Re: new Moparts fastest car list, post yours!
[Re: gregsdart]
#12655
09/13/04 09:51 PM
09/13/04 09:51 PM
Currently 11.40 at 119.18 1.608 60' uncorrected at LACRs 3000 ft alt,weight w/o driver 3020 lbs. 360 w2 71 duster(no N.O.S)
[Re: tazmaniac]
#12656
09/13/04 10:29 PM
09/13/04 10:29 PM
Posts: 10,037 Frostbitefalls MN (Rocky&Bullw...
gregsdart
B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide & 1050 Dominator on gasoline
Atco 15/Nov. '03: 8.178 @ 167.12 mph, 1.139 60', 132.7 mph @ 1/8
Rapid588 93'Dodge Stealth, 8.24et 163mph, 1.15/60' ,2490lb, motor only.
"Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.68 156
Gregsdart 65 dart 8.77et 153.16mph, 3000 lbs, 2780 den altitude. NA 6/26/04
440Jim '69 Dart 9.83et 134. mph, 3150lbs, all motor
Bigcube '69 Dart 9.91et 137 mph, 2950lbs, all motor
TimMoffett 69 Charger 4-speed Street Car 10.68 @ 128.3, 1.54 60', 3900Lbs with full exhaust
68LAR '68 Road Runner 11.85ET 116.6MPH 3926LBS 1.65 60' 4 SPEED street car
LAR_414 1969 Dart GT 11.33 118.9mph 3350lbs race wt 1.60 60' 414 stroked smallblock w/ factory J heads, solid cam and pump gas
493Charger 68 Charger R/T auto. 493" 3750 LBS 1.65 60' 11.76 116.57
acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire, 9.81@137
Guys, please update this, i have done a couple, but not all! My main objective is to get a baseline of the engine combos that are on the board, so age of the run not important,body type is only weight related.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
[Re: gregsdart]
#12657
09/13/04 10:38 PM
09/13/04 10:38 PM
Posts: 3,104 Wheels up, MO
nhramark
Wheels up, MO
Rapid588 93'Dodge Stealth, 8.24et 163mph, 1.15/60' ,2490lb, motor only. "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.68 156 Gregsdart 65 dart 8.77et 153.16mph, 3000 lbs, 2780 den altitude. NA 6/26/04 NHRAMARK 70 Duster 3050 lbs, 540" Indy, 9.274 @ 145.76mph 440Jim '69 Dart 9.83et 134. mph, 3150lbs, all motor Bigcube '69 Dart 9.91et 137 mph, 2950lbs, all motor TimMoffett 69 Charger 4-speed Street Car 10.68 @ 128.3, 1.54 60', 3900Lbs with full exhaust 68LAR '68 Road Runner 11.85ET 116.6MPH 3926LBS 1.65 60' 4 SPEED street car LAR_414 1969 Dart GT 11.33 118.9mph 3350lbs race wt 1.60 60' 414 stroked smallblock w/ factory J heads, solid cam and pump gas 493Charger 68 Charger R/T auto. 493" 3750 LBS 1.65 60' 11.76 116.57 acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire, 9.81@137
[image]http://s1126.photobucket.com/user/nhramark1/library/Racing[/image]
9.100 @ 150 mph
5.780 @ 120 mph
[Re: nhramark]
#12658
09/13/04 10:44 PM
09/13/04 10:44 PM
Posts: 826 Georgia
66coronet
Georgia
Rapid588 93'Dodge Stealth, 8.24et 163mph, 1.15/60' ,2490lb, motor only. "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.68 156 Gregsdart 65 dart 8.77et 153.16mph, 3000 lbs, 2780 den altitude. NA 6/26/04 NHRAMARK 70 Duster 3050 lbs, 540" Indy, 9.274 @ 145.76mph 440Jim '69 Dart 9.83et 134. mph, 3150lbs, all motor Bigcube '69 Dart 9.91et 137 mph, 2950lbs, all motor TimMoffett 69 Charger 4-speed Street Car 10.68 @ 128.3, 1.54 60', 3900Lbs with full exhaust 68LAR '68 Road Runner 11.85ET 116.6MPH 3926LBS 1.65 60' 4 SPEED street car LAR_414 1969 Dart GT 11.33 118.9mph 3350lbs race wt 1.60 60' 414 stroked smallblock w/ factory J heads, solid cam and pump gas 493Charger 68 Charger R/T auto. 493" 3750 LBS 1.65 60' 11.76 116.57 acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire, 9.81@137 66coronet, SRheaded 440, auto, 3670lbs, mufflers and 10.5's 10.71 at 126 in the heat of summer
[Re: gregsdart]
#12659
09/13/04 10:47 PM
09/13/04 10:47 PM
Posts: 995 Boynton Beach, Fl
Rapid588
Boynton Beach, Fl
'Edit'
B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.178 @ 167.12 mph, 1.139 60'
93 Dodge Stealth - Supercharged 526ci Hemi 93 Dodge Daytona Top Sportsman injected 588 Hemi - plus a lil NOS 67 Hemi GTX (may the 4speed with you!)
