Page 21 of 36 1 2 19 20 21 22 23 35 36
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: moparpollack] #1267639
12/30/14 11:09 PM
12/30/14 11:09 PM
SoCal
MuuMuu101 Offline OP
I got lucky at Woodward!
SoCal
How's that 273 running?
Good question. I'll let you know as soon as I know.
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: MuuMuu101] #1267640
12/31/14 12:21 PM
12/31/14 12:21 PM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
Again, good progress. I'm about to get started on mine here pretty quick. Again.
1969 Dart GTS 340
1969 Coronet R/T X9 N-96
1999 Dodge Dakota R/T RC
2015 Dodge Dart GT
2019 Ram 2500 Big Horn
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: MuuMuu101] #1267641
01/31/15 11:48 PM
01/31/15 11:48 PM
SoCal
SoCal
So today I decided to stop thinking about the things that are stressing me out more in life and focus on a different, but arguably, less burdensome task.
I finished putting together the entire front suspension and brake setup. I toqued everything but I haven't fiddled with my camber bolts because I'm not sure how to set those properly. I also installed my Hotchkis, Fox Adjustable shocks and right now I set them to the softest setting. I just hope when I start driving this thing it will be painless and I won't find things I overlooked or forgot.
Right now, what I need to do is remake a couple of the front brakelines to make up for the front mounted calipers, swap out my rear shocks, install subframe connectors and sway bars, send it to an alignment shop, and some fluid based maintenance (oil change, add trans fluid, flush radiator, etc.)
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: MuuMuu101] #1267642
01/31/15 11:48 PM
01/31/15 11:48 PM
SoCal
SoCal
O yeah... Test fit of new wheels to see how they'd look. Torsion bars and shocks were already installed so I couldn't get it any lower.
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: MuuMuu101] #1267643
02/15/15 01:54 AM
02/15/15 01:54 AM
SoCal
SoCal
I know it's towards the end, but I'm throwing in the towel. I've got the wheels on the car and put the car on the ground. Definitely an awesome moment and all I could think was how bad @$$ it was. Well, next weekend, I'm going to be sending the car over to my mechanics. I'm going to have them redo a couple brake lines, do some regular maintenance, set its alignment, and weld in the sway bars and subframe connectors.
Hopefully it will be done sometime before April and I'll be able to take it to the Hotchkis Autocross and/or Spring Fling.
One thing I was upset about was that one side sits higher than the other. Whenever I fiddled with the passenger side adjuster the ride height changed. No matter how much I tightened or loosened the driver side torsion bar adjuster the ride height stayed the same so now my car has a little gangster lean to it. The whole driver side is taller than the passenger side. Overall, I like the ride height of the passenger side.
Also, it looks like there may be some interference with the top passenger quarter panel brace. I don't have that problem with the driver's side because the brace tore off sometime in its lifetime... No, seriously, the mounting points are gone, sheared.
Due to the wheels, the GT trim is starting to grow on me. I really don't know why, but not too long ago I wanted to throw it all out. Now I wish I kind of had the driver's door trim and all the trim was in better condition.
So here are some pictures... I edited on my phone, increasing the brightness and adding a filter to see more of the details. That's why there's an interesting hue to it.
Driver's side:
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: MuuMuu101] #1267644
02/15/15 01:55 AM
02/15/15 01:55 AM
SoCal
SoCal
Passenger side:
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: MuuMuu101] #1267645
02/15/15 01:55 AM
02/15/15 01:55 AM
SoCal
SoCal
Driver's Front:
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: MuuMuu101] #1267646
02/15/15 01:56 AM
02/15/15 01:56 AM
SoCal
SoCal
Driver's Rear:
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: MuuMuu101] #1267647
02/15/15 01:56 AM
02/15/15 01:56 AM
SoCal
SoCal
Passenger Front:
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: MuuMuu101] #1267648
02/15/15 01:57 AM
02/15/15 01:57 AM
SoCal
SoCal
Passenger Rear:
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: MuuMuu101] #1267649
02/15/15 01:49 PM
02/15/15 01:49 PM
SoCal
SoCal
Fixed the ride height issue. It was me just being stupid and tightening one of the adjusters instead of loosening it.
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: MuuMuu101] #1267650
02/15/15 03:04 PM
02/15/15 03:04 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
That's looking nice. Strangely I like the trim as well. It sets it off and actually works well with the new wheels.
Sheldon
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: RUNCHARGER] #1267651
02/15/15 03:33 PM
02/15/15 03:33 PM
SoCal
SoCal
Sheldon
Just a week ago I wanted to completely get rid of it, now I'm not so sure anymore. Like I said, I kind of wished I had a driver's door trim. Ironically, someone a year or two ago on FABO was selling one and someone informed me of it. I blew it off because I was planning on removing it some day. Now I kind of wish I didn't.
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: MuuMuu101] #1267652
03/22/15 12:30 AM
03/22/15 12:30 AM
SoCal
SoCal
Getting back on it. Finished my last set of finals on Friday, so hopefully I pass all my classes. Then I should be working full-time soon.
Other than that, I'm back on the Dart. I've got a bunch of little things I need to take care of. Today I replaced a shock (the one I got had a shim that was accidentally pressed in the bushing). Tomorrow I'm going to fiddle with the front and the ride height a little bit. Monday I'm doing an oil change (actually the first one I've ever done). Tuesday my friend is coming over to do brake lines and help me bleed the system. Wednesday I'm going to start greasing ball joints. Hopefully Thursday or Friday I'll send it out to be aligned. And if I'm lucky, I will be able to compete in the Hotchkis Autocross over the weekend.
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: MuuMuu101] #1799750
04/09/15 08:30 PM
04/09/15 08:30 PM
SoCal
SoCal
Well, a big update for you guys... I got the Dart on all 4's again and sent it to a shop. Part of it is to get some safety concerns addressed and the other part is to make it a racecar. Things on the list to get done... Engine swap (I already have a deal made it should make more than enough power for me to handle), new steering box (we're going to try something new, not Borgeson or FirmFeel), a potential manual trans swap (up in the air), and new interior (seats, belt, steering wheel, steering column/maybe, and a 4-point cage). It should be fun, but man is it going to hurt the bank account.
Before it left today.
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: MuuMuu101] #1799821
04/09/15 09:38 PM
04/09/15 09:38 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Nice Mustang! tonguue
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: moparpollack] #1799936
04/09/15 11:15 PM
04/09/15 11:15 PM
SoCal
SoCal
I've gotten Nice Nova before... Hey you're not going to ask me how my 273 is doing?
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: MuuMuu101] #1800114
04/10/15 10:01 AM
04/10/15 10:01 AM
Maryland
wally426ci Offline
wally426ci  Offline
Maryland
It looks great man!
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: MuuMuu101] #1800164
04/10/15 11:04 AM
04/10/15 11:04 AM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
Looking good!!
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: MuuMuu101] #1800180
04/10/15 11:21 AM
04/10/15 11:21 AM
Caldwell, Idaho
67R/T4speeder Offline
Caldwell, Idaho
Great looking Dart
