Re: i think my sprag went....found stuff in pan... [Re: Todd] #1268565
07/21/12 01:35 PM
07/21/12 01:35 PM
Ohio
Todd Offline OP
Todd  Offline OP
Ohio
Got the trans out and to the builder. He took it apart while we waited and my guess was right. The sprag came apart. He said it could have been alot worse. It only had a 12 roller stock sprag from TCI. Going to replace it with a 16 roller from A&A.
Re: i think my sprag went....found stuff in pan... [Re: Todd] #1268566
07/21/12 03:35 PM
07/21/12 03:35 PM
NC
440Jim Offline
440Jim  Offline
NC
Well, that answers that question. I thought you said it had a sprag with extra rollers?
Re: i think my sprag went....found stuff in pan... [Re: 440Jim] #1268567
07/21/12 03:49 PM
07/21/12 03:49 PM
Ohio
Todd Offline OP
Todd  Offline OP
Ohio
Yea that's what I thought it had. It makes a lot more sense now when my dad got the the one that turned to junk was half the price.
Re: i think my sprag went....found stuff in pan... [Re: Todd] #1268568
07/22/12 04:19 AM
07/22/12 04:19 AM
San Diego
formula S Offline
formula S  Offline
San Diego
To help prevent this from happening again, never start your burnouts in 1st gear
Re: i think my sprag went....found stuff in pan... [Re: Todd] #1268569
07/22/12 01:29 PM
07/22/12 01:29 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
That 16 roller unit is great and stops a lot of those problems
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: i think my sprag went....found stuff in pan... [Re: Todd] #1268570
07/22/12 02:42 PM
07/22/12 02:42 PM
NC
440Jim Offline
440Jim  Offline
NC
I like the look of the stepped, axle bolts used in Coan Super Sprag better than the ferrals on the A&A unit. But both should be a big improvement to the factory setup.
Re: i think my sprag went....found stuff in pan... [Re: dusturbd340W5] #1268571
07/22/12 02:44 PM
07/22/12 02:44 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Well we know the effect.... now what was the cause?
When I had the trans in my old car updated, I inquired about changing from the stock sprag. The builder didn't seem to concerned with the "upgrade" as I had never had issues with it, and the stock unit was secure in the case. Springs were uniform and rollers true. I've always just done my burnout in 2nd which he said was just fine.
Re: i think my sprag went....found stuff in pan... [Re: 440Jim] #1268572
07/22/12 02:45 PM
07/22/12 02:45 PM
Kissimmee Fl.
Kissimmee Fl.
that is the 1 I used because of the stepped bolts.
