Re: vibration update on the cuda
[Re: sleepyhead416]
#127084
12/21/08 12:14 PM
12/21/08 12:14 PM
Posts: 2,617 Stratford nj
cudadan
Stratford nj
Any UPDATE dan ??
not yet the motor will be out just after xmas, and the 340 goes in. hopefully by the end of next week i'll have an update
[Re: sixpackgut]
#127085
12/21/08 12:16 PM
12/21/08 12:16 PM
cudadan
Stratford nj
Since you swapped out every other thing, I would think a motor swap would not be much more work at this point.
thats what im gonna do, im putting in a bad a$$ lil 340 to check, probably right after the holidays. 340 is for sale too.
your going to sell a 340 ci vibrator?
do you have a pulley on the balancer?
the 340 doesnt vibrate its the 360 that does,,
and i know its not the wrong flexplate cause its been in the car for 5 yrs
[Re: PC-CHARGER]
#127087
12/21/08 01:16 PM
12/21/08 01:16 PM
cudadan
Stratford nj
I can't recall which flex plate you had and I don't feel like reading 6 pages to find out if it was a weighted unit but I assume you do know that generally a 340 is internal balance and 360's are external balance? As such, they require specific harmonic balancers and converters/flex plates. If you install a converter that is neutral balanced on a 360 that requires an externaly balanced converter and damper, it will shake like he!! Same thing the other way.
i do have all the correct stuff for the 360, as for ther 340 im using everything from that motor,,,
LOL fred
[Re: cudadan]
#127090
01/05/09 11:13 PM
01/05/09 11:13 PM
Posts: 15,493 the boonies
aarcuda
the boonies
well i got the 340 in the cuda and the vibes arrrrrrrrrrrrrrrrrrrrrrrre alllll gone. so somehwere in the motor something is letting go, gone pull the bottom end apart sometime this week to see whats going on finally i can sleep at night lol, thx for all the help guys
wait a minute. you mean you dont know what it was yet? why you little
[Re: aarcuda]
#127091
01/05/09 11:16 PM
01/05/09 11:16 PM
Triple Threat
Renton Washington
Wow, Glad to see you got the issue resolved. Only could wish it would have been easier. Now my car, it still vibrates, let me know when you wanna help track that one down.
[Re: cudadan]
#127092
01/05/09 11:40 PM
01/05/09 11:40 PM
Posts: 2,537 PORT ALBERNI , BC., CANADA
superwrench
This is getting interesting. I'd sure like to know what could cause a vibration like that "internally"....woulda been the last place I'd have looked. Whad'ya think?......what could "Loose" or "Gain" weight to unbalance the engine? It's gotta be something stupid like a blown intake gasket/head gasket.
Post deleted by Defbob
[Re: superwrench]
#127093
01/06/09 03:08 AM
01/06/09 03:08 AM
#127094
01/06/09 07:48 PM
01/06/09 07:48 PM
cudadan
Stratford nj
good lord it only took 6 months
hell i think it was longer than that, hey Fred ya got a spare HEMI laying around lol
[Re: RyanJ]
#127097
01/11/09 11:27 AM
01/11/09 11:27 AM
cudadan
Stratford nj
That's all you found a spun cam bearing????
Does this motor have a gear drive on it?
,, visually thats all i saw wrong, just the cam bearing, the center one walked and covered the oil hole, no gear drive. gonna have the crank spun and the rods checked this week,, i have another 360 i just picked up friday im gonna use.
