Re: Building a custom Fan Shroud: Pic by pic
[Re: autoxcuda]
#1272418
07/25/12 06:37 AM
07/25/12 06:37 AM
Posts: 1,880 Out in Left Field, NY
bobs66440
I always thought distilled water was best also, but after some research I ended up using drinking water (purified by reverse osmosis) and No-Rosion which is probably similar to what you are using to protect the aluminum radiator. He said it would also bring the temp down 10 degrees, but it didn't. Here's an excerpt from their site. I'm not an expert by any stretch, and I'm not saying it's gospel but it sounded plausible... Q. Should I use distilled water as coolant? A. Yes. But only in a 50/50 mix. Distilled water should not be used as straight water coolant, because it can cause damage to system metals. The reason has to do with how distilled water is created. During the distillation process, water is vaporized into its gaseous phase, so all impurities are left behind. These impurities include a number of minerals, including calcium and magnesium, the two components of hardness. The water is then condensed back into its liquid phase, so the resulting liquid is pure water. In fact, some of the purest water on earth. The problem is that distillation strips impurities from water, resulting in water molecules that are electrochemically imbalanced. So distilled water will actually strip electrons from the metals in a cooling system as it attempts to rebalance itself electrochemically. This can result in damage to metals in a cooling system. Using distilled water in combination with 50% antifreeze effectively cuts the amount of distilled water in half. By compounding with glycol, it will not cause damage to metals in a cooling system. For this reason, it is safe to use distilled water in a 50/50 mix. Q. What type of water is best to use as straight water coolant? A. Reverse osmosis (RO) water. Rather than stripping impurities from water, RO filters them through a membrane. The resulting water is electrochemically stable, and not harmful to metals in a cooling system. RO water is every bit as pure as distilled water, but without the risk of electrochemical stripping of electrons from system metals.
Q. Where can I find reverse osmosis (RO) water? A. At the local supermarket. Look for DRINKING WATER, which is available in gallon bottles. But do not confuse it with SPRING WATER, which is often high in mineral content. We have performed extensive testing of major brands and generic brands of bottled drinking water, and found that it is almost always composed of RO water.
Q. What are the benefits of using purified water, such as distilled or RO? A. It lacks the impurities of tap water. Without impurities, its ability to function as an electrolyte is greatly diminished, thereby minimizing damage from electrolysis. It contains no hardness, meaning it will not form scales and deposits that can cause overheating. It does not contain other damaging contaminants, such as chloride or sulfate. And importantly, it enhances the overall performance of No-Rosion, allowing it to more effectively function and provide the full range of benefits that it has been engineered to provide.http://www.no-rosion.com/
[Re: jcc]
#1272422
07/25/12 11:48 PM
07/25/12 11:48 PM
Posts: 27,483 So Cal
autoxcuda
So Cal
So I got it all together and tested it. It was 92 degrees in my garage when I started it up. I figure if I went this far, I was really going to test it. I've been a S-O-B to this car for 19 years, why should I stop now ![](/ubbthreads/images/graemlins/shruggy.gif) .... I let it idle for 25 minutes not moving it an inch in the garage! ![](/ubbthreads/images/graemlins/devil.gif) The front of the car was 1 1/2 ft from my washer and dryer. So no wind to help it. Even though the garage door was open, after 25 minutes my eyes would tear up if I stayed in there too long. After 25 minutes, the car raised the temp in the whole garage to 98 degrees. RESULTS 1) After 10 minutes idling, temp measured on heat gun was 160 deg. at the temp sender. 2) After 25 minutes idling, temp measured on heat gun was only 203 deg. at the temp sender. Turned it off and no boilover whatsoever. I didn't think that was bad given the extreme abuse. It was a fricken nauseous sauna in there. ![](/ubbthreads/images/graemlins/boogie.gif) I think it did really well for such an extreme test ?? Here's a picture showing the suction of a paper towel on my grille at idle and the ambient temperature there.
[Re: autoxcuda]
#1272424
07/26/12 07:21 PM
07/26/12 07:21 PM
Posts: 28,071 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
it would cool better if you got that paper towel off the grille. ![](/ubbthreads/images/graemlins/biggrin.gif) Do you have a lower air dam on the car?
[Re: feets]
#1272425
07/27/12 02:25 AM
07/27/12 02:25 AM
autoxcuda
So Cal
No I don't have a lower air dam. 67-69 Barracuda have a lower valence with a large opening. I was going to put a spoiler on the lower valance, and I thought it would divert more air into radiator.
But I don't currently have any cooling issues whatsoever if the car is moving, forcing more air into the radiator.
