Page 2 of 3 1 2 3
Re: Firm Feel sector support kit. [Re: jcc] #1274775
08/18/12 12:15 PM
08/18/12 12:15 PM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
but even the shaft itself has some flex. The new 3rd bearing cuts that to near zero.
Rick
Its difficult to imagine a sector extending 1.5"?
and 1"+ in diameter, mainly torsionaly loaded, flexing any significant amount, worth correcting. The mounting is another story however, imo. I have read the numerous positive comments others have made, and suspect it offers an improvement. But "sector" flex is not the problem being solved. I do suspect that by using the sector as leverage arm mounting point to negate the oem cantilever sector box design, that this add on fix may now INCREASE actual sector flex. However I can't believe this miniscule increased sector flex, if even measurable, would be a hindrance, and that this likely stops the entire unit from moving a great deal, and is therefore a positive trade off. I guess my biggest complaint is the label "sector support kit" is misleading, it is not as I see it, bracing the sector, but simply using the sector as an effective anchoring point.
Yours truly as always
4.599
The bottom line: Just raise the hood of any muscle-era stock Mopar with the tires on the ground. Move the s/ wheel a few inches CW and CCW. You'll see the flex...it will be very apparent. it doesn't really matter what the source of the flex is (probably 95% K, 5% chuck). Now bolt on the FFI kit. Flex almost totally gone.
Yes, I admit copying this from the truck guys. I even tried to get the truck guys to make the kit before I offered the idea to FFI. I went over all that in the original article.
Rick
Re: Firm Feel sector support kit. [Re: Rick_Ehrenberg] #1274776
08/18/12 01:53 PM
08/18/12 01:53 PM
Santa Fe Springs, CA
Dan@Hotchkis Offline
Rick
4.599
Rick
I've seen the kit before and it really interested me. I'm going to throw a runout gauge on the car next time I have it on the drive-on lift.
Re: Firm Feel sector support kit. [Re: Dan@Hotchkis] #1274777
08/18/12 02:39 PM
08/18/12 02:39 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
Rick
4.599
Rick
You will be my hero.
I try not to repeat myself, but there is little doubt the add on stiffens the assembly, flex of the shaft and now the newly discovered bearing slop is the meat of my beef.
I suspect the most difficult decision on the run out test will be what to use as a base measuring point, hope at least one of those is on the housing right next to the sector.
Regardless i'll. Hip in on six pack of diet dr pepper.
Re: Firm Feel sector support kit. [Re: MoparMarq] #1274778
08/24/12 05:55 PM
08/24/12 05:55 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Rick
Thanks for clearing that up. The brace was invented about a decade ago by a clever guy named Darin. The problem trying to be solved that gave birth to the idea was death wobble and steering wander on 4x4 Dodge Rams with the mighty Cummins under the hood. The invention was 1st posted on the Turbo Diesel Register back then. Darin was making them for a while, but eventually these guys took over production and marketing -
http://www.solidsteel.biz/
Does it work? Like Richard said, take a look at the sector shaft while turning the steering wheel back and forth with the engine running. It ain't pretty. Will you feel the difference? Yes, but only if you drive fast enough. Just like people who put disc brakes on the rear of their Mopar and say they can't stop any faster, you will only feel the difference when driving on the edge of traction during braking or corning. That only happens during panic stops or on a race track.
Re: Firm Feel sector support kit. [Re: Lefty] #1274779
08/24/12 06:01 PM
08/24/12 06:01 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
Yea, my rear disks really improved my traction.
Re: Firm Feel sector support kit. [Re: jcc] #1274780
08/24/12 06:15 PM
08/24/12 06:15 PM
Lefty Offline
Lefty  Offline
I'm talking about being able to feel when the rear tires are just on the edge of locking up and being able to modulate the brakes so they don't lock up the wheels. It's easier to do/feel with rear disc brakes vs rear drums.
Re: Firm Feel sector support kit. [Re: Lefty] #1274781
08/24/12 06:20 PM
08/24/12 06:20 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
Re: Firm Feel sector support kit. [Re: Lefty] #1274782
08/25/12 01:24 PM
08/25/12 01:24 PM
Marlboro, NY, USA
Marlboro, NY, USA
This gets complicated. Bottom line: The Bendix duo-servo setup 99% of us have on the rear was designed, originally, to be heavily self-energizing so medium-weight cars would stop OK w/o a booster. The flip side of this is that they are very difficult to modulate near the max-G "lock point". You really need to be a near-pro to drive (read: threshold brake) these near the limit. There really wasn't a big fade issue, and weight-wise, cheapo disc setups are similar. It was the ease of "near the limit" modulation that finally convinced me to 4-wheel disc on most of my Mopars.