[Re: Rapid588]
#12660
09/13/04 11:27 PM
09/13/04 11:27 PM
How come we're doing a new list ? B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.178 @ 167.12 mph, 1.139 60' Rapid588 93'Dodge Stealth, 8.24et 163mph, 1.15/60' ,2490lb, motor only. "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.68 156 Gregsdart 65 dart 8.77et 153.16mph, 3000 lbs, 2780 den altitude. NA 6/26/04 NHRAMARK 70 Duster 3050 lbs, 540" Indy, 9.274 @ 145.76mph 440Jim '69 Dart 9.83et 134. mph, 3150lbs, all motor Bigcube '69 Dart 9.91et 137 mph, 2950lbs, all motor TimMoffett 69 Charger 4-speed Street Car 10.68 @ 128.3, 1.54 60', 3900Lbs with full exhaust 68LAR '68 Road Runner 11.85ET 116.6MPH 3926LBS 1.65 60' 4 SPEED street car LAR_414 1969 Dart GT 11.33 118.9mph 3350lbs race wt 1.60 60' 414 stroked smallblock w/ factory J heads, solid cam and pump gas 493Charger 68 Charger R/T auto. 493" 3750 LBS 1.65 60' 11.76 116.57 acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire, 9.81@13712.466 @ 108.98 (1.764 60') Greg J, 69 Road Runner 3850 # w/driver, 446, stock 4bbl intake, 452 heads w/ stock size valves, .484 purple cam , street tires, through full length exhaust, pump gas, all motor. Passes state emissions test. Idles in traffic in 110° weather. As usual I'm the slowest
#12661
09/14/04 01:07 AM
09/14/04 01:07 AM
Posts: 8,182 Detroit, MI
CokeBottleKid
Detroit, MI
Does it count if you haven't driven your car yet ? The Haze 8.02 @ 174+ twin turbo 452" B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.178 @ 167.12 mph, 1.139 60' Rapid588 93'Dodge Stealth, 8.24et 163mph, 1.15/60' ,2490lb, motor only. "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.68 156 Gregsdart 65 dart 8.77et 153.16mph, 3000 lbs, 2780 den altitude. NA 6/26/04 NHRAMARK 70 Duster 3050 lbs, 540" Indy, 9.274 @ 145.76mph acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire, 9.81@137 440Jim '69 Dart 9.83et 134. mph, 3150lbs, all motor Bigcube '69 Dart 9.91et 137 mph, 2950lbs, all motor TimMoffett 69 Charger 4-speed Street Car 10.68 @ 128.3, 1.54 60', 3900Lbs with full exhaust LAR_414 1969 Dart GT 11.33 118.9mph 3350lbs race wt 1.60 60' 414 stroked smallblock w/ factory J heads, solid cam and pump gas 493Charger 68 Charger R/T auto. 493" 3750 LBS 1.65 60' 11.76 116.57 68LAR '68 Road Runner 11.85ET 116.6MPH 3926LBS 1.65 60' 4 SPEED street car 12.466 @ 108.98 (1.764 60') Greg J, 69 Road Runner 3850 # w/driver, 446
[Re: quickd100]
#12664
09/14/04 05:28 PM
09/14/04 05:28 PM
Posts: 803 Texas
Beeracuda
super gas
super gas
Texas
