Page 12 of 36 1 2 10 11 12 13 14 35 36
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: MuuMuu101] #1267459
01/02/13 08:04 AM
01/02/13 08:04 AM
Maryland
wally426ci Offline
wally426ci  Offline
Maryland
Hey MuuMuu, I ran gouged rotors for a while due to lack of funds. It just means you'll need new pads when you do the rotors.
I also got my front rotors at Autozone and they have been fine. It's probably about the same price.
BTW - I won't say alot of good about big box autoparts stores but I will say that Autozone is the only place I can find Timken wheel bearings which I prefer.
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: wally426ci] #1267460
01/03/13 07:21 PM
01/03/13 07:21 PM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
Just rotors, no hubs, correct? Starting to look for the brake pieces to get my GTS stopping. Good point on the Timkens, too. I did notice they are the only ones that carry them.
1969 Dart GTS 340
1969 Coronet R/T X9 N-96
1999 Dodge Dakota R/T RC
2015 Dodge Dart GT
2019 Ram 2500 Big Horn
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: MuuMuu101] #1267461
01/06/13 01:58 AM
01/06/13 01:58 AM
SoCal
MuuMuu101 Offline OP
I got lucky at Woodward!
SoCal
Some updates. Mostly from today, but some from earlier in the week. So after I pulled my rotors and hubs off, I got bored and wanted to try to take out the grease off my UCA's. I'm not sure if the pressure washer would be able to get the hard stuff off so I worked at it for like an hour or so with some engine degreaser, a chisel, a hammer, and a wire brush. This is a comparison of how it used to look like (passenger side) vs. how it looks like now (driver side).
Earlier this week, my new rotors came in. Here's are pictures of them still in its package. They look like they'll work perfectly. There's definitely a lot more material on these guys than the ones I pulled off. The vented fins are also thicker as well so they should perform quite well.
Earlier tonight my friend and I got working on the firewall, brake pedal, and MC ordeal. I ended up wire wheeling the outer trim of the hole I cut out of the firewall for when we plan on welding the new panel (probably next week). We also made the new panel, just need to do some measurements of where to locate the MC and such. Lastly we worked on the brake pedal assembly (since it had more holes than swiss cheese) and basically we cut off the rivet/stud tabs and we're going to weld on new pieces with holes to mount the MC in the right spot. All the sheetmetal we used was .060" chromoly. Of course, more pictures...
My friend is going to fill up his welding tanks this weeks and we may start welding next week. My pads should be coming in on Tuesday and my studs should be here by Thursday. Hopefully by the end of the month all the brake stuff gets done. There's still quite a bit of work to do.
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: MuuMuu101] #1267462
01/12/13 11:56 PM
01/12/13 11:56 PM
SoCal
SoCal
Was a little bored today so I decided to paint something. Took the air filter breather off and worked on that. It wasn't my best work, but it came out better than before so I'll leave it at that. Kind of bittersweet and depressing sitting by the car and not being able to drive it. My friend and I may start working on it a little next weekend. Now with school and baja, time is becoming harder to find. As always, here are the pictures. All the pictures were taken with a fresh coat of paint. I touched them up a little afterwards.
I'm thinking about taking the calipers off and rebuilding them on my own time since the firewall and MC are going to take my friend and I a while before getting finished. I'd also like to paint the calipers black as well as the hubs when I get the studs off just in case I want to go with bigger wheels later on this year (after a suspension rebuild). I'm thinking about these if they will fit due to limited bs options.
Store: http://motechperformance.com/?page_id=22
Wheels: http://motechperformance.com/?tcp_product=17-polished-streeter
http://motechperformance.com/?tcp_product=17-black-streeter-priced-per-pair-249
Cheap, local, and the right bolt pattern. I figure I could get new wheels and tires for under $1k. I'd like a 275/35/18 series tire all the way around but with the bs offered, I don't think it's going to happen. I may end up going with a 17" (idk whether 7" or 8" wide) wheels with a 245(or 255 if it fits)/45/17 tire. That way the brakes don't look super small and I have less rotating mass.
That's pretty much it. Thanks for tuning in.
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: OhioMopar] #1267463
01/14/13 08:17 AM
01/14/13 08:17 AM
Maryland
wally426ci Offline
wally426ci  Offline
Maryland
The autozone pieces I got were hub/rotor all 1 piece. Originals I believe were 2 piece.
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: wally426ci] #1267464
01/15/13 01:11 AM
01/15/13 01:11 AM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
Cool! Thanks.
1969 Dart GTS 340
2015 Dodge Dart GT
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: MuuMuu101] #1267465
01/19/13 12:35 PM
01/19/13 12:35 PM
SoCal
SoCal
So here's the deal. Friend came over last night and we had our hand with the studs. Got 9.5 out. I screwed up the nut so much it won't unthread so we're going to cut it off today. Also, we took a closer look at my calipers and it seems like they are going to need a rebuild. My seals are all rotted away so if I have to take it apart I might as well restore/rebuild them. Anyone know where to get parts? While I'm at it, I think I'm going to paint them black along with the hubs and rear drum covers.
We also took out some of the AC stuff in the engine compartment last night. All the stuff under the dash is a little confusing though.
