.... [Re: meep_meep] #1277743
08/02/12 09:57 PM
08/02/12 09:57 PM
Iowa State fan
kilroy Offline
kilroy  Offline
Iowa State fan
Excellent catch!!!!
I was half right sort of.
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
