Re: using stainless brake lines with many leaks
[Re: mopar_leaner]
#1268200
07/15/12 01:11 PM
07/15/12 01:11 PM
Challenger 1
Cincinnati, Ohio
Stainless lines suck because of this, imo. They have to be oiled which I bet they are now and then be really tight, like tighten them and loosen them then tighten them again and again until they seal up. They have to be really tight and lubed when you tighten them, did I mention they have to be tight, real tight?
And no teflon tape and anywhere near flare fittings, like the inverted flares your trying to seal.
Plus you better have GOOD line wrenches, no way reg wrenches are gonna work with stainless lines!
[Re: Bill MeLater]
#1268204
07/15/12 02:57 PM
07/15/12 02:57 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
Yup...Just tighten 'em till the corners just start to round off, and your halfway there..
tooo funny!!! stainless looks pretty but sure isn't worth all the headaches! what really sucks is the lines stay nice but the fittings look like crap in a year....
[Re: RSNOMO]
#1268211
07/15/12 10:11 PM
07/15/12 10:11 PM
Posts: 2,431 USA
SSAAHemiFan
USA
I use the anti-seize and tighten and retighten method above. For problem connections I have put a TINY dab of rectorseal (pipe dope)at the flair to help lube the sealing surface connection and seal any small imperfections. Those flarite seals seem do the same without risk of contamination.. I would like to try them. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: JohnRR]
#1268213
07/15/12 10:54 PM
07/15/12 10:54 PM
Posts: 1,682 Philadelphia
radar
Philadelphia
The last stainless line set I installed was a right stuff , used anti-seize as I stated above with a flare nut wrench , small weep at one joint , little more with the wrench and no more leak.
Same exact experience here love 'em
[Re: JohnRR]
#1268215
07/16/12 12:17 AM
07/16/12 12:17 AM
Posts: 18,632 jersey shore
flypaper
I hate Texas
I hate Texas
jersey shore
The seal is not made in the threads, it is made by the flare against the seat. .
that is the root of your problem... reg lines use a 45 degree flare for the seat stainless has a 37 degree flare you either need to use adaptors to fix this issue or tighten the out of them with the methods suggested ![](/ubbthreads/images/graemlins/laugh.gif)
[Re: gregn96cuda]
#1268217
07/16/12 12:26 AM
07/16/12 12:26 AM
Posts: 1,880 Out in Left Field, NY
bobs66440
I read on here or some other site that the stainless brake lines have a different angle at the face of the flair.
The AN fittings use a 37 degree flare. SAE double flare is 45 degree. You can use the stainless line and make 37 degree single flares and use the AN flare nuts and sleeves.
[Re: radar]
#1268218
07/16/12 12:28 AM
07/16/12 12:28 AM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
x3 here.