Rick
Re: Firm Feel sector support kit. [Re: Rick_Ehrenberg] #1274783
08/25/12 04:13 PM
08/25/12 04:13 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Rick
How would you identify a "cheepo rear disc setup" that doesn't modulate well to one that does?
Re: Firm Feel sector support kit. [Re: autoxcuda] #1274784
08/25/12 05:27 PM
08/25/12 05:27 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
"and weight-wise, cheapo disc setups are similar"
Re: Firm Feel sector support kit. [Re: Rick_Ehrenberg] #1274785
08/25/12 05:35 PM
08/25/12 05:35 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
This gets complicated. Bottom line: The Bendix duo-servo setup 99% of us have on the rear was designed, on, and weight-wise, cheapo disc setups are similar. It was the ease of "near the limit" modulation that finally convinced me to 4-wheel disc on most of my Mopars.
Rick
I say this jokingly, blah, blah, blah. Botomline, if your rears are locking up first, your fonts aren' t working hard enough. Any modulation should be of the fronts, and discs shine in THAT. use.
Re: Firm Feel sector support kit. [Re: autoxcuda] #1274786
08/26/12 10:57 PM
08/26/12 10:57 PM
Marlboro, NY, USA
Marlboro, NY, USA
I wouldn't! The cheapo ones I'm referring to use Eldo or Exploder calipers, Ford or Cherokee rotors, etc. They generally work fine, they're just no lighter than the drum setups. Either way, the ease of precise modulation is there -- they are dead linear: EG: 2X line pressure = 2X clamping torque.
Rick
Re: Firm Feel sector support kit. [Re: Rick_Ehrenberg] #1274787
08/26/12 11:15 PM
08/26/12 11:15 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Rick
Thank you for clarifying.
Re: Firm Feel sector support kit. [Re: autoxcuda] #1274788
02/10/14 02:28 AM
02/10/14 02:28 AM
Berwyn, IL
challenger70 Offline
Berwyn, IL
Is this worth doing in addition to the firm feel K-member welding and reinforcement? Dick talked me out of it, but it seems like this might help too.
Re: Firm Feel sector support kit. [Re: challenger70] #1274789
02/11/14 04:41 AM
02/11/14 04:41 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
I run the entire Firmfeel setup on my 71 RR. I had a figment issue as well. with the cr sterling box and pitman arm I really didn't feel a differance.
Re: Firm Feel sector support kit. [Re: dart4forte] #1274790
02/18/14 03:31 PM
02/18/14 03:31 PM
Lakeland FL
floridian Offline
floridian  Offline
Lakeland FL
Can this be used with the Borgeson steering box?? Not sure what pitman arm is used on the mopar/borgeson install??
Re: Firm Feel sector support kit. [Re: floridian] #1274791
02/19/14 12:06 AM
02/19/14 12:06 AM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
any one you want, doesn't need a special one, just make sure you buy a pitman that matches your sector (large or small)
Re: Firm Feel sector support kit. [Re: dangina] #1274792
02/21/14 11:25 AM
02/21/14 11:25 AM
Lakeland FL
floridian Offline
floridian  Offline
Lakeland FL
OK, I meant does the Borgeson box use a stock mopar pitman arm or something different..
Per your comment does the borgeson box come with the small and large shaft for the older and newer pitman arms??
Re: Firm Feel sector support kit. [Re: floridian] #1274793
02/21/14 01:14 PM
02/21/14 01:14 PM
dangina Offline
dangina  Offline
Yes it uses the stock pitman arm. Comes in both sizes, small and large sector. Just pick the one you want when ordering.
Re: Firm Feel sector support kit. [Re: dangina] #1274794
03/21/14 01:43 PM
03/21/14 01:43 PM
VT
Mike Roberge Offline
VT
Yes, Dick’s selector support does work with the Borgeson box.
I installed one on my ’71 Charger last fall. It bolted up just as if it were connected to a stock Mopar steering box.
Michael Roberge '71 Charger R/T 440 4bbl, 500HP/500Ftlb Best ET: 11.590 120MPH
Page 2 of 3 1 2 3