The Haze 8.02 @ 174+ twin turbo 452" B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.178 @ 167.12 mph, 1.139 60' Rapid588 93'Dodge Stealth, 8.24et 163mph, 1.15/60' ,2490lb, motor only. "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.68 156 Gregsdart 65 dart 8.77et 153.16mph, 3000 lbs, 2780 den altitude. NA 6/26/04 Beeracuda 74 Barracuda 9.189 145.66 mph@4241' DA 2750 lbs 499/PG NHRAMARK 70 Duster 3050 lbs, 540" Indy, 9.274 @ 145.76mph acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire, 9.81@137 440Jim '69 Dart 9.83et 134. mph, 3150lbs, all motor Bigcube '69 Dart 9.91et 137 mph, 2950lbs, all motor TimMoffett 69 Charger 4-speed Street Car 10.68 @ 128.3, 1.54 60', 3900Lbs with full exhaust LAR_414 1969 Dart GT 11.33 118.9mph 3350lbs race wt 1.60 60' 414 stroked smallblock w/ factory J heads, solid cam and pump gas 493Charger 68 Charger R/T auto. 493" 3750 LBS 1.65 60' 11.76 116.57 68LAR '68 Road Runner 11.85ET 116.6MPH 3926LBS 1.65 60' 4 SPEED street car 12.466 @ 108.98 (1.764 60') Greg J, 69 Road Runner 3850 # w/driver, 446
[Re: Beeracuda]
#12665
09/14/04 08:12 PM
09/14/04 08:12 PM
Posts: 192 LEBANON;PA
daron
LEBANON;PA
The Haze 8.02 @ 174+ twin turbo 452" B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.178 @ 167.12 mph, 1.139 60' Rapid588 93'Dodge Stealth, 8.24et 163mph, 1.15/60' ,2490lb, motor only. "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.68 156 Gregsdart 65 dart 8.77et 153.16mph, 3000 lbs, 2780 den altitude. NA 6/26/04 Beeracuda 74 Barracuda 9.189 145.66 mph@4241' DA 2750 lbs 499/PG NHRAMARK 70 Duster 3050 lbs, 540" Indy, 9.274 @ 145.76mph acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire, 9.81@137 440Jim '69 Dart 9.83et 134. mph, 3150lbs, all motor Bigcube '69 Dart 9.91et 137 mph, 2950lbs, all motor TimMoffett 69 Charger 4-speed Street Car 10.68 @ 128.3, 1.54 60', 3900Lbs with full exhaust LAR_414 1969 Dart GT 11.33 118.9mph 3350lbs race wt 1.60 60' 414 stroked smallblock w/ factory J heads, solid cam and pump gas 493Charger 68 Charger R/T auto. 493" 3750 LBS 1.65 60' 11.76 116.57 68LAR '68 Road Runner 11.85ET 116.6MPH 3926LBS 1.65 60' 4 SPEED street car 12.466 @ 108.98 (1.764 60') Greg J, 69 Road Runner 3850 # w/driver, 446 daron 73 duster 10.50 et @ 127.00 sb street car
[Re: daron]
#12666
09/14/04 08:15 PM
09/14/04 08:15 PM
CokeBottleKid
Detroit, MI
guys please put your cars in order, not necessarily on the bottom of the list... unless you want to be slower The Haze 8.02 @ 174+ twin turbo 452" B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.178 @ 167.12 mph, 1.139 60' Rapid588 93'Dodge Stealth, 8.24et 163mph, 1.15/60' ,2490lb, motor only. "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.68 156 Gregsdart 65 dart 8.77et 153.16mph, 3000 lbs, 2780 den altitude. NA 6/26/04 Beeracuda 74 Barracuda 9.189 145.66 mph@4241' DA 2750 lbs 499/PG NHRAMARK 70 Duster 3050 lbs, 540" Indy, 9.274 @ 145.76mph acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire, 9.81@137440Jim '69 Dart 9.83et 134. mph, 3150lbs, all motor Bigcube '69 Dart 9.91et 137 mph, 2950lbs, all motor daron 73 duster 10.50 et @ 127.00 sb street car TimMoffett 69 Charger 4-speed Street Car 10.68 @ 128.3, 1.54 60', 3900Lbs with full exhaust LAR_414 1969 Dart GT 11.33 118.9mph 3350lbs race wt 1.60 60' 414 stroked smallblock w/ factory J heads, solid cam and pump gas 493Charger 68 Charger R/T auto. 493" 3750 LBS 1.65 60' 11.76 116.57 68LAR '68 Road Runner 11.85ET 116.6MPH 3926LBS 1.65 60' 4 SPEED street car 12.466 @ 108.98 (1.764 60') Greg J, 69 Road Runner 3850 # w/driver, 446
