Re: Horsepwer/torque gain with rear gear change ?
[Re: Mopardude440]
#1270299
07/19/12 02:54 AM
07/19/12 02:54 AM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
[Re: west]
#1270300
07/19/12 05:19 AM
07/19/12 05:19 AM
Posts: 28,633 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
It cant change H.P. but you will see a performance gain. I would recommend the 3:55
I agree you will not get more hp gain but the steaper gear set will tune your trans/ engine combo so it will perform better showing more power as a matched set I[ie} it it a matched set engine with right cam, trans rear Hope I making censer here changing from 323 to 355 is so little it will not help mubh at all and just mess up the speedo reading lol I have done it my self when I broke the 323 and had some 355 laying around and did not notice much if at all other than the speedo being off the big change was 323 to 391 and I liked that as with my cam and compression it when fine on 1-10 interstates well
[Re: 340SIX]
#1270301
07/19/12 09:29 AM
07/19/12 09:29 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
a gearset won't change the Hp/Tq that the chassis dyno actually sees? I always heard that it would, as gears "multiply torque" ![](/ubbthreads/images/graemlins/shruggy.gif) if it doesn't matter what the gear ratios are, then why do they always do the dyno pull in the 1:1 gear?
**Photobucket sucks**
[Re: 70Cuda383]
#1270303
07/19/12 10:26 AM
07/19/12 10:26 AM
Posts: 3,719 Space Station #5
471Magnum
Space Station #5
Actually, it does and they don't. Typically, the higher the gear (numerically lower), the lower the parasitic loss. Your 1:1 gear will give the least loss since everything is locked together inside the transmission. No gear friction. That being said, a qualified dyno operator should put the car in the safest gear. That would be one that won't exceed a tire speed rating, or allow an unintended down/up shift during the pull. In the case of a three speed auto, they often put it in second. A chassis dyno factors out gear ratio.
-Jim
I can fix it... my old man is a television repairman. He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
[Re: jcc]
#1270304
07/19/12 10:29 AM
07/19/12 10:29 AM
Posts: 214 Colo Springs, CO
DconD100
Colo Springs, CO
So...if you made a dyno pull in second gear, wouldn't be the same as pulling it in high gear with 4.68 gears? I always wondered if the final gear made a difference on a wheel dyno. Do they have to input final gear ratio and tire diameter before they start?
Pump Gas Small Blocks Rock!
11.53 @ 116mph E85 408 at 8500 ft da,
3605 pound truck, 3.91s, street driven
[Re: DconD100]
#1270305
07/19/12 10:42 AM
07/19/12 10:42 AM
The dyno knows the engine rpm and the tire speed, so the overall gear ratio (factoring in tire size) is a pretty simple mathematical computation.
No one has addressed the OP's real concern which is that he has a 510 horsepower engine which is only putting 310 horsepower to the rear wheels. That does seem like a pretty huge power loss through the drivetrain.
#1270306
07/19/12 11:02 AM
07/19/12 11:02 AM
DconD100
Colo Springs, CO
I realize that most of Kansas doesn't have a lot of elevation, but if the flywheel horsepower is a corrected number and the wheel horsepower is observed, that could explain some of the huge loss.
[Re: DconD100]
#1270307
07/19/12 11:56 AM
07/19/12 11:56 AM
471Magnum
Space Station #5
3.91s will theoretically give more parasitic than would 3.23s, all else being equal. Maybe 5%. Probably less.
What is type/brand of chassis dyno? Mustang dynos give notoriously conservative, but arguably more accurate numbers than a Dynojet.
Are those engine numbers verified on an engine dyno? If so, those chassis numbers are low regardless of dyno type or gear ratio. I would expect to see 400+. You've got some serious parasitic loss in the drivetrain. Bad bearings, brake drag, driveline misalignment, etc. Is AFR being monitored during the pulls and is it good?
-Jim
[Re: 471Magnum]
#1270312
07/19/12 02:07 PM
07/19/12 02:07 PM
DconD100
Colo Springs, CO
Also, the type of air filter, headers, and mufflers on the car compared to the engine dyno could cause some loss...especially if the air cleaner lid was so close to the carb it was choking it.
[Re: DconD100]
#1270314
07/19/12 02:38 PM
07/19/12 02:38 PM
70Cuda383
Marysville, O-H-I-O
and maybe it's a combo of a happy engine dyno and a stingy chassis dyno. if the engine dyno was reading 20-30 high, and the chassis is 20-30 low, that would also account for the variance.
If you really ARE losing that much Hp through the chassis, then start looking for problems...as mentioned, brakes dragging, driveline mis-aligned, bad bearings, maybe a bad torque converter, etc.
also, make sure nothing in the motor has gone bad from engine dyno to chassis dyno. if you are starting to wipe some lobes and have less lift now, or the the intake/exhaust is too restrictive, etc.
I know that how my engine was tested on the dyno, it'll NEVER see that kind of set-up in the vehicle unless I turned it into an all out race car. on the engine dyno there was no air cleaner whatsoever, no turbulance of intake air because there was no hood, no moving air over the carb, etc. just sitting static in a room. on the engine dyno it had the same headers as in the car, but they were open, with a vacuum system over the collector to take the fumes outside, vs a full exhaust in the car. it also had an electric water pump, with no other accessories, and the fuel pump, ignition, etc. was all driven by a stand-alone power source, so the flywheel hp was a pure, free number with NO loss anywhere.
add in a full exhaust, air cleaner, underhood turbulance, alternator, water pump, PS drag, and it wouldn't surprise me if suddenly my flywheel hp was down by 30, and I haven't even begun to account for parasitic loss through the transmission, U-joints on drive shaft, rear end bearings, inertia of the parts, etc.
