electric fuel pump leaking ideas ??
#1272952
07/23/12 10:32 PM
07/23/12 10:32 PM
Posts: 1,757 levittown pa
fstfish66
levittown pa
i am looking for any ideas,,,
i have installed a carter elec fuel pump at the tank on my coupe,,it already had an elec pump on the frame when i bought it,,its too close to the motor but keeping it as a back up,,
so i try to do things per the instructions,,even when i think i know better,,, ive looked at several cars lately with the same pump,they all had liquid teflon sealant,, the instructions say NO TEFLON TAPE or sealant needed,,,just re-tighten as needed,, well that didnt work,,, so i used liquid teflon i let it set up for over a week,,,i still have a super tiny leak enough to make it damp around the fitting on the metal housing of the pump....the pump that was already there has some sort of dark gray sealant,,,any one know what it might be ?? or what would WORK ?? thank you in advance
1966 barracuda prostreeter super charged 340(SOLD) 1940 dodge coupe 241 hemi street rod 2014 ram express hemi 4x4 dailey driver 2015 cherokee 2013 R/T classic
Re: electric fuel pump leaking ideas ??
[Re: Hemi Allstate]
#1272954
08/03/12 02:47 AM
08/03/12 02:47 AM
fstfish66
levittown pa
thanks,,,, sorry i didnt see your reply sooner,, after trying it dry per the instructions,,,that failed,,,then liquid teflon failed,,, i said what the heck,,, cleaned every thing off..2 wraps of teflon tape,,,dry as a bone good to go but i will make a note of the permatex,,,thanks
now on to the other problems,,,lol