[Re: CokeBottleKid]
#12667
09/14/04 08:50 PM
09/14/04 08:50 PM
The Haze 8.02 @ 174+ twin turbo 452" B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.178 @ 167.12 mph, 1.139 60' Rapid588 93'Dodge Stealth, 8.24et 163mph, 1.15/60' ,2490lb, motor only. "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.68 156 Gregsdart 65 dart 8.77et 153.16mph, 3000 lbs, 2780 den altitude. NA 6/26/04 Beeracuda 74 Barracuda 9.189 145.66 mph@4241' DA 2750 lbs 499/PG NHRAMARK 70 Duster 3050 lbs, 540" Indy, 9.274 @ 145.76mph acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire, 9.81@137 440Jim '69 Dart 9.83et 134. mph, 3150lbs, all motor Bigcube '69 Dart 9.91et 137 mph, 2950lbs, all motor daron 73 duster 10.50 et @ 127.00 sb street car TimMoffett 69 Charger 4-speed Street Car 10.68 @ 128.3, 1.54 60', 3900Lbs with full exhaust w2_360duster 11.40 @119.18 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020lbs w/o driver LAR_414 1969 Dart GT 11.33 118.9mph 3350lbs race wt 1.60 60' 414 stroked smallblock w/ factory J heads, solid cam and pump gas 493Charger 68 Charger R/T auto. 493" 3750 LBS 1.65 60' 11.76 116.57 68LAR '68 Road Runner 11.85ET 116.6MPH 3926LBS 1.65 60' 4 SPEED street car 12.466 @ 108.98 (1.764 60') Greg J, 69 Road Runner 3850 # w/driver, 446
[Re: aarlucas]
#12669
09/14/04 08:59 PM
09/14/04 08:59 PM
Posts: 6,847 Missouri
StrokerPost
Missouri
The Haze 8.02 @ 174+ twin turbo 452" B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.178 @ 167.12 mph, 1.139 60' Rapid588 93'Dodge Stealth, 8.24et 163mph, 1.15/60' ,2490lb, motor only. "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.68 156 Gregsdart 65 dart 8.77et 153.16mph, 3000 lbs, 2780 den altitude. NA 6/26/04 Beeracuda 74 Barracuda 9.189 145.66 mph@4241' DA 2750 lbs 499/PG NHRAMARK 70 Duster 3050 lbs, 540" Indy, 9.274 @ 145.76mph acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire, 9.81@137440Jim '69 Dart 9.83et 134. mph, 3150lbs, all motor Bigcube '69 Dart 9.91et 137 mph, 2950lbs, all motor StrokerPost 67 Dart Sedan, 414 SB, 10.45 @ 127, 3290lbs, factory iron heads, all motor. daron 73 duster 10.50 et @ 127.00 sb street car TimMoffett 69 Charger 4-speed Street Car 10.68 @ 128.3, 1.54 60', 3900Lbs with full exhaust LAR_414 1969 Dart GT 11.33 118.9mph 3350lbs race wt 1.60 60' 414 stroked smallblock w/ factory J heads, solid cam and pump gas aarlucas '70 cuda,11.40 @ 121.80 W/1.63 60',451"6 PK, 3680lbs,2.5"exh sys,pump gas, 3.91, auto 493Charger 68 Charger R/T auto. 493" 3750 LBS 1.65 60' 11.76 116.57 68LAR '68 Road Runner 11.85ET 116.6MPH 3926LBS 1.65 60' 4 SPEED street car Greg J,12.466 @ 108.98 (1.764 60')69 Road Runner 3850 # w/driver, 446
