69 393 HP - oil pickup help
#1271320
07/20/12 10:44 PM
07/20/12 10:44 PM
Posts: 252 Seattle, WA.
edp
Seattle, WA.
I have an oil pickup tube like this except bent & am wondering if the mopar performance one is the actual replacement for the HP motor w/windage tray. Jeg's said they use a stock photo so just wondered of anyones ordered this from Summit or Jeg's & received the wrong one. summit shows this....I need this style mopar performance via Jeg's shows this.... I assume the top one is correct for the windage tray style, is that accurate? Thanks ,evan
Re: 69 393 HP - oil pickup help
[Re: edp]
#1271321
07/20/12 11:58 PM
07/20/12 11:58 PM
moparpollack
Lil Herman
Lil Herman
85086
The stock mellings are straight like the mopar performance. My machinist has the oil pick up I ordered from summit racing. When I get home from vacation I will see if it fits the 402 pan correctly.
[Re: JohnRR]
#1271324
07/22/12 04:33 PM
07/22/12 04:33 PM
edp
Seattle, WA.
thanks John, I do have the 402 pan so how do I know which part # is the correct one? MP # is P5007848 on summits site, will that be the curvy one in the pic or the straight one? i should of said before both sites show the same part number but different pic's.
I did search the google box & I guess there's multiple questions about the oil pickup confusion.
[Re: edp]
#1271325
07/22/12 08:36 PM
07/22/12 08:36 PM
Posts: 75,098 A Banana Republic near you.
JohnRR
all you did was show pictures , I told you which picture was the correct one , you did not include a part number or links to an item , the part number you just gave is the WRONG part , the picture doesn't matter.
The pickup for the 402 pan is P4529564
http://www.summitracing.com/search/?keyword=P4529564&dds=1
[Re: JohnRR]
#1271326
07/23/12 01:48 AM
07/23/12 01:48 AM
edp
Seattle, WA.
thanks for the part number for the 402 pan pickup, appreciate it. The only reason I showed the picture of the top pickup that's curved is because it looks EXACTLY like the one that came out of my motor hence my thinking about the part # that shows it as a P5007848. http://www.summitracing.com/parts/DCC-5007848/Application/?prefilter=0 whereas the other sites show a straight pickup as the same #- I just didn't know which one is correct. Perhaps the one that came out of my motor wasn't correct in the first place, I don't know as i haven't taken a 383 apart before. thanks again for the part number.
