Re: using stainless brake lines with many leaks [Re: flypaper] #1268219
07/16/12 01:48 AM
07/16/12 01:48 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
that is the root of your problem...
reg lines use a 45 degree flare for the seat
stainless has a 37 degree flare
I guess the $20 question is why in the heck would they have different angles? There is a rational reason?
Re: using stainless brake lines with many leaks [Re: Rug_Trucker] #1268220
07/16/12 02:15 AM
07/16/12 02:15 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
The 37 is for the aircraft industry, the 45 is automotive....has to do with cracking. Tim
Re: using stainless brake lines with many leaks [Re: astjp2] #1268221
07/16/12 02:28 AM
07/16/12 02:28 AM
Rug_Trucker Offline
Rug_Trucker  Offline
So, they are selling the wrong fittings as brake lines. They have no fears of liability issues? Amazing!
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: using stainless brake lines with many leaks [Re: mopar_leaner] #1268222
07/16/12 03:23 AM
07/16/12 03:23 AM
cbusters Offline
cbusters  Offline
The used parts already have the imprint of the old line flares. If the brass parts are new they will seal. I had to call the brake line company about that one myself. Replaced the block and inserts in the m/c and it sealed up.