[Re: StrokerPost]
#12670
09/14/04 09:02 PM
09/14/04 09:02 PM
Posts: 2,275 Kissimmee, Florida
aarlucas
Kissimmee, Florida
The Haze 8.02 @ 174+ twin turbo 452" B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.178 @ 167.12 mph, 1.139 60' Rapid588 93'Dodge Stealth, 8.24et 163mph, 1.15/60' ,2490lb, motor only. "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.68 156 Gregsdart 65 dart 8.77et 153.16mph, 3000 lbs, 2780 den altitude. NA 6/26/04 Beeracuda 74 Barracuda 9.189 145.66 mph@4241' DA 2750 lbs 499/PG NHRAMARK 70 Duster 3050 lbs, 540" Indy, 9.274 @ 145.76mph acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire, 9.81@137 440Jim '69 Dart 9.83et 134. mph, 3150lbs, all motor Bigcube '69 Dart 9.91et 137 mph, 2950lbs, all motor StrokerPost 67 Dart Sedan, 414 SB, 10.45 @ 127, 3290lbs, factory iron heads, all motor. daron 73 duster 10.50 et @ 127.00 sb street car TimMoffett 69 Charger 4-speed Street Car 10.68 @ 128.3, 1.54 60', 3900Lbs with full exhaust LAR_414 1969 Dart GT 11.33 118.9mph 3350lbs race wt 1.60 60' 414 stroked smallblock w/ factory J heads, solid cam and pump gas aarlucas '70 cuda,11.40 @ 121.80 W/1.63 60',451"6 PK, 3680lbs,2.5"exh sys,pump gas, 3.91, auto w2_360duster 11.40 @119.18 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020lbs w/o driver 493Charger 68 Charger R/T auto. 493" 3750 LBS 1.65 60' 11.76 116.57 68LAR '68 Road Runner 11.85ET 116.6MPH 3926LBS 1.65 60' 4 SPEED street car cudadan, 12.02 at 110 with a 1.58 60ft quickd100, 1.595 60ft. 7.621@87.04-1/8 12.19@105.88 1/4 Greg J,12.466 @ 108.98 (1.764 60')69 Road Runner 3850 # w/driver, 446
[Re: aarlucas]
#12671
09/14/04 09:50 PM
09/14/04 09:50 PM
Posts: 16,934 NC
440Jim
NC
I already have the Dart at 9.83, this adds my 440 Barracuda at 11.72 at 113 mph, 1.59 sixty with 4.30 gears; it went 11.77 at 116, 1.66 sixty with the 3.91 gears. The hydraulic cam gave up with the 4.30 gears on the top end. The Haze 8.02 @ 174+ twin turbo 452" B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.178 @ 167.12 mph, 1.139 60' Rapid588 93'Dodge Stealth, 8.24et 163mph, 1.15/60' ,2490lb, motor only. "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.68 156 Gregsdart 65 dart 8.77et 153.16mph, 3000 lbs, 2780 den altitude. NA 6/26/04 Beeracuda 74 Barracuda 9.189 145.66 mph@4241' DA 2750 lbs 499/PG NHRAMARK 70 Duster 3050 lbs, 540" Indy, 9.274 @ 145.76mph acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire, 9.81@137 440Jim '69 Dart 9.83et 134. mph, 3150lbs, all motor, 471CID Bigcube '69 Dart 9.91et 137 mph, 2950lbs, all motor StrokerPost 67 Dart Sedan, 414 SB, 10.45 @ 127, 3290lbs, factory iron heads, all motor. daron 73 duster 10.50 et @ 127.00 sb street car TimMoffett 69 Charger 