I also went to the tire shop yesterday since I needed my tire to be plugged and had a look at a lot of 17" tires (primarily 215/45/17 and that range). They don't seem too bad of a size for the fronts. I'm just worried that if I decide to go with bigger wheels and tires later in the year that my 7 1/4 will go capoot.
That's it for now. More progress on the firewall later today though. The more I go through this the longer it seems to take as I keep finding more and more wrong. I guess that's just what we have to go through on 45 year old cars.
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: MuuMuu101] #1267466
01/20/13 02:43 AM
01/20/13 02:43 AM
SoCal
SoCal
So here's all the progress of the weekend. Been working slowly but we're pushing through little by little. Got the firewall welded and grinded a little. May do some more work on Monday and work with the pedal assembly as well. I'm going to probably rebuild my calipers since the seals are bad. Also may get new wheel bearings as well since I've practically rebuilt the entire brake system.
Also took out some of the AC stuff from the engine compartment to reduce weight and clean it up a little.
Went to the tire shop on Friday to look at tires. I'd like some 17's but don't know if my axles can handle them in the rear. Also looks like I'm going to need a skinny front (was hoping for something like a 245 or more).
Here are my progress pics...
Hubs and studs:
Going to need a rebuild and a fresh coat of black paint:
Firewall:
(a little bit of grinding)
Engine Compartment with a little less AC:
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: MuuMuu101] #1267467
01/27/13 03:10 AM
01/27/13 03:10 AM
SoCal
SoCal
Ordered some more parts and am currently degreasing my UCA's. My friend may come over tomorrow night and we may work on the Dart a little.
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: MuuMuu101] #1267468
01/27/13 03:56 AM
01/27/13 03:56 AM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
Cool! Roadworthy by a penguin spring?
1969 Dart GTS 340
2015 Dodge Dart GT
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: MuuMuu101] #1267469
02/02/13 10:38 AM
02/02/13 10:38 AM
Southern by Choice
Shoozy Offline
I have a foot fetish
Shoozy  Offline
Southern by Choice
STOP STUDYING and get back to work.
Old, tired, and sometimes broke down. Me, not my car...
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: Shoozy] #1267470
02/03/13 01:34 AM
02/03/13 01:34 AM
SoCal
SoCal
I haven't been studying much and I have hardly touched my Dart. I got a bunch of stuff in the mail this week. I've been spending most my time in Baja, machining parts. All I've done is taken off the bearing seals on the hubs so I can clean them.
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: MuuMuu101] #1267471
02/03/13 10:02 AM
02/03/13 10:02 AM
Southern by Choice
Shoozy Offline
Shoozy  Offline
Southern by Choice
Baja is great to develop your skills for YOUR project! Do you have access to a parts washer at school?
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: Shoozy] #1267472
02/03/13 02:23 PM
02/03/13 02:23 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Me going to Baja would mean intense study...
Of Agave...
And Senorita's...
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: Shoozy] #1267473
02/03/13 03:35 PM
02/03/13 03:35 PM
SoCal
SoCal
I'm learning a lot. Even on my Dart when my friend is helping me. I really need to absorb as much as I can in the shop the next couple months because there will only be 4 returning members out of 10 or so of us.
Now that you mention it, I do have access to a parts cleaner. Right now it's crunch time. 10 weeks till we are off to Tennessee. Then 3 weeks after that we're off to Washington.
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: MuuMuu101] #1267474
02/03/13 03:37 PM
02/03/13 03:37 PM
Southern by Choice
Shoozy Offline
Shoozy  Offline
Southern by Choice
OK so take some parts with you to the shop and soak them while you work on Baja....when you leave your clean parts go home with you...
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: Shoozy] #1267475
02/15/13 01:59 AM
02/15/13 01:59 AM
SoCal
SoCal
Very small update. No Valentine's Date tonight (must be a curse of the engineers) so I decided to spend some time with the Dart. I changed the upper radiator hose and wire brushed the UCAs. I was going to try my hand at block sanding the firewall, but I didn't have a block with me that wasn't too big so I may just borrow one from the shop tomorrow. Don't worry, I've been sanding so much in baja this year I've earned the nickname of "Sandy Samy." I've sanded everything from aluminum to fiberglass to carbon fiber.
Progress is going to be really slow for a while. All free time and weekends goes to the baja car till our competition in Tennessee, April 16th. Then we have another one 3 weeks later in Washington. I sure do miss driving the Dart.
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: MuuMuu101] #1267476
02/15/13 09:47 PM
02/15/13 09:47 PM
Southern by Choice
Shoozy Offline
Shoozy  Offline
Southern by Choice
Where in TN will you be in April? I am just 1.25 hours south of Chattanooga.....
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: Shoozy] #1267477
02/16/13 04:29 AM
02/16/13 04:29 AM
SoCal
SoCal
Cookeville, TN. I believe it's about another 100 miles South of Chattanooga.
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: MuuMuu101] #1267478
02/16/13 10:43 AM
02/16/13 10:43 AM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
Cookeville is between Knoxville and Nashville, on I-40. That used to be my gas stop every 2 weeks when I was cannonballing to go see my then girlfriend. That was the good ol days....lived on adrenaline,Big Macs and ! I've since had to cut out the Big Macs. Have fun in TN.
