Page 9 of 12 1 2 7 8 9 10 11 12
Re: vibration update on the cuda [Re: flatiron] #127024
11/26/08 06:53 PM
11/26/08 06:53 PM
Stratford nj
cudadan Offline OP
cudadan  Offline OP
Stratford nj
i swear im losing sleep over this, i just can't believe how long ive had this problem., just hopefully when i try this other trans it goes away, i need to race LOL
Re: vibration update on the cuda [Re: cudadan] #127025
11/27/08 04:21 AM
11/27/08 04:21 AM
las vegas
70challenger408 Offline
las vegas
dan, I posted with the same problem on my challenger this past summer. I have changed every thing from the flex plate back, with the same results as you. The only thing left is the rear diff housing. I was looking for Santa to leave a new Moser housing under the tree this year LMAO.
scott
Re: vibration update on the cuda [Re: 70challenger408] #127026
11/27/08 10:02 AM
11/27/08 10:02 AM
Stratford nj
cudadan Offline OP
cudadan  Offline OP
Stratford nj
scott
LMAO well if this other trans doesnt do it, i have another housing thats getting powerder coated next week, but i dont really think its the housing if it still has the vibes without the axels in it on the jack stands, still gonna change it anyway, i also measured the wheel base the other day and there was only 1/8" of a difference between sides.
Re: vibration update on the cuda [Re: cudadan] #127027
11/27/08 10:07 AM
11/27/08 10:07 AM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
I hope the trans works for you Dan and all your questions get answered.
Re: vibration update on the cuda [Re: scatpacktom] #127028
11/27/08 10:17 AM
11/27/08 10:17 AM
Stratford nj
cudadan Offline OP
cudadan  Offline OP
Stratford nj
you and me both, lol thx again to everyone for all there help.
Re: vibration update on the cuda [Re: cudadan] #127029
11/27/08 11:07 AM
11/27/08 11:07 AM
PA USA
flatiron Offline
flatiron  Offline
PA USA
I'm just curious have you ran this car down the strip while this problem's been going on. I'm half scared to drive mine.
Re: vibration update on the cuda [Re: flatiron] #127030
11/27/08 01:04 PM
11/27/08 01:04 PM
mass,usa
sickhemi Offline
sickhemi  Offline
mass,usa
i think it's the output shaft. any chance you had two bent ones? when you changed the driveshaft did you use the same front yoke or did you use a different one?
1968 gts 355 r3 six speed efi with irs in progress and 1969 convt 440 stage 6 efi 5spd dana
Re: vibration update on the cuda [Re: flatiron] #127031
11/27/08 10:40 PM
11/27/08 10:40 PM
Stratford nj
cudadan Offline OP
cudadan  Offline OP
Stratford nj
yeah it its scary at 110mph
Re: vibration update on the cuda [Re: sickhemi] #127032
11/27/08 10:41 PM
11/27/08 10:41 PM
Stratford nj
cudadan Offline OP
cudadan  Offline OP
Stratford nj
anything is possible, with all of the driveshafts i've tried they all had there own yoke on them, with the same results
Re: vibration update on the cuda [Re: cudadan] #127033
11/27/08 10:53 PM
11/27/08 10:53 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
i havent read this whole thread,did you find your problem??
Re: vibration update on the cuda [Re: MIKES_DUSTER] #127034
11/28/08 09:07 AM
11/28/08 09:07 AM
Stratford nj
cudadan Offline OP
cudadan  Offline OP
Stratford nj
wish i did Mike, im getting ready to leave to pick up another trans to try that, keep your fingers crossed LOL
Re: vibration update on the cuda [Re: cudadan] #127035
11/28/08 09:11 PM
11/28/08 09:11 PM
Port Alberni, British Columbia
MoparDonny Offline
MoparDonny  Offline
You got that trans in yet, Dan? Ha ha!! JK!!
I hope you figure this out tonight! Good luck. You must be pulling your hair out by now.
Don.
Re: vibration update on the cuda [Re: MoparDonny] #127036
11/28/08 10:53 PM
11/28/08 10:53 PM
Stratford nj
cudadan Offline OP
cudadan  Offline OP
Stratford nj
Don.
i got it lol, just pulled the trans out of the car, and tomorrow morning the new one goes back in. please please please don't vibrate LOL i'll have an update probably by lunch time
Re: vibration update on the cuda [Re: cudadan] #127037
11/29/08 01:49 AM
11/29/08 01:49 AM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
Well...if it doesn't fix it, HemiFred seems like he's game for attending a Car-B-Cue!!
Good luck Dan....I can't imagine the frustration.
Re: vibration update on the cuda [Re: cudadan] #127038
11/29/08 01:50 AM
11/29/08 01:50 AM
fullmetaljacket Offline
Cudadan.
If you have an front engine plate holding your motor in place, you might want to make sure the motor is aligned with the propeller shaft and rear in the right orientation. I think I might have the same issues also with this.
Make sure your front end is tight and aligned.
Make sure your rear springs have no broken leafs.
Check the rear spring center bolt that centers the leafs onto the rear housing
Check the front rear spring hangers and the front rear spring eye bushing for wear.
Re: vibration update on the cuda [Re: fullmetaljacket] #127039
11/29/08 10:41 AM
11/29/08 10:41 AM
Stratford nj
cudadan Offline OP
cudadan  Offline OP
Stratford nj
well the trans is out, and i pulled the flexplate to get a better look at it and saw that 2 of the torque converter hole were a lil worn, and the other 2 are perfect, would the 2 hole that are perfect keep it all inline? not sure if this is the problem,
just went out and bolted the flexplate to the converter kept the bolts loose and i cant turn the flexplate on the converter it fits nice and tight no moverment
http://picasaweb.google.com/cudadan360/Flexplate?authkey=WKEd3o52m3Y#
Re: vibration update on the cuda [Re: cudadan] #127040
11/29/08 03:24 PM
11/29/08 03:24 PM
MoparDonny Offline
MoparDonny  Offline
Can't see that little bit of wear causing you any problems. Patiently awaiting some good news!!
Don.
Re: vibration update on the cuda [Re: MoparDonny] #127041
11/29/08 03:29 PM
11/29/08 03:29 PM
Stratford nj
cudadan Offline OP
cudadan  Offline OP
Stratford nj
well no good news just yet this other tranny slips, cant tell if im in 2nd or 3rd, but at 1800 rpms @35mph this trans doesnt vibrate at all, still dont know if its slipping so bad that i can set it where i want, so im gonna pull my manual vavle body and put it in the other trans so i know that i am in 3rd gear, i can't win i tell ya
Re: vibration update on the cuda [Re: cudadan] #127042
11/29/08 03:51 PM
11/29/08 03:51 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Unfing believeable
Re: vibration update on the cuda [Re: SomeCarGuy] #127043
11/29/08 04:01 PM
11/29/08 04:01 PM
Stratford nj
cudadan Offline OP
cudadan  Offline OP
Stratford nj
Unfing believeable
could'nt have said it better myself, gonna swap the valve bodys now so i know im in 3rd with the manual valve body