4-speed Street Car 10.68 @ 128.3, 1.54 60', 3900Lbs with full exhaust LAR_414 1969 Dart GT 11.33 118.9mph 3350lbs race wt 1.60 60' 414 stroked smallblock w/ factory J heads, solid cam and pump gas aarlucas '70 cuda,11.40 @ 121.80 W/1.63 60',451"6 PK, 3680lbs,2.5"exh sys,pump gas, 3.91, auto w2_360duster 11.40 @119.18 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020lbs w/o driver 440Jim '73 Cuda 11.72et 113mph, 3700lbs, hyd cam, 446CID, street 493Charger 68 Charger R/T auto. 493" 3750 LBS 1.65 60' 11.76 116.57 68LAR '68 Road Runner 11.85ET 116.6MPH 3926LBS 1.65 60' 4 SPEED street car cudadan, 12.02 at 110 with a 1.58 60ft quickd100, 1.595 60ft. 7.621@87.04-1/8 12.19@105.88 1/4 Greg J,12.466 @ 108.98 (1.764 60')69 Road Runner 3850 # w/driver, 446
[Re: aarlucas]
#12672
09/14/04 09:52 PM
09/14/04 09:52 PM
Posts: 754 Longview, Texas
marvo451
Longview, Texas
Marvo451 '71 Duster 10.23@130.50,1.41/60ft.,451 RB. Iron 452 heads, pump gas, flat tappet cam, 3220 lbs.
[Re: marvo451]
#12673
09/15/04 04:01 AM
09/15/04 04:01 AM
Posts: 2,697 Renton Wa
topfueldart
Renton Wa
The Haze 8.02 @ 174+ twin turbo 452" B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.178 @ 167.12 mph, 1.139 60' Rapid588 93'Dodge Stealth, 8.24et 163mph, 1.15/60' ,2490lb, motor only. "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.68 156 Gregsdart 65 dart 8.77et 153.16mph, 3000 lbs, 2780 den altitude. NA 6/26/04 Beeracuda 74 Barracuda 9.189 145.66 mph@4241' DA 2750 lbs 499/PG NHRAMARK 70 Duster 3050 lbs, 540" Indy, 9.274 @ 145.76mph acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire, 9.81@137 440Jim '69 Dart 9.83et 134. mph, 3150lbs, all motor, 471CID Bigcube '69 Dart 9.91et 137 mph, 2950lbs, all motor Marvo451 '71 Duster 10.23@130.50,1.41/60ft.,451 RB. Iron 452 heads, pump gas, flat tappet cam StrokerPost 67 Dart Sedan, 414 SB, 10.45 @ 127, 3290lbs, factory iron heads, all motor. daron 73 duster 10.50 et @ 127.00 sb street car TimMoffett 69 Charger 4-speed Street Car 10.68 @ 128.3, 1.54 60', 3900Lbs with full exhaust LAR_414 1969 Dart GT 11.33 118.9mph 3350lbs race wt 1.60 60' 414 stroked smallblock w/ factory J heads, solid cam and pump gas aarlucas '70 cuda,11.40 @ 121.80 W/1.63 60',451"6 PK, 3680lbs,2.5"exh sys,pump gas, 3.91, auto w2_360duster 11.40 @119.18 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020lbs w/o driver 440Jim '73 Cuda 11.72et 113mph, 3700lbs, hyd cam, 446CID, street 493Charger 68 Charger R/T auto. 493" 3750 LBS 1.65 60' 11.76 116.57 68LAR '68 Road Runner 11.85ET 116.6MPH 3926LBS 1.65 60' 4 SPEED street car topfueldart 70 challenger 446, bone stock 906's, hyd cam, 11.97 @ 111 1.65 60ft cudadan, 12.02 at 110 with a 1.58 60ft quickd100, 1.595 60ft. 7.621@87.04-1/8 12.19@105.88 1/4 Greg J,12.466 @ 108.98 (1.764 60')69 Road Runner 3850 # w/driver, 446
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
